Question about Unitec Gj 6200 Go-jak Right Hand Vehicle Dolly Caster Sold
Very hard to press down on pedal on 6200
This is anew item, I used it once and it is very hard to press down on pedal with all of my 270 lbs.
  • anthony dileo
    anthony dileo Feb 14, 2014
    also can the 6200 be used to just wheel the tire over to the car and align the stud holes with rim and put on the lug nuts so you don t have to physically lift tire up to align the holes.
How to hard reset maylong m-270.
look for a tiny hole on the side.Use a paper clip to reset. If not, try turning unit off then press power and volume DOWN at the same time to restart. use the manu after that. If that desnt work, try same thing with volume UP.
Nov 27, 2015 | Maylong Mobility M-270 7 4 GB Tablet -...
When I stomp on my brakes let's say in an emergency the pedal is very hard and the brakes don't realy work at all but if I use them normally they are perfect it's on a ford au xr6 ute
to test your brake assist is working. stop the motor. Press w few times the brakes, till the pedal feels sturdy. Then while pressing the pedal down firmly, start the engine. When you feel the pedal going down, like feeling "soft" you know the brake assist works. If nothing changes it is defect.
Jul 14, 2014 | 1999 Ford Falcon
After cranking it will go dead unless I hold the gas pedal down then once I put it in drive it bogs down & will not accelerate or hesitates to accelerate when trying to pull into traffic. After holding...
Have the fault codes read. Replace faulty items. Use only genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units.
Jun 03, 2013 | 1995-1997 Chevy Suburban Ignition Starter...
97 chevy suburban have replaced fuel pump, relay, fuel filter, & the fuel pressure regulator but now it will crank & then die once I press the gas pedal. It also bogs down after coming to a st
possible faulty accelerator position sensor. Have the fault codes read. Replace faulty items. Use only genuine items as non-genuine replacement are not always compatible with the OEM fitted CPU units
1992 F250 460 cid automatic 2w drive 85000 mi. Just replaced my master cylinder, all 4 brakes, and both front rotors. Afterward I blead the brakes and got bubbles out of fluid. Problem is : when not...
There is never a test or reason to pump your brakes
Accomplishes absolutely nothing.
There is no pressure in a braking system at all,
until you SLOWLY apply the brake pedal.
Then less than 1" off movement in the master cyl,
will develop 600 to 1800 lbs at the wheels
Release the brake pedal, the system goes to zero,
IT DOES NOT HOLD ANY PRESSURE
To answer your question
You not suppost to press the pedal hard
The saying goes--you apply the brakes,
not force the pedal arm and pin into the
vacuum booster, as though you want to damage it
When your driving what happens ?
You have higher manifold vacuum and
thus your pedal is normal,why the VACUUM
brake booster
Mar 31, 2011 | 1992 Ford F250
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
How can I take off the fuel pump on my nissan altima 2001
The procedure is as follows:---
  • First of all get the fuel pressure released and then disconnect the negative battery cable .
  • The fuel pump can be seen by taking out the rear seat and removing the access cover. Unplug the fuel pump's electrical connection and disconnect the fuel lines from the fuel pump. Remove the locking ring or screws with a socket wrench and disconnect the fuel gauge assembly so that you can disconnect the fuel tube from the fuel gauge.
  • Remove the fuel pump by holding the connector for the fuel line in one hand while pressing down on the two locking tabs at the same time. Lift the fuel pump out of the fuel tank. Discard the O-ring.
  • Install the new fuel pump using the items included in the kit, especially the O-ring. If you have a threaded lock ring, torque it to between 22 and 26 ft. lbs. If you have lock ring with six retaining screws, torque them to between 18 and 22 in. lbs.
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    Aug 19, 2010 | 2001 Nissan Altima
    98 bmw z3 gas pedal meets resistance
    has some of the fire wall sound deadner falling behind the pedal near the top where it mounts
    May 31, 2009 | 1998 BMW Z3 Roadster
    My dell gx-270 power keeps shutting down.
    hmmm,
    Dont worry just boot your computer using Bootable disk or windows installation disk, enter into Recovery console by pressing"R"
    type the Administrator password if any or simply press "Enter".
    At the command prompt type-"fixboot"
    once done restart your computer normally.
    Mar 25, 2009 | Dell OptiPlex GX270 PC Desktop
    Gaggenau EB 270/271 Electric Clock
    To set the clock:
    1. Press the clock key 3 items until the hr/min icon flash.
    2. Press the + or - key until it come to your desired time.
    3. Press the confirmation (check) key.
    You have your time.
    If not, call the service support.
    Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
    Unitec Gj 6200 Go-jak Right Hand Vehicle Dolly Caster Sold Logo
    Top Unitec Tools & Hardware - Others Experts
    John Trevino
    Are you an Unitec Tool and Hardware - Other Expert? Answer questions, earn points and help others
