Question about HP 517034-001 - Slimline S5000 S5300 System Case Fan
Broken sata connecter
Can i use a different port
    Master:
  • 680 Answers
If you mean on the motherboard then yes. if you can find an empty one.
Terry
Posted on Feb 05, 2015
HD322HJ, 320GB, 7200RPM/16M SATA Hard Drive is not detecting in Bios My system configuration is quad-core 9650 processor, 9400gt nvidia graphics card, 2gb ram kingstone,M2N68AM+ motherboard pls give me...
Did you try to connect it to another PC, different port in the same PC? Are all SATA ports enabled on the motherboard? It may be problem with fault motherboard, sata/power cables or the hard drive itself.
If it's a second drive for you can you try connecting it through USB bridge to see will it work that way.
Aug 20, 2013 | Samsung HD322HJ 320GB 7200RPM 3.5" SATA...
WD1001fals as slave
SATA Hard Disk as a Slave b> An SATA hard drive is an internal hard drive that connects to your computer's motherboard. It is even possible to connect multiple drives to the same computer; however, only one drive can be the master hard drive; the other(s) must be slave drives. This is because the master drive has the operating system installed and must be used to boot up the system. When installing a new SATA hard drive onto your computer, you must set it as a slave.
Power down your computer and disconnect the cables. Remove the Phillips screws from the exterior of the computer case and slide the case open to expose the interior of your computer. Identify the hard drive at the front of your computer, then slide the new SATA drive in underneath. Insert the smaller power cable into the power port on the side of the SATA hard drive. Follow the power cable running out of the current hard drive and insert it next to it on the motherboard. Pull out the ribbon cable, which has three different connection ports: one on each end of the cable and one in the middle. The connection port on the middle inserts into the slave drive and is slightly different than the other two ends (the pins built into the port are in different locations than the other ends). Insert the middle connection port into the ribbon port on the back end of the SATA hard drive. Plug one of the opposite ends of the cable (doesn't matter which one) into the SATA connection port on the motherboard (your current hard drive is inserted here). Once connected, this completes your slave drive connection. Second SATA 2 Hard Drive as a Slave b> Installing a second hard drive in your desktop PC or notebook is an option used to increase hard disk space without losing or transferring the data from your original hard drive. Using this method not only increases hard disk space, it also increases the virtual memory space for the Windows operating system, increasing operational efficiency. One of the ways in which a BIOS can recognize the second hard drive is to boot it as a slave drive, with the primary hard drive booted as a master drive.
Turn the PC off and remove the desktop chassis. Refer to the pin connector diagram. This is displayed on the sticker, on top of the hard drive, for the position of the slave pin. Place the plastic connector on the slave pin as detailed on the diagram. Connect the hard drive to the power and IDE/SATA cable. Ensure the other ends are connected to the motherboard. Use the screws to mount the drive. Replace the desktop chassis. Turn on the PC. Enter the BIOS, by default this can be done by pressing F2. If this does not work consult your motherboard manual. In the BIOS, press right until the boot device tab is highlighted. Set the slave drive to boot following the primary drive. Read the bottom line and use the relevant key to save the settings. Restart the PC.
Hope it helps.
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/ Installing a hard drive.
Jan 24, 2013 | Western Digital WD Caviar Black WD1001FALS...
Doesn't show connected with the PC. kindly give a details customer care address of Kolkata, West Bengal India immediately. i have three 250 GB SATA Hitachi Hard Disk
are you using the correct SATA port for this if not then try a different port but i have never heard of this happening but try some different ports and see if that helps
Jan 03, 2011 | Hitachi Computers & Internet
My sata has been removed fram my motherboard, only the yellow colour plastic, but the seven pins are their in a motherboard so give me the solution, please fast
Hi shaqi0078666
Meaning now,
pin SATA on SATA port for SATA ports left and you were broken.
what about the other SATA port?
if there is, use the other SATA port for your SATA and SATA cut the pin is left, do not let it come into contact with another pin.
If you do not have SATA ports. you must try to improve by changing the SATA port on the sata port. or you can use sata to ide converter to install a SATA hard disk to your motherboard..
thanks&regards
Dec 15, 2010 | Gigabyte GA-M61PME-S2 Motherboard, AM2,...
My desktop all of a sudden cannot detect the sata hdd. earlier it was working fine. Now it is not detecting the hdd and the red led is also blinking
First make sure there are no loose cabling/glitches.
Does the drive spin up?
- check power cable
1. connect the drive to another port
- port may be broken
2. connect another drive instead
- drive may be broken
Aug 18, 2010 | Computers & Internet
Sata dvd rom cause the computer to crash, is it because its plug in to the wrong plug in on the board or the sata on the motherboard isnt the right one im trying to install a sata rom on a gateway 5474,...
on pata ,flate data cable use in long connerter . on sata cable we use thin and flatcable join in n small squire port. some bord have both type port we can use diffrent port in same time . but port should be good. i think there no chance to join different connecter joining. we look seriously. in any coonater we saw cuttin g shape or male female shape. power cable of smps which join in hdd/cd room may be lose when we join any part it can be short so connecting any cable before we do switch off or pullout powercable.
Nov 05, 2009 | SuperMicro LiteOn SSC-2485K - Disk drive -...
Connection of DVD writer having SATA cable
The blue ports on this motherboard are SATA ports.
This is a SATA cable:
Mar 30, 2009 | Intel Motherboard
RAID 0 on Asus motherboard
Hi macjax,
I agree Asus wasn't using their noodle when they came up with that one. With the JMicron Controller your sort of forced to use an external for raid. But getting another Raid controller is simple. I like High Point Rocket Raid, and it's simple to install and setup. HERE's a link to there site. The main reason that they should be using an external is for hotswapability. But for some reason JMicron wanted to allow for more drives. Can you image having for external drives!!! Crazy.
Anyway, if you get another controller card, you'll go through needing to load the drivers and change Bios to accept them, and at the same time you can disconnect the JMicron raid. As far as speed is concerned, you're still on the SATA platform, I find no difference on speed unless you have two drives of different sizes.
Good Luck
Mark
Please provide a rating based on this solution.
Thanks
Mar 28, 2009 | ASUS Computers & Internet
HP 517034-001 - Slimline S5000 S5300 System Case Fan Logo
201 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
