Question about Samsung RS2556 Side by Side Refrigerator
How to clean drain pan in RF4287HARS - Samsung RS2556 Side by Side Refrigerator
Hhhhhhhhhjkkkkll
Posted on Feb 08, 2014
LG ptac MODEL : LP153HD3A collecting condensation water in bottom but not going to outside drain pan.
there is probably a blocked pipe or filter it will need cleaning, you may need a pump to remove the water first to get to the pipe to clean it out.
Jun 19, 2017 | LG Heating & Cooling
How do I clean the drain pan? Why in the world would anyone make a fridge that has a non-removable - and even a non-accessible drain pan? It stinks after awhile and it does need cleaned - even if jus
The "cover" is removable. Once the cover is removed, you can gain access to the pan and remove it for cleaning. The removal process can be a little tricky, but it can be done.
Dec 19, 2014 | Refrigerators
My Frigidaire refrigerator has a drain pan that is un remove able and has a bad smell how can I clean.
I appreciate your inquiry, friend!
If you would like to clean any dirt or debris from the drain pain you can use a vacuum attachment to get inside and clean any residue within the drain pan. You can also use warm water and bleach to help disinfect the drain pan prior to vacuuming it out. If that does not help you may want to consult with a professional technician for additional cleaning to be completed within your Frigidaire refrigerator. Best of luck! -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Bad transmission seal on a 2002 ford explorer
Drain the Transmission Fluid and Replace the Filter
Raise the car with ramps or a floor jack and support it with jack stands. Find the lower cover of the torque converter housing. Turn the torque converter until you find the drain plug. Place a drain pan beneath the drain hole, remove the plug and drain the fluid.
Remove the cooler lines at the transmission and flush them with compressed, low pressure air. Be careful during this step; fluid may shoot from the other cooler line.
Place a large drain pan beneath the transmission. Loosen the retaining bolts on the oil pan with a socket wrench until they are within a few turns of removal. If the seal doesn't break on its own, gently tap it with a rubber hammer. Fluid will drain from the edges of the pan.
Remove the pan retaining bolts when the fluid stops draining. There is still transmission fluid in the pan. Hold the pan carefully and drain as much as you can into the drain pan.
Scape the old gasket material from the mating surfaces on the oil pan and the transmission. Discard the old gasket. Clean the magnet in the pan. Clean the pan and the mating surfaces with a solvent and a clean, lint-free cloth. Replace the magnet and allow the pan to air dry.
Employ a socket wrench to remove the bolt that holds the filter onto the transmission. Some models may have two bolts. Pull the filter and any old seals or gaskets from the transmission. Install a new filter assembly, including any required seals or gaskets.
Put a new gasket on the oil pan and reinstall it on the transmission. Tighten the retaining bolts to 79- to 119-inch pounds with a torque wrench. Replace the cooler lines on the transmission and the drain plug on the torque converter.
OBD Tools 365 Days Shop
Sep 25, 2014 | 2002 Ford Explorer
Where is the drain located
under the freezer coil/fan assembly, typically draining out the back of the unit or into a catch pan on top of the compressor.
Jun 18, 2014 | Samsung RF4287HARS French Door...
I have a RF4287HARS -- the touch pad is flashing 1-E and nothing works but the light
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Oct 18, 2012 | Samsung RF4287HARS French Door...
How to clean the drain pan
You can access the drain pan thru the back panel on most whirlpool refrigerators. Most drain pans are diffucult to remove so clean the pan without removing it. Be sure to put a little bleach in the bottom of the pan so no mold will grow.
http://www.on-timeappliance.com/refrigeratorrepair.html
Mar 28, 2012 | Whirlpool Refrigerators
Need to change the transmission filter
get your self the right tools, the filter, transmission fluid, gasket, gasket silicon, a good wide drain pan, clean rags, some cleaner to clean out the pan like brake parts cleaner. first find the transmission pan. once located undo the bolts around the pans flange or use the drain plug to drain all the fluid. if it doesnt have a drain plug then you have to take off the pan to drain it, messy! once the pan is off you should be able to see the filter and swap it out. clean out the pan, pan magnent, put your new gasket on and use some silicon, bolt it back on. fill the trans back with new fluid. this is straight forward approach. and dont mix the oil pan with the trans pan. the oil pan is under the motor( if that helps) let me know if you need any help or you dont understand something, thanks
Nov 07, 2009 | 1998 Honda Accord
Air Handler leaking
First make sure unit is level. Drain pan may be dirty. On the rheem or Ruud unit the back of the pan gets stopped up. Ithas small holes that let the water by and they get stopped up. Now even though your drain is clean you may have a stopped up dain pan. Check this > These are problems you can take care of your self. Open up the top panel of your unit and you can look down on the drain pan. Check for dirt and stoppage near the outlet of the drain pan. You amy also have a cracked drain pan but I doubt it. Rus
Jul 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
2003 Dodge Stratus
no drain plug, no car or truck has had a drain plug for decades, reason? they want the filter changed with the fluid, so they make you pull the trans pan to drain the fluid, one very messy job.
Feb 12, 2009 | 2003 Dodge Stratus
Samsung RS2556 Side by Side Refrigerator Logo
91 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
