Question about Maytag Maxima EcoConserve Series MED6000X 27" Electric Steam Dryer with 7.4 cu. ft. Capacity, 8
Maytag maxima dryer steam valve will not stop spraying water
2 Suggested Answers
  • 7 Answers
SOURCE: maytag dryer model mde6400ayw
Sounds like you might need a new belt
Posted on May 10, 2012
Maytag maxima XL washer is not spinning out the water how can I fix this?
Pump, filter or drainage problem.
Check there is nothing jammed in the pump or the filter.
Make sure the drain is not blocked or running "up hill"
Mar 14, 2016 | Maytag MHW6000AW Maxima XL 27" White Front...
Frigidaire fase7074la0 dryer will not stop misting. As soon as the water line is connected it sprays water all over the inside of the drum even when the dryer is off. Please help!!!
You water valve is malfunctioning. Remember the dryer is plugged into the wall, which gives it power, so the valve solenoid will open the valve and hence spray the water. Please hire a professional to replace the valve.
Oct 25, 2015 | Frigidaire Dryers
I ran the perfect steam option on my Electrolux dryer and ran the program but now the water continues to spray inside the dryer. How do I shut it off?
Thank you for your post, Travis!
I see that you are having a continuous spray of water inside of your Electrolux dryer from the Perfect Steam option. It appears that you could have an issue with your water valve or control panel. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for roughly ten minutes. If this does not correct your issue I would suggest having a professional technician for proper diagnosis and repair. This will help you avoid any future issues. Best of luck! -Matt
Mar 15, 2015 | Electrolux Dryers
Ma secheuse maytag ne fait pas de vapeur
translation
My Maytag dryer does not make steam
Permalink
When I put on this function makes no steam
questions
1. is there water flowing to the dryer?
2. Is the dryer connected to a water source
3. Are there any clogged water filters or screens in the back of the Dryer.
4. If there are no water problems, then I would check for thermal fuses or defective control boards.
Oct 30, 2014 | Maytag Dryer. Bravos XL 7.3 cu. ft....
Whirlpool duet dryer stuck on steam cycle
one trick to stop the steam is to remove the water hose connected to the dryer
Nov 20, 2013 | Whirlpool WED9500T Electric Dryer
Steam valve won't shut off
If the water sprays after the dry cycle has completed and you have to physically have to turn the tap off, then you need to replace the water inlet valve on the unit. Here is a link to the valve.
Oct 20, 2012 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
Maytag Maxima EcoConserve Series MED6000X 27" Electric Steam Dryer with 7.4 cu. ft. Capacity, 8 Logo
189 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
