Question about 3M Genuine Thermofax Thermo Fax Tattoo Stencil Transparency Maker Model 45dg
My thermofax wont spin or accept the carrier sheets
Do they carry a sin card what carrier
Hi all gsm phones will carry or accept any GSM sim card you can't use the phone without sim in it ...The phone will accept any carrier sim if it is unlocked one else if the phone is locked to any particular carrier then it wont accept any other carrier sim until you unlock it .You can easily unlock the phone through online providers like SimpleUnlocking.com here they are rendering network unlock code for all mobile models at reliable cost .You first check that whether the code is available for your mobile model ,country and network provider .If yes then pay for it and unlock your phone then freely use it with any carrier sim ...
Oct 24, 2014 | Cell Phones
How to change imei number
The phone maybe locked to a particular carrier and needs to be unlocked to in order to use with other carriers. You must check witht the seller abot the carrier, i beleive you have been cheated.
Nov 27, 2013 | Apple iPhone 4S
Won't accept the sheet
wont accept the sheet in paper tray or in the scaner?
Aug 20, 2013 | Office Equipment & Supplies
Carrier model 38txa024300 ,condesor fan wont oporate with compressor unless the fan is spun befor energizing . is it the dual run capacitor that is bad? thanks for any help. jeff
If the fan spin freely then the capacitor could be bad. Otherwise, if it spin with difficulty then it need to be cleaned and lubbed.
May 22, 2011 | Carrier 36KCARMS Air Conditioner
The outside fan is not spinning in my carrier tech 2000ss. I was trying to find the panel outside to reset it but I dont know where it is. Can you please help me?
The outside unit will have finned tubes on three sides, and sheet metal on the fourth side. The panel is located behind the sheet metal panel.
Best regards, W/D
Apr 29, 2011 | Carrier Heating & Cooling
Sony CMT-EP515 CD Shelf System. CDs wont play. Place CD in tray and close, disc doesnt spin but 4 distinct clicks heard then nothing
It could be 3 things.
1. the Laser carrier may be stuck and may need to be gently pried from centre to outskirt and back.
2. your cd spinning motor has gone and needs to be replaced,
3. your laser carrier motor has gone and needs to be replaced,
hope it helps.
Aug 04, 2010 | Sony CMT-EP515 CD Shelf System
Why wont my thermofax bulb kick on?
Call me 614-580-9676. I repair this machines.
Jul 20, 2010 | Office Equipment & Supplies
Thermofax machine repair
Not really sure what you are asking? Is it a thermofax that is making noise that you use to make transparency with. Or is it transparency making? I never worked on a transparency maker in 20 years of office machine repair... What is it? Is a old machine? If it is that old it may be time to replace it....
Mar 30, 2009 | Office Equipment & Supplies
I have a 3m thermofax 45cg every paper run through is completely
I am a major seller of these machines in ebay. The machine may need a new potentiometer. Build a carrier. Put two pieces of transparency plastic sheets together with a piece of tape and use this to carry your stencils. This will reduce the heat of the lamp. Rouben (rouben@ektalc.com).
Mar 23, 2009 | Office Equipment & Supplies
3M Genuine Thermofax Thermo Fax Tattoo Stencil Transparency Maker Model 45dg Logo
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
