Question about Bullz Audio Capacitor 2.2 Farad Power Amp Kit 4 Gauge Wi
Need instalation instructons for a bullz audio power capacitor 2.2 farad 2200 watt low esr 200cv
I need instalation instructions or programing process for this power capacitor
Need adjustment instructions for car audio capacitors
You can not adjust capacitors, they are a fixed value device.
Sep 02, 2013 | Xscorpion NEW Bullz Audio BCAP 4.4 Farad...
I have a new 10 farad cappacitor and a 2600 watt amp and my lights still dim why?
You are draining your battery regardless of the cap. You are probably going to need a bigger alternator, and an extra battery to run your setup.
Sep 19, 2010 | Boss Audio CAP10 10 Farad Digital...
How to charge the lanzar 1.6 capacitor
typically you can charge or discharge large capacitors using a resistor. Not just any resistor will do. You will need one with high-enough resistance and wattage ratings or you'll burn up the resistor. I would use a 1/2W, 4.7kohm or a 1W, 1kohm. These are minimum values and you can use a slightly higher resistance but it will take longer to charge/discharge.
To charge, connect the positive terminal, then hold the resistor between the ground wire and the ground terminal for 30-60 seconds. Then connect the ground terminal. To discharge, disconnect both terminals, then hold the resistor across the terminals (do not reconnect terminals without charging). In either case, you can use your fingers to hold the resistor as DC will not shock you, but if the resistor gets hot it will burn you. I use needle-nose pliers to hold the resistor (just in case). Just be careful not to short the resistor leads or terminals with the pliers.
Explanation: For a standard cap 1 - 2 farads, the discharge voltage is up to 20V so we'll figure off of that. I would use at least a 1/2 watt resistor, a 1 watt could be safer, depending on the value. For a 1 watt, the current can be no more than .05A at 20V. For a 1/2 watt, only .025A. Let's say .04A and .02A, respectively. Ohms = Volts / Amps, so 20V / .04A gives us 500ohms. Double that to be safe (avoid overheating) and it's 1kohm. Same process for the 1/2W version will be 2kohm, but it's not as hefty, so I would recommend 4.7kohm.
Jun 29, 2010 | Lanzar 16 Farad Power Capacitor LQ16CAP
Am not getting the full power to my amp just wanna know why
i have always heard that for ever 2000 watts you need at least 1 farad of capacitor. also once you hit more on the lines of 3000 or more you need a bigger alternator or battery and a capacitor is a must to keeping your amp running cooler and cleaner by keeping voltage drops to a minimum.
Apr 14, 2010 | Stingpro ST444 1850 Watts Complete...
Hey i had 2 car amps +for 4 speakers(140W maxi) and a sub 12inch
1 cap, either .5, 1 or 1.5 farad will be fine. they make 5 10 and 20 farad that cost way more than u need to spend for 400 watts RMS. i like the rockford fosgates, you can get a low cost Tsunami, just make sure you follow the charging instructions.
Oct 20, 2009 | Car Audio & Video
Need diagram to install capacitor
Hello tommysgirl,
Here's a link to Car Audio Help's cap wiring diagram.
Hope this helps.
Aug 27, 2009 | Power Acoustik 1.2 Farad Capacitor Pcnc...
Capacitor
You usually don't need a capacitor because your car can keep up with the power requirements, especially since your system isnt too big (no offense). But if you wanted to get one, i would only get a 1/2 or 1 farad cap.
Jul 26, 2009 | Legacy LA588 Car Amp
Will a JL audio 1000/1 amp run a orion HCCA 15
Hello evopower,
The JL 1000/1 will power the Orion HCCA OK.
It is stable only to 1.5 ohms so your best choice would be the 15.4 with dual 4ohm voice coils. In parallel, this would offer a 2ohm impedance. The 15.2 could only be wired for either a 1ohm load (too low) or a 4ohm load (less power).
Hope this helps.
May 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Boss 3.5s capacitor?
something in the order of 120 ohms. If you use a 1/4 watt size it will get extremely hot.
May 15, 2009 | Boss AUDIO CAP2C 2 FARAD CAPACITOR DIGITAL...
Bullz Audio Capacitor 2.2 Farad Power Amp Kit 4 Gauge Wi Logo
227 people viewed this question
Top Bullz Audio Electronics - Others Experts
Are you a Bullz Audio Electronics - Other Expert? Answer questions, earn points and help others
