Sec 1.329 degree angle - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
About 1.000269 .
Calculate it as 1/cos(1.329).
If you're asking how to calculate this on a particular calculator, what make and model?
Posted on Feb 08, 2014
What's the value of y
67 degrees. There are a number of methods to solve this.
One method.
Opposite angle of 67 degrees will be 67 degrees.
Angle above this will be 180 - 67 degrees, or 113 degrees.
Angle above this, y, will be 180 - 113 degrees, because angles of a straight line must add to 180. Result is 67 degrees.
Good luck,
Paul
Sep 12, 2016 | Office Equipment & Supplies
I want to know the torque opel corsa lite 1.4 cylinder head bolts.
stage 1 ... 25 Nm (18 lb ft)
stage 2 ... angle tighten + 90 degrees
stage 3 ... angle tighten + 90 degrees
stage 4 ... angle tighten + 90 degrees
stage 5 ... angle tighten + 45 degrees
Feb 26, 2015 | Opel Corsa Cars & Trucks
If an angle of a parallelogram is one- third of its adjacent angle, find the angle of the parallelogram
Since the two adjacent angles of a parallelogram must add to 180 degrees, the two angles have to be 45 and 135 degrees respectively.
Nov 02, 2012 | Office Equipment & Supplies
A scalene triangle has side measuremnts a=43, b=55, c=30 . Angle a plus Angle b must equal 43. Angle b plus Angle c must equal 55. Angle c plus Angle a must equal 30.
Answer: angle a=9 degree angle b=34 degree angle c=21 degree Explanation: we have, a+b=43............(1) c+b=55..............(2) c+a=30..............(3) from (3) we get, c=30-a...........(4) substituting value of c from (4) in (2) we get, 30-a+b=55.........(5) a+b=43..........(1) (5)-(1) give 30-2a=12 30-12=2a a=18/2=9 degree giving value of 'a' in (1) 9+b=43 b=34 degree similarly giving value of 'a' in (3) c+9=30 c=21 degree
Oct 14, 2012 | TOPICS Entertainment Snap! Geometry...
How can you classify a triangle according to it angle? is there a formula for it
Well, there is classification by sides, equilateral with 3 equal sides, Isosceles with two equal sides, and scalene with no equal sides, but you talk about angles, but I wanted to point out equilaterals have 3 equal angles, isoceles have 2 equal angles and scalene have no equal angles.
So, now we talk about angles: a Right trianlge has one angle that is 90 degrees, an Obtuse triangle has one angle greater than 90 degrees, and an Acute has no angles over 90 degrees.
Thus, it is possible to have a (scalene or isoceles) AND (acute, obtuse, or right) triangle, but never an equilateral AND (obtuse or right). The angles can't be equal and 90+ degrees if all three must equal 180 degrees.
Oct 06, 2012 | Mathsoft StudyWorks! Middle School Deluxe...
Ok so my math hw only gave me the degree, minute, sec format of the angle. How do i input it in the fx 155 es to work out and find the rest of the angles, sides, etc?
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
This showed you how to enter angles in DMS or DD. For the rest 'find the angles, etc.' you should refer to your trigonometry manual: You have the definitions of the trigonometric ratios, the sine law, the cosine law to resolve triangles.
Feb 24, 2011 | Casio FX-115ES Scientific Calculator
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
Agasta ant starts at one edge of a placemant, 29.6 cm wide. she travels at 1.40 cm/sec at 52.o degree from one edge. how long will it take her to get across the width?
draw a right triangle. The bottom of the triangle is 29.6 cm and the angle is 52 degrees (from the other edge). note: triangle not to scale.
|52 \
|_____38\ 52|
29.6
Therefore the inside of the angle is 38 (90-52) and the opp angle is also 52 (90-38)
sine = opp / hyp therefore hyp = opp / sine
length of hypotenuse is: 29.6 * sine 52 deg.
therefore the length of the hypotenuse is 23.32511 cm. the ant travels 1.4 cm / sec so the ant travels to the other edge in 16.66 seconds.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
HOW DO YOU USE THE DEGREES MINUTE SECONDS FUNCTION
To convert an angle from degrees (decimal degrees) to the sexagesimal notation (deg, min, seconds) use the key [DMS] the one between [(-) and [hyp].
Everytime you press the key, the displayed result is cast in the other form
EX; 12.58 [DMS] gives 12 deg 34 min 48 sec.
Suggestion: If you are doing many calculations with the sexagesimal format, use the decimal degree format, and only when you find the final result do you convert it to DMS.
Hope it helps.
Sep 30, 2009 | Casio FX-115ES Scientific Calculator
Can't find angle measurements function on casio fx 9750
In [RUN], screen press [OPTN][F6:->][F5:ANGL] [EXE].
Exemple 18.53 deg
18.58 [F1 Degree symbol] [EXE] shows 18.58. At the bottom of the screen appears a new option DMS with a left arrow. By pressing the corresponding key [F5], the screen displays 18 deg 34 min and 48 secs. To enter an angle in DMS, exemple the one above, you procedd as follows:
18[F4]34[F4] 48 [F4] [EXE] displays 18.58
Hope it helps.
Aug 20, 2009 | Casio FX-9750GPlus Calculator
16 people viewed this question
jasbo
jasbo
