Question about Electrolux Central Vacuum
Electrolux troubleshooting I have everything connected but unit will not turn on when i insert the hose in the house.
2 Suggested Answers
SOURCE: Electrolux 1590 not turning on
TRY JUMPING THE CENTRAL VAC INLET WIRES AT WALL! IF COMES ON SOMETHING IS MISSING ON HOSE TO WALL CONNECTION. MOST HAVE A METAL RING TO ACTIVATE THE INLET DOOR WHEN HOSE IS CONNECTED.
Posted on Dec 12, 2009
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
My electrolux versatility vacuum doesn't have much suction
Hello, this is Ava with Think Crucial.
If you are experience less or no suction of you vacuum, most of the time there is a blockage that clogs up your unit resulting to this. Turn off your vacuum first and unplug the machine from the power before doing any troubleshooting with your vacuum. Remove the attachment hose and check inside the hose and the openings where the hose attaches for any blockages. You may refer to your manual below for troubleshooting solutions:
Electrolux EL8502 User Manual
You can purchase a wide variety of high quality Electrolux replacement parts for your Electrolux vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=electrolux
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 18, 2014 | Bissell 9200 Upright Vacuum
Renny starts as soon as the unit is plugged in....leave the hose off and the unit will not start until the hose is connected
This is a problem that needs to be checked at an Aerus Electrolux store. They have the tech manuals to troubleshoot the specific problems with the Renny (Renaissance). There are three possible problems involving the electronics in either the hose handle or the canister.
When the problem was first noted, customers brought their vacuums in and the service managers simply replaced the hoses. That resulted in burning out the boards in either the new hose or the vacuum, increasing the cost of warranty repair/part replacement. Electrolux quickly sent out service updates letting the service personnel know to stop the practice immediately. I can't remember how long it took before we finally got the proper troubleshooting data, but yes, there were a lot of problems with many of the machines. Fortunately for the store I worked at, there weren't many.
Oct 16, 2013 | Electrolux Vacuums
Unit turns off when any type of restiction to air intake. For example when unit is turned if hand is held in front of hose connection unit will turn off
This actually cover several models of Aerus and Electrolux canister vacuums. Models covered include: 2100, Epic 6000, Epic 6500, Aerus Lux 5500, Aerus Lux 7000, and Aerus Lux Legacy. Be aware that some of these models may still be under warranty. Any disassembly of those machines will void the warranty. Use of non-genuine bags also voids the warranty. Use only Home Solutions Aerus/Electrolux bags.
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Mar 04, 2011 | Electrolux Epic 6500 Vacuum
My Epic 6500 power head will not turn on. Had to push the reset many times the last time it ran, and now it will not turn on. Help!
Does the power nozzle motor come on? Is it just that the brush won't turn? If it's just the brush not rotating, the belt probably broke and needs replaced.
Is the brush clean? If not, clean all threads, etc. off.
Check all wire connections for breaks, cracks, and discoloration. Power nozzle to wand, wand to wand, wand to hose. If any of those are found, that part, and probably the one it connects to. will need replaced.
Ensure all connections are snug.
Internal wiring, including connections, could be bad. This would include wiring in the power nozzle, wands, hose, or canister.
Reset or hose switch could be bad. These would need replaced.
Power nozzle motor could be bad. Generally the belt will break before the motor burns out, but it's possible it's didn't.
For any internal repairs, including belt replacement, the entire vacuum should be taken to an authorized Aerus Electrolux dealer. The service technician can also troubleshoot and find the problem. This is generally done at no charge.
You've got a great machine, and with proper care and maintenance it should last for years to come.
Dec 22, 2010 | Electrolux Epic 6500 Vacuum
Dec 12, 2009 | Electrolux Vacuums
Have electrolux renaisance e10 hose will not turn
This machine is sold only by a Electrolux dealer. Only they can get you the correct hose part. But you are right, it sounds like you have a bad electrical connection in this hose. That has been common.
Dec 03, 2009 | Electrolux Vacuums
Power head turns on and off as the unit is vacuuming
Probably not hose but more then likely is a problem within your wand. Try connecting your hose handle directly to your powerhead and see if you can get consisten power. I work in customer service for electrolux and more then likely it is in fact the wand
Jul 17, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have an Electrolux Aerus 2100 canister vacuum. When I
it might be that the hose connections are bad.or it might be a sensor in the vacuum. call a electrolux vac shop and get it looked at.
Jun 24, 2009 | Vacuums
Lack of suction at power unit
Check that the Handle has a slider to adjust air flow, Electrolux Vac's arent really designed for carpet cleaning, check hose for breaks or cuts and everything is secure, while its on run your hands all over the hose and vac to locate any air flow that should not be.
Let me know.
Nov 15, 2007 | Electrolux Centralux Vacuum
Vacuums Logo
35 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
