Question about KitchenAid 32685 Mixer
Kitchenaid leaking oil
Leaking oil from the head
  • KitchenAid Master
  • 1,238 Answers
Remove the chrome drip ring that covers the outer planetary, clean it out, wipe as much oil away as possible, put the drip ring back on and carry on using it. Eventually you will need to completely dismantle the gearbox and clean out & change the grease. It's not the sort of job to look forward to. The old grease slowly breaks down over time and the oil is separating out from the grease solids. It is special food grade grease so completely harmless.
Posted on Feb 28, 2014
5 Suggested Answers
  • 547 Answers
SOURCE: My kitchenaid stand mixer is leaking oil
First off -- if it's still under warrantee, you'll want to go to kitchenaid.com and find the nearest service center. The next thing I say starts with "void the warrantee" steps. :)
It's very simple to open a stand mixer to see if you've got a simple problem or a bad one.
Unplug it.
Follow the aluminum "Kitchen Aid" band to the back of the unit, there's one main screw. Remove this, and set it aside with the band which should come right off at this point.
Now, there should be two screws on each side of the unit where the band used to be. Remove each of these. They're all identical, so no worries if you mix them up.
Now you can lift the top off of the unit and see inside. The motor is at the back of the unit, the gear box at the front is where the oil is coming from. Try (GENTLY) to tighten the screws that hold the gearbox together. With a little luck, the gearbox screws had come loose and it was oozing oil out through the seals. If they're all firm, then you've got more serious problems and you'll want to find a service center for it.
Posted on Aug 03, 2009
  • 1214 Answers
SOURCE: kitchenaide mixer...leaking oil underside of
KitchenAid uses a grease in the transmission, and anything that may drip from the transmission will be very low in quantity.
If you want to disassemble, clean, and re-grease to remove the liquid part that has weeped out of the existing grease, do so with a food safe grease.
Posted on Dec 21, 2009
  • 130 Answers
SOURCE: My kitchenAid stand mixer is leaking oil. How do I
referring to:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%204176924.pdf
You can see that there are 5 screws holding the upper and lower gearcase together. They pinch the gasket number 26 together and prevent the oil and grease from leaking. Remove the chrome ring by prying gently around the ring. You will see the 5 screw heads. Tighten them and the leaking will stop.
If it still leaks then you may have to replace the fiber washers number 29 which will involve disassembling the lower gear case.
Posted on Mar 31, 2010
  • 130 Answers
SOURCE: kitchenaid mixer leaking oil from head.how to fix
It's not oil, it's grease. Here is a very detailed article on how to add grease to the mixer. After you have added some new grease and tightened the screws it will stop leaking. The temporary fix is to simply remove the chrome ring as is done in the picture on the attached link, clean out the oil and stick it back on till it fills up again. It is called a drip ring for the reason that it catches the oil component of the grease which drips from the gasket when the screws loosen:
http://www.artisanbreadbaking.com/discussions/kitchen-aid.htm
Posted on Jan 21, 2011
Kitchenaid mixer leaking oil from head.how to fix it.
Jan 09, 2011 | KitchenAid K45SS Classic Stand Mixer
OIL IS LEAKING OUT OF THE HEAD INTO FOOD BOWL. KITCHENAID SAID OK, FOOD GRADE OIL! I DON'T LIKE BLACK OILY CAKE OR COOKIES? CAN YOU HELP US TO FIX OURSELVES.
Kitchenaid says to run the machine on 'high' long enough to heat the gearbox well and then turn the machine upside down and let it cool.
What happens is when you don't use your mixer a lot the grease in the gearbox will separate into oil and thicker grease. Warming it and turning it upside down is supposed to mix all the grease together again and allow it to flow to the top of the gearbox.
Give it a try, check back if you get no satisfaction and we'll get you started on changing your grease.
lp
Jan 01, 2011 | KitchenAid KSM103 Professional 5 Series...
Leaking oil around head
These mixers are filled with grease at the manufacturer, and the heat may have broken down the grease a bit and looking like oil. Without seeing the problem, or knowing the exact location of the leak, I would say that a gasket or "O" ring has failed. Contact Kitchenaid for a gasket/seal rebuild kit. If it is new(er), It may be covered under warranty.
Dec 22, 2010 | KitchenAid KSM103 Professional 5 Series...
Oil leaking
the transmission gasket and "O":ring is bad , they are available from easy appliance parts.com,kitchenaid used to be "Hobart",dont call them because they dont have kitchenaid parts or service anymore
Dec 18, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
I was mixing a cheesecake with my stand mixer when I began to notice that the color of the cheesecake batter had changed. It looks like a metallic color. What happened
Perhaps oil is leaking from the gear head?? Check the shaft and see if there is oil or grease leaking from where that shaft enters the machine.
Apr 03, 2010 | KitchenAid Food Mixers
referring to:
Mar 30, 2010 | KitchenAid KSM103 Professional 5 Series...
When my 85 year old mother, who no longer does much cooking or baking, heard that my trusty KitchenAid stand mixer finally gave up the ghost after 25 years of great service, she sent me her KitchenAid...
The mixer normally has it's gearbox packed with (quite thick) grease. Over time it can heat up and become more fluid and leak out. I would guess that the amount of oil you saw would not be a problem to loose. If it were mine, I would use it and not worry. If you do feel you need to check, the grease is packed in the front of the head. You will need to remove the head, split it (you will need to remove the band and planetary) and then you can see the gears.
Jan 28, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Mixer leaking oil
Hi Tim. Don't try to pour anything into the side openings, these openings are for the electrical brushes. You didn't state what model you have so my help is limited. Goto www.kitchenaid.com and click on the customer care tab. Enter your mixer's model# into the search window. Look for a parts catalog for your mixer. If there is one, download it.
Your mixer uses grease to lubricate it. If it's leaking oil, the oil and old grease must be removed and replaced. Chevron FM ALC EP-2 is a "Food Grade" grease, use it to replace the old stuff. The transmission housing and Planetary assembly will have to be removed to accomplish this. It's a messy, but necessary task. Once completed, run the mixer for a few minutes each week to keep the oil suspended in the grease, this will extend the life of the new lube. Good luck!
If this solution has assisted you please rate it. ricardok45.
Mar 28, 2009 | KitchenAid Food Mixers
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
Leaking oil
thats the planetary seal thats leaking.the seal is cheap its the labor that may be costly.is it just a nuisance leak or a lot?you dont want any oil to get in your mix.
Aug 16, 2007 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid 32685 Mixer Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
