Question about Sewing Machines
It want run
921 want run
  • Sewing Machines Master
  • 1,388 Answers
What is your question ?
Make & Model ??
Posted on Apr 22, 2014
The machine runs when it is turned on, no stopping it
if runs without the foot pedal and internal electrical fault in the machine .dont use ..get repaired
hopefully only a faulty foot pedal
replaced or find a used pedal
Apr 29, 2016 | Sewing Machines
Juki lh-4128sf error 303
hi there,
regarding LH-4128SF JUKI double needle machine error E303, if you are using control model SC-920, SC-921 it means E303 Semicircular plate sensor
error
• Semicircular plate sensor signal cannot
be detected.
• Check w h e t h e r t h e mach ine head
corresponds with the machine type setting.
• Check whether the motor encoder connector
is disconnected.
if still error E303 coming please contact me.
best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Jul 04, 2014 | Juki Sewing Machines
Motor runs unaided, have to turn off power to stop it
Is the foot pedal not returning to the off position? Try disconnecting the foot pedal. If the machine stops running, then your problem is in the foot pedal. If it keeps running, then your control board is bad.
Mar 19, 2014 | Husqvarna Rose
Singer sewing machine 5528
No, sewing machines that use bobbins don't have an adapter like that. It would be difficult to get the bottom tension right working off the spool. The best solution is to fill several bobbins in your thread color before starting to sew. Then when you run out, swap in a new bobbin.
Some advanced machines will warn you when the bobbin runs low. (I've seen the feature on the machines with touch-screens.)
I wish that I had better news for you. A serger might be a an option to consider. They don't use a bobbin and can be used for some sewing projects. You can still run out of thread on one cone before the others run out. (Those machines use 3-4 threads at a time for the basic stitches. The knife can be lowered if you don't want to trim your fabric while stitching.)
(I've got a Singer Touch and Sew and usually don't run out of bobbin during a seam. I will swap bobbins when they are still 1/4 full at times if I get concerned about the bobbin running out.)
May 04, 2013 | Sewing Machines
Where do i put the oil in my ancient new home 921 my granddaughter is desparate to take over?
    New Home NLB Manual
  • Part 1 Pages 1-13 (~6Mb)
  • Part 2 Pages 14-25 (~5Mb)
  • Part 3 Pages 26-36 (~4Mb)
YOU CAN VIEW THE MANUAL
May 24, 2010 | Janome Sewing Machines
I have a Kenmore 385.1950280 that has been in storage for
When a sewing machine has been in storage for an extended period of time, it will need to go into the shop for service.
There could be several things that need attention and one possibility may be replacement of a circuit board.
May 01, 2010 | Sewing Machines
I have a necchi model number 537fa. the light comes on but the pedal and motor isnt running. you can manuely move the needle up and down, but the machine isnt running. could it be a belt?
If it is a belt problem, you should be able to hear the motor running. If you cant hear the motor running then it has to be the foot control or cord or possibly the motor.
Apr 20, 2010 | Necchi 3537 Mechanical Sewing Machine
Singer 258
There is no speed adjust, but 1st you must know the source of the slow down. Remove the belt from the motor pulley and run it, if it goes fast try turning the hand wheel if it is stiff the machine needs clean and oil. If it turns freely you motor may be dirty or just slow. If dirty, sometimes you can without the blet attached run it at full speed for 10 to 15 minutes. It should get faster as you run it. If not motor is weak or slow needs replace. Just replacement motor as genuine probably no longer available.
Jan 15, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Machine just stops but power is on
that is the power board (in base plate) you need a rebuilt base plate. Unless you can rebuild the power board. You can buy a rebuilt board and send your in and receive a core credit. It still will probably run $200 to get one. It will also come with a 2 year warranty.
Mar 16, 2009 | PfaFF Tiptronic 2030
Machine stopped running, its getting power but wont run.
Are you sewing or embroidering? If you are embroidering, the machine automatically stops and shows scissors in the window, for you clip the jumpstitch. Then just push the "Run/Stop" button.
Dec 13, 2008 | Husqvarna Rose
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
