Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid superba KSRP22FNBT00 I CAN'T GET THE REPLACEMENT WATER FILTER TO TURN AND SEAL
  • 1314 Answers
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
Posted on May 13, 2008
philbran
  • 242 Answers
SOURCE: in door water dispenser leaking on my kitchenaid superba
Hello , I can help , If water is coming out of the tube in the door the only problem you could have is the water inlet valve not sealing all the way causing water to seep out and leak, this is normal to happen over time and the only way to fix it without turning your water off to the unit is to replace the water inlet valve , it is not extremly difficult and will cost about 50 dollars. it is the part that you connect your water line to in the lower rear of the unit. This should get you going if you have any questions just ask. tell me how it works out.
Phil
Posted on Jan 07, 2009
ginko
  • 19396 Answers
SOURCE: Kitchenaid Icemaker leaking in big drips on front of freezer bins
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
aasc
  • 1606 Answers
SOURCE: how do you take out and change the water filter on
At the bottom of refrig , on the toe plate , press the button on the left kinda hard , and the filter should pop out .
Posted on Sep 24, 2009
Testimonial: "thanks for the help. "
SOURCE: KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
Manufacturer recall on door because the wiring was cut by use. Replaced free by certified repairman.
Posted on Sep 20, 2010
Water filter on kitchenaid superba not snapping into place
The entire filter with cap attachment must be in place or the water will not be filtered.
Feb 27, 2014 | KitchenAid Superba Architect KSCS25INSS...
What type if filter do I for kitchenaid superba ksrb25fhss01?
The refrigerator water filter for the kitchenaid superba ksrb25fhss01 is part number 4396508. If you order it from Sears Parts Direct, it's $45. See: http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KSRB25FHSS01/0593/0165000/O2029608/00002 . It's available from other sources for less (including Amazon: http://www.amazon.com/Whirlpool-4396508-KitchenAid-Maytag-Refrigerator/dp/B0009793KC .)
I hope this helps.
Jun 24, 2012 | KitchenAid Refrigerators
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Jul 22, 2010 | KitchenAid Superba Architect KSCS25IN Side...
How to change the water filter on my Kitchenaid Superba fridge?
The details are on page 6 of this manual or I have pasted them below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202306982.pdf
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the protective covers from the O-rings.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See “Water and Ice Dispensers.”
Apr 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
The water dispenser stopped working but the ice dispenser still works just fine on my KitchenAid Superba KSRG25QFB side by side
First Question, Have you changed the water filter???needs to be done every 6months. dirty water filter can keep water from flowing through system......also nasty to drink.........
Jan 09, 2010 | KitchenAid Superba KSRG25FK Side by Side...
How do I replace kitchenaid superba KSCS25FKSS00 water filter. When I try to turn counterclockwise with my hand it doesnt budge? I have never done it in 5 years
Here are some instructions for you.. it is important to press the ejection button and pull the filter straight out before turning counter clockwise..
1.Press the eject button to release the filter from the base grille. 2. Pull the filter straight out.
3.Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter. 4.Align the ridge on the cap with the arrow on the new filter and turn the cap until it snaps into place. NOTE: You can run the dispenser without a filter. Your water will not be filtered. Simply insert the cap all of the way into the base grille and rotate the cap until it is firmly in place. 5. Remove the protective covers from the O-rings. 6.Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
I hope this information helps you with your filter. They suggest you replace the filter every 6 months. It could help the quality of your water and if you make a lot of ice..
Nov 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
How do you replace the water filter on a Kitchenaid Superba refrigerator. I can find the filter.
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Oct 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water is dispening to slow
check for proper flow and pressure on water supply line
Feb 23, 2009 | KitchenAid Superba KSCS23IN Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
29 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
