Question about Apple Cell Phones
When i try to activate i messages or facetime a message an error occured during activation please try again
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 41 Answers
You probably need to update your phone bc thats part of the update the imessage & factime issue
Posted on Feb 18, 2014
4 Suggested Answers
SOURCE: Error 96 While text messaging, Help please?
I have the same problem. You have to use the area code, the full 10 digit number. Even the phone numbers stored in your memory need to include the area code for the text to send.
Posted on Aug 16, 2007
SOURCE: i have an lg viewty
i download nimbuzz in my mobile LG pk500 but i canlt find in menu,,thnx
Posted on Jan 10, 2010
SOURCE: "Message storage memory not ready", followed by 0x80900001 error while backing up
I got the Same Problem with error(0x80900001) and i have tried to delete message but it not allow to delete message also.
after removing external memory card i have restarted once. now every thing comes to control.and started to delete inbox messages. now working fine.
Posted on Jul 22, 2012
What does it mean when my 2008 trailblazer LT stabilitrac service light comes on?
Service Stability System Message The message center displays the service stability system message when any one of many VSES-disabling DTCs is set. The EBCM sends a serial data message to the IPC requesting this display.
It means there is a problem an till you get it fixed the stability control system is disabled ! ( EBCM ) electronic brake control module Has detected a problem an set a DTC - diagnostic trouble code in it's memory an had the message displayed !
Vehicle Stability Enhancement System (VSES)
The vehicle stability enhancement system (VSES) provides added stability during aggressive maneuvers. Yaw rate is the rate of rotation about the vehicle's vertical axis. The VSES is activated when the electronic brake control module (EBCM) determines that the desired yaw rate does not match the actual yaw rate as measured by the yaw rate sensor.
The desired yaw rate is calculated by the EBCM using, primarily, the following inputs.
The position of the steering wheel
The speed of the vehicle
The lateral, or sideways acceleration of the vehicle
The difference between the desired yaw rate and the actual yaw rate is the yaw rate error, which is a measurement of oversteer or understeer. When a yaw rate error is detected, the EBCM attempts to correct the vehicle's yaw motion by applying brake pressure to one or more of the wheels. The amount of brake pressure which is applied varies, depending on the correction required. The engine torque may be reduced also, if it is necessary to slow the vehicle while maintaining stability.
VSES activations generally occur in turns during aggressive driving. When braking during VSES activation, the pedal may pulsate. The brake pedal pulsates at a higher frequency during VSES activation than during ABS activation.
It
Jun 19, 2015 | 2008 Chevrolet Trailblazer
Volvo V-70 drivetrain & electronics faults
I suspect you have some loose connections or shorts in the wiring harness. I've had similar strange things happen with an Olds Bravada. Various transmission shifting problems, faults, etc. that all seemed to come from the engine's computer system getting incorrect voltages and readings due to wiring faults/shorts.
Dec 16, 2011 | Cars & Trucks
I am having trouble with Microsoft Office Home and Student 2007
This article describes how to troubleshoot problems that you may experience when you try to activate a 2007 Microsoft Office application. Additionally, this article contains several methods that you can use to troubleshoot activation issues.
This article is intended for a beginning to intermediate computer user.
You may experience the problems in the following scenarios:
Scenario 1
When you try to activate a Microsoft 2007 Office suite, you may experience one of the following symptoms:
  • You receive the following error message:Your software cannot be activated because the product key you installed with is not valid. Please uninstall the software and reinstall it using a valid product key.
  • The activation process fails. Additionally, you receive a message that states that you have reached the limit on the number of computers on which you can activate the 2007 Office suite.
Scenario 2
When you successfully started a 2007 Office application and all functions worked correctly for you in the past, you receive an error message. The error message indicates that significant changes were made to the configuration of the computer. In addition to this error message, you may also experience any of the following symptoms:
  • When you try to activate the 2007 Office suite, the Activation Wizard disappears.
  • When you try to to activate the 2007 Office suite over the Internet, you receive a communications-related error.
  • When you try to activate a 2007 Office suite , the Activation Wizard does not start. Additionally, you receive no error messages.
Scenario 3
You try to activate the 2007 Office suite over the phone. However, after you enter the confirmation ID that the support staff supplied to you, you receive an error message. The error message states that the confirmation ID is invalid.
Scenario 4
When you successfully started a 2007 Office application and all functions worked correctly for you in the past, the 2007 Office application now runs in a reduced functionality mode.
Scenario 5
When you start a 2007 Office Trial version for the first time after you complete License Activation, the 2007 Office Trial version runs in a reduced functionality mode, and the Office Activation Wizard is displayed. Additionally, the following text is displayed:
2007 Office system is expired. In this expired state, many features of the version are unavailable until you convert to the full product. Click Convert to begin the conversion process.
Note This activation problem indicates that the Opa12.dat file is corrupt for the 2007 Office application. Scenario 6
When you try to obtain an activation key for a trial version of the 2007 Microsoft Office system over the Internet, you receive the following error message:The Microsoft Activation Assistant was unable to request your trial activation key
This issue is temporary until the updated version of Try Microsoft Office 2007 is available. Microsoft is in the process of updating Try Microsoft Office 2007 based on the January 2010 update for Office Word. For more information, click the following article number to view the article in the Microsoft Knowledge Base:978951 Description of the January 2010 update for Office Word
Oct 26, 2011 | Microsoft Office Home and Student 2007...
Display an error message as "your internet setting must be activated for java applications, or try again later"
You need to activate mobile office,you will then get an service message with the configuraton. for Airel I guess you can dial *567*# to activate it.
Feb 11, 2011 | Cell Phones
Loaded Start disc. When installing my language disc 1, I get an 9123 error code and a message " there was an error in the application". I cannot uninstall, because I get messages "...
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
  • Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
  • Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Dec 23, 2010 | Rosetta Stone Chinese Mandarin Level I &...
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Keyboard cannot be install on rebooting
uninstal the drivers of keyboard from device manager and restart the system
Aug 14, 2009 | HP Business Notebook 550
I cannot get on the internet. It gives me an error message- Network too busy. please try again. This is my cell phone. The Samsung m300
Certain times of day, cell phone traffic is at its busiest. This error message occurs during these times when the network is unable accept more traffic. Try again in little while and it should work. :)
Nov 23, 2008 | Cell Phones
Cell Phones Logo
60 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
