Question about Saws
How to put the guard back on supieror chop saw
Can 't figure how to put the guard back on supieror 10" chop saw
rowdy45176
  • 2176 Answers
SOURCE: Lower Blade Guard on a Miter saw
If you haven't fixed them yet, give me the model and brand and I will see what I can do. Dave
Posted on Dec 24, 2008
brewerstool
  • 141 Answers
SOURCE: How to replace Ryobi circular saw CSB140LZ lower guard assembly
Clean the area where the guard attaches to the hub assy. It is a snap ring that is holding the guard on. You will need to either use a pick or a small flathead screw driver in order to remove it. There should be a little tab that you will be able to work out. Look around the entire perimeter of the hub to locate it. You may need some extra light to see it. Stick the pick or small flathead behind the tab from the right. Work the tab out and above the hub. Now you can work your pick or scredriver around the perimeter to remove the ring. Install it in a similar fashion but use the flathead to guide the ring back into the groove, working it around the opposite way.
Posted on Sep 28, 2009
Testimonial: "Got it. Thanks"
rowdy45176
  • 2176 Answers
SOURCE: replacing the blade guard spring
there is a hold in the lower guard for the loop and the other end wraps around the guard slightly and there is a hole in the back of the upper guard. You can go to Milwaukeetool.com and download a breakdown for the tool Also when you have the blade off I would try using compressed air to clean the area and spray some lubricant on the hub to lubricate. The guard should "snap" back when done sawing. Let me know if you need more help
Posted on Mar 25, 2010
  • 10865 Answers
SOURCE: To get the blade guard on a Ryobi circular saw to stay up.
Hello. The blade guard is specifically designed to not stay up but instead to only come up as the wood pushes it up. This is a problem when you are trying to do a plunge cut but it is a safety feature. Joe
Posted on May 05, 2010
Testimonial: "Your feedback is very much appreciated. Thanks."
rowdy45176
  • 2176 Answers
SOURCE: How do I assemble the blade guard for my Makita
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
Posted on May 04, 2011
How do you remove the blade on my toledo chop saw
Unplug the saw first. Then raise the guard and lower the blade onto a piece of wood to keep the blade from turning. Using a proper wrench, turn the nut in the direction the blade spins when cutting and remove the nut and blade.
Sep 04, 2014 | Saws
My chop saw has power but does nothing, it's new. Brushes are good, Power to the switch but it does nothing.
Hi. Maybe there is a safety interlock of some sort for which the conditions are not being met, maybe a blade guard switch or some such. Can you refer to the owners manual?
Sep 14, 2011 | Black & Decker DW713 10 In. In. Comp Miter...
Needing to change the 12 inch blade on a Dewalt chop saw. How do I remove theblade guard and remove the bolt out of the saw. Is the bolt clock wise or counter clock wise
I don't believe you have to take the guard off,just roll it back out of the way so you can get a wrench on the nut. The rotation is clockwise to take it off.
Aug 30, 2011 | Garden
I have a ryobi 10" mitre saw and i took the guard
I don't know but if you have figured it out let me know. I have same prroblem.
Apr 19, 2011 | Ryobi 10 In Miter Saw With Laser
WHAT IS THE LARGEST BLADE THAT CAN GO ON THE SAW
you don't say what kind of saw, so i'll make the assumption that you are talking about a circular saw. in this case the blade cannot be so large as to not allow the guard to close, pretty obvious. It is best to put a blade in that has at least 1/4 in (inch) clearance on the guard when closed. This holds true for a "Chop Saw" "radial arm" elec miter box" and table saw.
Mar 23, 2011 | Garden
Where do i get a diagram of how to instal guard spring on makita ls1030 chop saw
Hello. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Oct 26, 2010 | Makita 10" Miter Saw LS1030N
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Apr 10, 2009 | Makita 10" Miter Saw LS1030N
How do i change the blade on a bosch 3912 chop saw
Push the saw down and manually hold the guard while it is the retracted position and let up on saw while holding guard,you should
be able to put in wrench and loosen bolt.
Apr 09, 2009 | Bosch 3912 12 Inch Compound Miter Saw,...
Saws Logo
48 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
