Question about Vizio 8-inch TouchScreen WIFI Android Tablet PC- plus Folio Case -
My VIZIO TABLET VTAB1008 The MICRO USB Port is broke my tablet won't charge is there any way this can be fixed
The micro usb port is broken on my tablet wanting to no if it can be fixed what do I need to do
  • 3 Answers
My usb port is pushed down
Posted on Feb 19, 2014
2 Suggested Answers
  • 987 Answers
SOURCE: I have a orange light when I plug up my charger to
its chargeing
Posted on Sep 02, 2013
I want to hook my tablet to my tv, how can I do this?
Use an HDMI cable between your tablet and your TV. On my tablet, the HDMI port is near the micro USB power port.
Jun 03, 2017 | Tablets & eReaders
Charger fot my acer tablet only goes half way in and wont charge
The pin inside the charger port might be broken.
Look in the hole where you put the USB (on the device) there should be a tiny flat tongue sitting in the middle, if it's bent and touching the inside of the hole, it will need repairing. It's a very common fault.
You might be able to temporarily fix it yourself by trying to straighten it with a tooth pick. It's supposed to slot inside the micro USB plug.
Oct 20, 2016 | Acer Tablets & eReaders
Port on 10 inch tablet not working can it be fix
Linda, if it is the charge port, mini USB, yes they can be fixed or replaced by cell phone/computer repair shop.
Check the attached links videos showing port replacement. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Toshiba Tablet AT300SE AT305SE Charging Port Repair
Samsung Galaxy Tablet 10 1 Tab 3 10 1 P5200 P5210 Micro USB Port Replace HD
May 03, 2016 | Tablets & eReaders
My Charger Port is no longer there is there any other way to charge it
Jillian, Check warranty, I beleive should be one year, call manufacturer right away if under warranty. Option 2 Have charger port replaced at a computer/cell phone repair shop. Check links below and see how they fixed this issue.
How to Fix the Charging Port on Tablet
Is there any way to charge my tablet without the micro USB port
http://forums.androidcentral.com/amazon-kindle-fire/283806-anything-i-can-do-if-my-charging-port-broke.html
Apr 26, 2016 | Tablets & eReaders
The charger wont go in to the port to charge it and the tablet needs to be charged it was working just fine last night dont know if my son did something or not
Robin, the charge ports can be changed at a computer or cell phone repair facility. Check the attached links,instruction and guides, Good luck
How to replace the fixed charging port
How to Fix Tablet Charger Port
Amazon com 2 pcs Replacement Micro USB Charging Port Connector for Vizio...
Apr 24, 2016 | Tablets & eReaders
Is it ok to charge my RCA tablet pc w/a micro mini USB?
if the micro mini usb port fits the tablet ---yes as that is the cable used to charge it with
Dec 21, 2015 | Tablets & eReaders
Charging port loose.no longer charging on my tmax tablet
Try a different Micro-USB cable. It is usually caused by the cable's micro-USB end being loose and not the tablet's charging port. Most smartphones these days use Micro-USB so you can usually try using one of those if you have one.
Aug 04, 2014 | Tablets & eReaders
Charging port broken
Honestly, even if you could find the part (not likely - tablets are commodity items these days), you would need specialized tools to de-solder the remainder of the old port and solder the new port, and you would risk damaging other components because of the proximity of parts on these small circuit boards. If you want to take it on, research who actually builds the tablet and contact them about parts. A better option might be to find one with a broken screen or some such (check local 'for sale' sites) and try to swap only that part (if the charging port happens to be connected to a smaller 'side' board rather than the main board). Tough one. Good luck.
Jul 18, 2014 | Coby Kyros MID7036-4 7" 4 GB Tablet -...
How does and android charger look like
A USB cable with a micro-USB connection at the phone or tablet...
You can plug the USB directly into your PC, get a car adapter with one or two USB ports, or a small outlet adapter with one or two usb ports.
Mar 09, 2014 | Velocity Micro Cruz Reader R101 Tablet PC
Vizio 8-inch TouchScreen WIFI Android Tablet PC- plus Folio Case - Logo
157 people viewed this question
Top Vizio Tablets & eReaders Experts
Carlos L. Burgos
Carlos L. Burgos
Johnathan Lence
Johnathan Lence
Are you a Vizio Tablet and eReader Expert? Answer questions, earn points and help others
