Question about Kenwood Radio Communications
No signal on RX,only noice , TH22-AT
Receiver no signal, only noice, TX work and all funcktion.
    Scholar:
  • 154 Answers
You have the 'squawk' turned up too far. This will be a standard dial or a small slotted dial inset in the body. Turn counter clockwise to lower the resonance effect. This should not be confused with a transponder squawk code, which is a different thing totally. If your model is more up to date then the squawk function will be automatic and toy will need to reset it by firstly switching the unit off, then hold the transmit button and the volume UP button while powering the unit on. This will reset all the functions of the unit back to the factory default. If you still have problems then the unit is faulty and needs repair or replacement.
Posted on Jun 15, 2014
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: cobra 29ltd classic : no rx / tx
D23 is the reverse protection diode and it shorting is the primary reason your fuse blew. As you posted, power was applied in reverse, hence other components would also fail. Pls check:
1. D22 - 9.1V Zener Diode
2. TR23 (2SC1096) 9 Volts regulator
3. D19 - 5.1 Zener Diode
4. IC4 (TA7222) - Audio Amp
5. TR14 (2SC2029B/10) - Finals
6. TR15 (2SC2028B/20) - Driver
7. Most capacitors over 220uF (like C123, C114 & C112)
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 04, 2008
What is the difference between GPON B+ and C+ GPON transceiver?
B+ Module C+ Module Type One-fiber bi-directional optical module, class B+ One-fiber bi-directional optical module, class C+ Operating Wavelength Tx: 1490 nm
Rx: 1310 nm Tx: 1490 nm
Rx: 1310 nm Encapsulation Type SFP SFP Port Rate Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Minimum Output Optical Power 1.50 dBm 3.00 dBm Maximum Output Optical Power 5.00 dBm 7.00 dBm Maximum Receiver Sensitivity -28.00 dBm -32.00 dBm Optical Connector Type SC/PC SC/PC Optical Fiber Type Single-mode Single-mode Reach 20.00 km 20.00 km Overload Optical Power -8.0 dBm -12.0 dBm Extinction Ratio Huawei GPBD Board Thunder link com
Nov 02, 2016 | Computers & Internet
When I press the speak button, It display's TX and the other radio displays RX
tx is the word for transmit and rx is for receive
if you press the talk button, the unit goes into transmit mode and is received in the receiver of the other unit/s
now that your statement has been clarified what was the question?
Feb 26, 2016 | Radio Communications
What does TX and RX mean on my AWA-5112 marine radio?
tx means transmitter, & rx means receiver
Jan 19, 2012 | Radio Communications
What do you mean by rx and tx from china mobile
rx = recieve a signal tx = transmitt a signal
Jan 25, 2010 | Cell Phones
Please send me Canon Ir all model Error code. How can solve it?
Error codes for iR2016i,2020i for other machines codes you need to get the specific manual, these manuals can be downloaded from Ebay, look for user ID ultimate_sacrifice A seller on Ebay.
No. Tx/Rx Description
##0100 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0101 [Tx/Rx] the modem speed does not match that of the other party.
##0102 [Tx] at time of transmission, fall-back cannot be used.
##0103 [Rx] at time of reception, EOL cannot be detected for 5 sec (15 sec if CBT).
##0104 [Tx] at time of transmission, RTN or PIN is received.
##0106 [Rx] at time of reception, the procedural signal is received for 6 sec while in wait for the
signal.
##0107 [Rx] at time of reception, the transmitting party cannot use fall-back.
##0109 [Tx] at time of transmission, a signal other than DIS, DTC, FTT, CFR, or CRP is
received, and the procedural signal has been sent more than specified.
##0111 [Tx/Rx] memory error has occurred.
##0114 [Rx] at time of reception, RTN is transmitted.
##0200 [Rx] at time of reception, no image carrier is detected for 5 sec.
##0201 [Tx/Rx] DCN is received outside the normal parity procedure.
##0220 [Tx/Rx] system error (main program out of control) has occurred.
##0232 [Tx] encoding error has occurred.
##0237 [Rx] decoding error has occurred.
##0261 [Tx/Rx] system error has occurred.
##0280 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0281 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0282 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0283 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0284 [Tx] at time of transmission, DCN is received after transmission of TCF.
##0285 [Tx] at time of transmission, DCN is received after transmission of EOP.
##0286 [Tx] at time of transmission, DCN is received after transmission of EOM.
##0287 [Tx] at time of transmission DCN is received after transmission of MPS.
##0288 [Tx] after transmission of EOP, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0289 [Tx] after transmission of EOM, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0290 [Tx] after transmission of MPS, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0670 [Tx] at time of V.8 late start, the V.8 ability of DIS front the receiving party is expected
to be detected, and the CI signal is expected to be transmitted in response; however,
the procedure fails to advance, and the line is released because of T1 time-out.
##0671 [Rx] at time of V.8 arrival, procedure fails to move to phase 2 after detection of CM
signal from caller, causing T1 time-out and releasing line
##0672 [Tx] at time of V.34 transmission, a shift in procedure from phase 2 to phase 3 and
thereafter stops, causing the machine to release the line and suffer T1 timeout.
Dec 12, 2009 | Office Equipment & Supplies
Tx and rx
can you clarifiy? please
Oct 25, 2009 | Midland 4001 40-Channels Base CB Radio
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
Changed battery and still does not work - hear pinging in computer
There are buttons on the transmitter/receiver and the mouse(small red on bottom). Turn off the mouse. Plug in the USB Tx/Rx and hold down the button. Then press the red button on the mouse and hold for one second. Do this until the rapidly flashing light on the Tx/Rx slows down. The unit's frequencies are then encoded/decode and can communicate.
Jun 13, 2009 | Targus PAWM001U Mouse
Radio Communications Logo
56 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
