Question about RCA DRC8300N DVD Recorder/VCR
RCA DRC8320 DVDrecorder/VCR combo problem
We had a disc get stuck--we turned the power off and on--nothing--then unplugged the AC cord--thought we had it because theDVD started playing but then the words INTERFACE ERROR--Turn off power   came up.  We still could not remove the disc before this message appeared--went to the troubleshooting part of the manual--where the player locks up (which it did do after teh interface message) and it told us to go to the general menu to reset the DVD/VCR and highlight and select USER DEFAULT ....there was no such selection there.What now???
  • Anonymous Dec 24, 2007
    we had a disc get stuck--we turned the power off and on--nothing--then unplugged the AC cord--thought we had it because theDVD started playing but then the words INTERFACE ERROR--Turn off power came up. We still could not remove the disc before this message appeared--went to the troubleshooting part of the manual--where the player locks up (which it did do after teh interface message) and it told us to go to the general menu to reset the DVD/VCR and highlight and select USER DEFAULT ....there was no such selection there.What now???
C13295
  • 128 Answers
SOURCE: dvdrecorder combo VCR model DMR-ES45V, LJBED01124 R
Take it back to radio chack, and show them. They should tell you your options on what to do. :)
Posted on Jan 20, 2008
SOURCE: interface error
Throw it away and buy a new one. Less frustration.
Posted on Jan 25, 2008
SOURCE: Dvd Recorder+VCR Combo Model#DRC8320N
-----Original Message-----
From: RCA Support [mailto:rcasupport@1800customersupport.com]
Sent: Monday, May 12, 2008 2:52 PM
Subject: RE: DVD stopped playing
Let the unit sit with the AC power cord out of the wall for a couple of hours. Then hit the power button 10-15 times (with the AC power cord still out of the wall socket!) and then try again. If you continue to have problems unfortunately it sounds as though it is within the electrical assembly. It is hard to say exactly what caused it or exactly what the problem with the circuits are.
Posted on May 14, 2008
GSAN
  • 106 Answers
SOURCE: rca dvd\vcr locked on hello
The hello issue is most likely a faulty DVD-RW. These go out on thse models more than usual. Reset is a combination of 2 buttons. Press and hold the play and disk tray open or the power and play ( i forgot the exact sequence but you get my drift, press 2 buttons for about 10 seconds). You can also update the firmware...or atleast could before from RCA.COM but they no longer support this midel. I do have the software update on CD but it won't do any good on Hello issue. If worst comes to worst, open the player up and replace the DVD-RW drive.
Posted on Jun 19, 2008
SOURCE: rca dvd/vcr dual recorder, wont play dvd
My VCR/DVD Model # DRC6200N is not working. I can hear the DVD but no picture, do you have any suggestion what is wrong?
Posted on Jul 17, 2008
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Where is the fuse on the RCA DVD+VCR Combo (DRC8320N Model)? Please do not be too technical.
UNPLUG the unit... put it in front of you,, unscrew the 2 screws on the side and 4-6 that hold the COVER only... take cover off.. the fuse is on the top left side.. check it if no good replace it. Thats it.. oh put the cover back on .
Jun 07, 2009 | RCA DRC8320 DVD Recorder/VCR
Problem with DVD/VCR RCA DRC8335
More than likely the DVD drive in your unit is bad.
Feb 27, 2009 | RCA DRC8320 DVD Recorder/VCR
My dvd/vcr does not display video, you can only hear the audio.
on the combo device like you have the dvd can be connected thru the component but the vcr needs to use any of the other output connections that you might have.
Jan 09, 2009 | RCA DRC8320 DVD Recorder/VCR
RCA DVD/VCR model DRC8320
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
Power problem.
1. Make sure the AC outlet is good.
2. Make sure there is no damage to the AC line cord.
3. Look to see if there is a fuse at the rear of the unit. It's usually located inside a black circular housing with a screw off cap that says "fuse".
If not, unplug the unit and remove the outside cover. Look for a blown fuse on the motherboard or power supply. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged.
Please let me know if I can be of further assistance to you.
- Jim
Mar 20, 2008 | RCA DRC8320 DVD Recorder/VCR
Interface error
Jan 04, 2008 | Sony RDR-VX525 DVD Recorder/VCR
RCA DRC8300N DVD Recorder/VCR Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
