Broken sata plug for hard drive - Computers & Internet
    Master:
  • 752 Answers
I assume you're talking about a bare drive here, not one that is in an enclosure for external use. A picture would help.
It is possible to remove the circuit board from a bare hard disk drive, desolder the connector and replace it with a new one. Only try this if you are handy with a soldering iron. Alternatively replace the whole circuit board and with it the connector, if you find one that is right type
I would sell it as a faulty item on ebay, hoping some skilled at repairing these things would buy it, and buy a new or used HD
If you have data on the HD which you wish keep, the best thing is to get it repaired by someone skilled in the art, or go to a data recovery company. Many manufacturers offer a data recovery service, and/or if you're very lucky and/or the disk is under guarantee they replace it free of charge.
see this
Broken HDD Sata connector
read to the end: there may be other solutions in the references at the end
I think (?) what you need is something like this
http://www.ebay.co.uk/itm/Laptop-SATA-HDD-Adapter-C49RW-Connector-Interposer-Dell-Latitude-E5420-E5520-New-/301600025459
Posted on May 18, 2016
FreeAgent Pro USB broken -- need data from Momentus drive
Momentus is a SATA drive, so you can put it in any PC that has SATA bus to access the drive.
If you can borrow a SATA to USB dock, you can put it in the dock and plug the dock to USB port on a computer to get your data out the drive.
One example for the USB dock is EZ-dock and you can search on Internet for the picture.
Apr 11, 2014 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Repair broken
Easy, just hook up old drive as secondary and new drive as primary. Copy what you need from the secondary onto the primary. When you are done, just disconnect the secondary drive and enjoy your new one.
Dec 28, 2013 | Hitachi Deskstar 7K1000.C HDS721010CLA332...
Sata pata ide hard
A sata drive doesn't need jumpers. The jumpers were only required when 2 drives used the same cable.
Nov 28, 2013 | Dell Dimension 3000 PC Desktop
My model BC1TB has not backed up for 10 days, and does not turn on when plugged into AC power. It it dead?
It may not be your hard drive but the enclosure casing that is not powering up your drive. If you are a self do'er, open the enclosure and take the hard drive out. The hard drive should be a SATA. Do only this if the warranty has expired otherwise you will void the warranty. You can purchase another enclosure for your SATA drive. To test if the hard drive is still operable, you will need to open the case and connect the hard drive to a SATA controller via a data cable/15 pin power connector. If you're a novice, I recommend getting a hard drive docking station which will connect via usb to your computer/laptop.
Nov 23, 2013 | Computers & Internet
My Seagate Momentus 5400.6 500GB hard disk is told to be inaceesible and corrrupted by my pc. the plug of hard disk was broken so i changed the casing twice , it works finely for 2 3 days and then there...
Internal hard drives should only be opened in a clean room. If I understand you correctly this drive is bound to fail. Suggestion: Start moving files onto other space.
Aug 28, 2012 | Seagate Momentus 5400.6 500GB SATA/300...
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
How do i install a wdeads hard drive? where is the power supply (4pin Molex)?
I'LL TELL YOU UPFRONT i HAVE ONLY INSTALLED SATA ON A NEW SYSTEM SO MY ANSWER MAY NOT BE CORRECT IN ALL SITUATIONS
Question is vague. Are you replacing a drive or building a new system? SATA drives have a dedicated plug on the Mother Board. Of course you already know you can't replace an IDE with a SATA without an adapter (Ebay has them for about $8) or the Bios is incompatible. The power is on the Motherboard and does not have a connector from the power supply like an IDE has.
Feb 20, 2011 | Western Digital WD15EADS 1.5 TB SATA Hard...
My samsung sata hard disk HM120JI is not working fine. Windows is not coming up. I have replaced the hard disk and now want to copy data from samsung sata disk to the new disk. Could you please tell me how...
You can buy a SATA dongle that plugs in to the hard drive and plugs into the USB port on you computer $20 or buy a external SATA case to put the hard drive in $40 at most computer retailers.
Feb 06, 2011 | Samsung SpinPoint M60 HM120JI 120 GB SATA...
My laptop is broken and i want my data copy to my other pc
Maybe you need laptop drive enclosure? It can be powered by USB cable alone together with to and in data transfer.
Hope this helps.
Jan 18, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
