Question about Dishwashers
Frigidaire FDB1050REM0 dishwasher. Lights go through all cycles on every setting. Soap dispenser opens as it should and timer is right on.
It started making noise below the tub so I researched it here and found it was most likely the pump. I've replaced the circulation and drain pumps. All connections are solid and the water pressure is very good. At the connection to the control module one of the terminals to be discolored suggesting signs of heat. Door latch checks out ok
I'd pop open the drain screen and see if anything is in there, it sounds like theirs something reaching the propeller, sounds kinda like a card in bike spokes
Posted on Sep 22, 2014
2 Suggested Answers
  • 330 Answers
SOURCE: dishwasher stopped in mid cycle. door
check the main fuse box breaker
Posted on Jul 06, 2008
My FRigidaire GLD2250RDC6 dispenser cup doesnt open after any full cycle. Open the cup manually & the soap cube is still there.
remove door face so you can see the back side of soap door. close soap door and turn timer by hand. watch and see if a part on the trip mechenism is broke.. then replace that part
May 26, 2012 | Frigidaire Dishwashers
The soap dispenser only opens sometimes. When the dispenser doesn't open the soap is in a solid cake inside dispenser.
IF DISPENSER IS CLOSED WHEN FINISHED COMPLETE CYCLE .
THERE ARE TWO WAYS THAT D/W'S
OPEN THE DISPENSER ONE IS BY WAY OF TIMER TRIPPING LATCH, OTHER IS BY WAY OF BIMETAL IN THE DOOR. THE SOLID IS BECAUSE OF THE MOISTURE ABSORPTION OF THE SOAP. THIS IS ASSUMING THAT YOU HAVE NOT BLOCKED THE DISPENSER DOOR WITH SOME OBSTRUCTION.
Feb 18, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Soap dispenser problem?
Check the water supply. Start cycle then open the door after it fills and check water level and spray action. If everything is soaking wet, there is probablyl a pizza pan blocking the soap tray.
Jan 05, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Frigidaire FDB1050REM2 soap cup doesn't open or opens but doesn't dispense. is it a latch, spring or timer issue?
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 27, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire fdb510lcs0 soap dispenser not opening
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once poweris applied to it. The BI-metal strip bends and allows the soap door spring toopen up the dispenser. This bi-metal strip is not given full 120 volts power,the timer "shunts" the power through either the heating element (most common ) or the motor and this gives the bi-metal strip lower than fullpower to work and open. Most often the bi-metal strip has lost its ability tobend properly and needs to be replaced. Older GE dishwashers used a mechanicalarm driven by the timer to open the dispenser = no electrical bi-metals.
Newer Frigidaire dishwashers and many newer Whirlpool dishwashers use a wax motor to open the soap dispenser. The plunger insidethe wax motor slowly moves and pushes the plunger and door open. And, if thiswax motor doesn’t receive 120 volts, then it’ll not work.
This will help you --
Please do rate this solution and revert for furtherassistance.
Thanks
Rylee
Sep 20, 2009 | Frigidaire Dishwashers
GE profile model GSD 4120y70BB the second soap dispensor does not open at the right time. When cycle is done and the door is opened the soap has just ran down. It is like it is opening to late.
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced. Older GE dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) Maytag dishwashers and many newer Whirlpool and Frigidaire dishwashers use a wax motor to open the soap dispenser; this wax motor does receive 120 volts to work. The plunger inside the wax motor slowly moves and pushes the plunger and door open. This is what a wax motor looks like.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 06, 2009 | GE Dishwashers
Cleaning Cycle not Starting
Please provide the model number and the approximate age of the dishwasher.
If this diswasher uses a turning dial to select the cycle, which turns as the dishwasher progresses, I strongly suspect that this timer has failed and needs replacement. Especially since the soap door never opens. Does the dishwasher drain during and at the end of the full cycle?
Mar 29, 2009 | GE Dishwashers
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Soap dispenser doesn't open for wash cycle
I noticed you didn't rate out chat and saw that your problem was posted. I'm happy to continue to help you if you encountered problems or were not happy with the solution in your chat session.
Jul 07, 2008 | Frigidaire FDS251RJ Free-standing...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
Owen Barnes
