Question about Simpson Esprit 750 Top Load 7.5kg
Intermittent fault top loader
My aching works perfectly one wash, the next wash won't agitate sometimes and sometimes will agitate but not spin? I leave it overnight and when I try again it all works fine sometimes? Mystery- please help! Ps it is about 13 years old but is a great machine.
  • 5 Answers
If your motor is running but the tub isn't turning it may be the part between the motor and the tub is broken and needing to be replaced (made up of two three pronged nylon parts with a thick rubber gasket with six holes that goes between , over time the prongs break and the gasket shreds), if you've done one wash after another and the first few worked but the one after didn't and on opening the lid you have the smell of burnt rubber your belt is worn, if you put your clothes in and put down the lid and nothing happens it's the lid safety switch, if you hear the hum of electricity and a clicking sound it'may be some kind of electrical issue with the solenoids ( one forum i looked at said wigwag switch) or a rapidly deteriorating motor.
Posted on Jan 31, 2015
  • painta76 Jan 31, 2015
    if your motor is running but the tub isn't turning it may be the part between the motor and the tub is broken and needing to be replaced (made up of two three pronged nylon parts with a thick rubber gasket with six holes that goes between , over time the prongs break and the gasket shreds), if you've done one wash after another and the first few worked but the one after didn't and on opening the lid you have the smell of burnt rubber your belt is worn, if you put your clothes in and put down the lid and nothing happens it's the lid safety switch, if you hear the hum of electricity and a clicking sound it'may be some kind of electrical issue with the solenoids ( one forum i looked at said wigwag switch) or a rapidly deteriorating motor.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 10 Answers
Please check the door switch or leak the door switch for test and check the capacitor motor
Posted on Mar 07, 2014
  • SANJAY HEERALALL MUSRUCK
    please check the door switch or leak the door switch for test and check the capacitor motor
4 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: Hi, I have a simpson ezyset 550 which won't stop spinning.As soon as i turn the machine on the agitator spins continually.Any ideas?
Most likely the brake on the bottom of the tub isn't engaging.
Posted on May 21, 2012
  • 713 Answers
SOURCE: My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Posted on Jul 14, 2012
  • 3 Answers
SOURCE: Simpson Ezi Sensor Front Loader keeps pausing during washes, doesn't put through the detergent.
you might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves.
You have to ask yourself what has changed,cheers.
Posted on Aug 14, 2012
Washer goes into spin cycle and will not spin out but it will agitate
Is it a front loader, top loader, what make ? Too many different types and makes to determine the fault. Have you checked to see if the cycle is on drip dry? If it is, the machine wont spin and leaves all the water in the clothes.
Sep 18, 2014 | Washing Machines
Top loader does not spin fast enough to spin dry.
possibly the clutch is slipping, i've heard you can take a #10 washer and put it in one end of your clutch spring caps and that would tighten it up
Mar 23, 2010 | Kenmore Washing Machines
Whirlpool top loader model #LA9500XTNO won't agitate
the agitator dogs need replaced sounds like.4 little comma shape pieces underneath the top of agitator
Jan 15, 2010 | Washing Machines
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
No final extract spin
P-bass, sounds like your problem is in the lid switch actuator that mounts to the bottome side of the top. I have found a bunch of these actuators just missing making the switch. Therefore the intermittent problem. Solution is to just bend it enough to insure making the switch on every closure. Catriver..post back.
Nov 29, 2006 | Whirlpool CAM2752KQ Top Load Washer
Washing Machines Logo
184 people viewed this question
Top Simpson Washing Machines Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
