Question about 1995-1996 Saab 900s Convertible Top Cover
WARNING LIGHT [!] COMES ON ALONG WITH THE (ABS) LIGHT HOWEVER, I HAVE TESTED THE BRAKES BY DRIVING FORWARD AND BACKWARDS AND BRAKING HARD!! THE BRAKES SEEMS FINE THOUGH.. WHAT'S YOUR SUGGESTIONS?
SOME1 REMOVED THE TURBO ENGINE AND PUT A REGULAR ONE IN, NOW ENGINE LIGHT STAYS ON.. IS THAT A POSSIBLE REASON?
    Sergeant:
  • 281 Answers
Use a diagnostic system to find the actual fault rather than simply remove it. Could be a ABS Sensor units on each wheel , Brake pads or an actual ABS fault. Best know exactly whats causing it first..
Posted on Dec 23, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 120 Answers
Have fault codes read but if brakes work ok could be faulty wheel speed sensor. if you have locked up one or two wheels (skidded) light will come on
Posted on Feb 21, 2014
The Brake warning light comes on. I checked the brake fluid level in master cylinder & it was okay. The fluid looked dirty. Please help
Sharon, Check to make sure emergency brake is not on and fully released, try not to drive your vehicle if the red brake warning light is on. Could have air in the system from a small crack in brake line, faulty master cylinder, faulty caliper etc. Have a good tech. check braking system, diagnose and estimate repair.
Brake Warning Light
Brake Hydraulic System Red Warning Light
What do the brake warning lights mean in my car HowStuffWorks
Aug 18, 2016 | Cars & Trucks
ABS CHECK LIGHT DOESNT COME ON WHEN YOU TURN KEY ON
1. I would not be concerned because if there was a failure in the ABS you would definitely get an ABS warning light and the ABS and most likely the stability control/traction control systems (with added warning lights) will all switch off .
2. You can test if the ABS is operational. On a very quiet damp surface, straight, wide road( with NO other cars around), apply your brakes hard from a very low speed - up to 20 mph ONLY driving in a straight line - until the car stops. The front brakes should attempt to lock up under hard braking and if the ABS is operational you will feel it kick in and the brake pedal will pulsate as the ABS constantly allows brake pressure and then releases it to prevent the wheels from locking up on the damp road. If the ABS does not kick in be ready to release the brake pedal quickly to allow the wheels to rotate so you can steer the car safely. Without the ABS the front wheels should begin to lock up on the damp road surface due to the low level of tire grip. ONLY test this at very low speed and ONLY when driving in a straight line on a straight section of wide road with no other vehicles around.
Dec 15, 2015 | Cars & Trucks
91 Buick park avenue abs light. This happened after my friend was driving down the freeway and his tire blew. Now it just blew the rubber off and he was able to drive t off the freeway on the belts. And...
ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti lock brake system light comes up when there is issue with car brake systems. It can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly. Your vehicles brake system needs inspection.
To troubleshoot these issues, I suggest you to refer the help links provided below. There are direct links with accurate solution, for these specific issues.
Click the link below and follow the procedure: ------
All types of ABS LIGHT / brake problems and repairs
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
ABS light stays on but brakes work fine?
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
VCS and ABS lights go on and off intermittently on Lexus?
http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction Control Lights stays ON dash of car?
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Battery Light and ABS Light on Dash
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
How Anti-Lock Brakes Work?
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
Brake System Troubleshooting?
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Anti-lock brake light stays on all the time?
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
2008 Toyota Highlander: ABS warning light Blinking and OBD Error codes Coming?
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
2003 Lexus ES: VSC, TRAC OFF, ABS lights ON?
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
2008 Toyota Highlander Hybrid: Warning Lights Abs, Vsc & Brake Are On?
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
ABS & Brake warning lights remains steady on dash?
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Can I drive the car without ABS fuse connected?
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
Where is ABS/TCS module located on 2005 Cadillac Deville
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
ABS motor keeps running?
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
When the car stops, abs pump turns ON?
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Replacing ABS unit on Buick Century?
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
2008 Toyota Tacoma: ABS causes Brake pedal fade?
http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
Toyota Camry: Premature ABS Actuation?
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
Feb 04, 2013 | Cars & Trucks
Why is brake warning light is on
It can be issue with master cylinder or the problem is there is still some air there in the system,that has to be bleed.Or else the parts replaced are not aligned properly/.I suggest everything back.
There are few help links mentioned below to troubleshoot the issue.
Click the link below and follow its procedure:-----
2002 Ford Windstar: Brake Warning Light ON dash?
http://schematicsdiagram.blogspot.in/2012/06/2002-ford-windstar-brake-warning-light.html
Battery and brake Warning lights on Dash
http://alltypesofpartsreplacing.blogspot.com/2012/10/battery-and-brake-warning-lights-on-dash.html
ABS & Brake warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Brake warning light comes on and car will not start intermittently? http://repairhelpcenter.blogspot.com/2011/12/brake-warning-light-comes-on-and-car.html
------------ When the car stops, abs pump turns ON? http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
----------- Where is Power Brake Booster located on 1995 Lincoln Town Car? http://howtobyme.blogspot.com/2011/12/where-is-power-brake-booster-located-on.html
----------- Sometimes ABS light comes on while Driving?
All types of brake problems and repairs http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
Brake Fade Issue? http://whoisbyme.blogspot.in/2012/07/brake-fade-issue.html
Brake System Troubleshooting? http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Car Brake lines have no pressure? http://schematicsdiagram.blogspot.com/2011/12/car-brake-lines-have-no-pressure.html
Car Brakes Dragging? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-dragging.html
Car Brakes grabbing? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-grabbing.html
Car Brakes Making Noise? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Brakes Pulling? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-pulling.html
Pulsating Brake Pedal? http://repairhelpcenter.blogspot.com/2011/12/pulsating-brake-pedal.html
Spongy brake pedal? http://repairhelpcenter.blogspot.com/2011/12/spongy-brake-pedal.html
Hard Brake Pedal? http://repairhelpcenter.blogspot.com/2011/12/hard-brake-pedal.html
Fading Sinking Brake pedal?
http://whoisbyme.blogspot.in/2012/06/fading-sinking-brake-pedal.html
Feels Like Brake pedal Pulsating http://repairhelpcenter.blogspot.in/2012/06/feels-like-brake-pedal-pulsating.html
What is Brake Drum Bar? http://repairhelpcenter.blogspot.in/2012/02/what-is-brake-drum-bar.html
Vibrations while braking On Chevrolet Van? http://technoanswers.blogspot.in/2012/04/vibrations-while-braking-on-chevrolet.html
Dragging brakes? http://howtobyme.blogspot.in/2012/03/dragging-brakes.html
Brake pedal stuck? http://howtobyme.blogspot.in/2012/03/brake-pedal-stuck.html
After replacing brake rotors and pads, brake pedal remains on floor? http://technoanswers.blogspot.in/2012/02/after-replacing-brake-rotors-and-pads.html
How to replace Brake Power Booster? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-brake-power-booster.html
1997 Chevy Tahoe Brake lights not working? http://technoanswers.blogspot.in/2012/02/1997-chevy-tahoe-brake-lights-not.html
How to service Drum brakes? http://repairhelpcenter.blogspot.in/2012/02/how-to-service-drum-brakes.html
What type of problems usually noticed on Drum brakes? http://repairhelpcenter.blogspot.in/2012/02/what-type-of-problems-usually-noticed.html
How to test Drum Brakes? http://repairhelpcenter.blogspot.in/2012/02/how-to-test-drum-brakes.html
Brake Bleeder Screw Function? http://repairhelpcenter.blogspot.in/2012/02/brake-bleeder-screw-function.html
Toyota Tundra: Parts diagram to replace Brake Drums?
http://technoanswers.blogspot.in/2012/06/toyota-tundra-parts-diagram-to-replace.html
---------- Squeak and grinding sound is heard when brakes are applied?
http://technoanswers.blogspot.in/2012/02/squeak-and-grinding-sound-is-heard-when.html
Brake Pads Inspection on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/brake-pads-inspection-on-acura-integra.html
How to remove Brake Pads on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-pads-on-acura.html
How to remove Brake Disc Rotor on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-disc-rotor-on-acura.html
Brake Caliper OVERHAUL on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/brake-caliper-overhaul-on-acura-integra.html
How to remove Brake Caliper on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-caliper-on-acura.html
How to remove Parking Brake shoes on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-parking-brake-shoes-on.html
How to remove Parking Brake Cable on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-parking-brake-cable-on.html
Brake pedal is pulsating and vibrating? http://repairhelpcenter.blogspot.com/2012/01/brake-pedal-is-pulsating-and-vibrating.html
Nov 23, 2012 | 2004 Ford Expedition
Abs light stays on and a yellow triangle warnng light
On occasion an ABS light will come on when a brake light is out. So check your brake lights first. Your ABS light is on because there is a malfunction in the ABS system. Is your brake warning light and your ABS warning light both on? This would be an indicator of a major malfunction in the ABS system. Stop driving the vehicle and fix this immemorially. If only your ABS light warning light is on this will not effect normal braking but the ABS system is disabled while the ABS warning light is on. You still need to have it repaired but you still have brakes for the moment. Now the code for this fault will be stored inside the ABS memory module. So you pinpoint this with scanner. Hope this helps
Mar 22, 2011 | Volkswagen New Passat Cars & Trucks
I start the car and the abs light goes off, then driving along the brake light and abs light comes on for no reason.
Possible faults:
Different tire rotational speed wheel to wheel.
Broken wire loom to wheel sensor.
ABS Tone ring missing teeth, broken.
Bad ABS wheel sensor.
Dirty Tone ring...... brake dust and rotor dust.
There is always a reason for warning lamps to illuminate.
Jan 15, 2011 | Dodge Ram 150 Cars & Trucks
Anti loc brake problem
when the abs light comes on that disables the abs wich frees up your brakes u will need to go to the shop and have a code pull done on your car to figure out what is setting the abs code
Mar 15, 2010 | 2000 Jeep Grand Cherokee
Both the abs and brake light is on and stays on what could be wro
Your ABS systems use a combination of electronic and hydraulic systems to modulate the brakes individually to prevent them from locking up. Antilock systems consist of wheel speed sensors, a hydraulic control unit (HCU), and an electronic control unit (ECU). Because of how complex the system is your computer does a self-test. If the check is successful, the ANTILOCK and BRAKE lights will go out within a few seconds. If one of the component of the ABS system fails to pass the test one or both lights will remain lit. One or both warning lights may also come on while driving, also indicating a problem. If just the ANTILOCK warning light comes on, some ABS component has failed, but the car still has hydraulic brakes. You or a technician will have to perform further testing to pinpoint cause and the proper repair.
Please let me know if this information is helpful. Positive feedback is appreciated. Thank You!
Mar 30, 2009 | 2004 Jeep Grand Cherokee
Abs sensor light wont go off my 2005 polo
Your ABS systems use a combination of electronic and hydraulic systems to modulate the brakes individually to prevent them from locking up. ANTILOCK systems consist of wheel speed sensors, a hydraulic control unit (HCU), and an electronic control unit (ECU). Because of how complex the system is your computer does a self-test. If the check is successful, the ANTILOCK and BRAKE lights will go out within a few seconds. If one of the component of the ABS system fails to pass one or both lights will remain lit. One or both warning lights may also come on while driving, also indicating a problem. If just the ANTILOCK warning light comes on, some ABS component has failed, but the car still has hydraulic brakes. The grinding noise could the the ABS pump or your brake pads could to worn to the metal backing and grinding against the brake rotors. I recommend a inspection soon for your safety.
Mar 04, 2009 | Audi S4 Cars & Trucks
Dash warning light
Do you mean the ABS and BRAKE lights? If so, the ABS module is bad which causes both lights to come on. After rebooting, the module gets tested and the ABS light will come on after a few seconds. If it a module problem the BRAKE light will also come on. The brakes will work normally, but will not provide the anti-lock feature.
Sep 05, 2008 | 1993 Dodge Dakota
1995-1996 Saab 900s Convertible Top Cover Logo
117 people viewed this question
Top Microbead Vehicle Parts & Accessories Experts
yobo007
yobo007
john h
Are you a Microbead Vehicle Part and Accessory Expert? Answer questions, earn points and help others
