Question about Apple Cell Phones
I try to send i messages or activate facetime and each time the message an error occured during activation please try again
Every time i try to set up i messages or facetime a message comes up an error occured during activation please try again everything else works on the phone ive registered with the apple store and still the problem continues
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Settings>Facetime>turn on activation.
Posted on Feb 18, 2014
  • 4 Answers
SOURCE: Iphone won't work well with SBC global
Are you setting up your email using the Yahoo! presets? Or are you actually typing in the POP and SMTP server information (e.g. pop.att.yahoo.com)? I know people with ...@sbcglobal.net email addresses have had success using the Yahoo! presets. This seems to be a persistent issue with iPhone users - not being able to access their SBC accounts.
Posted on Aug 10, 2007
jessee007
  • 310 Answers
SOURCE: Can't send or download any multimedia messages
check your service provider this is a pay service and they could be the problem not your phone
Posted on Jan 04, 2008
SOURCE: Error message when trying to send pictures
i work at a cell phone support group called ict, we get this problem all the time with the lg phones. the problem is with the carrier select in the programming. have your phone reprogrammed...you will need to contact your service provider for you lock code, but you can usually get into the programming screen by dialing ##program# or ##data# from the main screen of the phone (you do not need to dial this number or hit ok once putting in the last #, it will automatically pop up if you are doing the right code. again, you will need your lock code from your service provider/carrier. once you have that go into the programming and go to carrier, high lite which ever carrier you are with, hit ok and the phone will shut itself off, turn itself back on and you should be able to send your picture without further problems..
...if it then asks you for a pass, call your service provider, they also need to give that to you and if it says error 256 after that, then call your service provider because the url needs to be changed...
hope this long winded post helps you guys.
Posted on Feb 05, 2008
cilikcelkom
  • 253 Answers
SOURCE: when im trying to send
Do a hard reset. Its very simple just press *#7370#.
Then it requests for the security key which is 12345 by default or enter your security code if you have changed the security code..
Please note that all the data on your phone will be deleted so kindly make a back up.
Kindly rate us in fixya if i am helpful
Posted on Jan 03, 2011
SOURCE: I'm having problems with the
This sometimes happens, if you have just turned off your phone this will more o rless always happen. Just give it a couple of minutes and if this keeps on happening....turn off the phone take off the back and take out the battery and sim card. Leave it for a minute or two and then put them back in and turn on your phone. Then go back onto messages, it will still be happening, leave it for a minute or two and it should be absouletly fine, the sim is just taking a long time to load thats all, there is not really much you can do! I hope this helped (:
Posted on Apr 08, 2011
What does it mean when my 2008 trailblazer LT stabilitrac service light comes on?
Service Stability System Message The message center displays the service stability system message when any one of many VSES-disabling DTCs is set. The EBCM sends a serial data message to the IPC requesting this display.
It means there is a problem an till you get it fixed the stability control system is disabled ! ( EBCM ) electronic brake control module Has detected a problem an set a DTC - diagnostic trouble code in it's memory an had the message displayed !
Vehicle Stability Enhancement System (VSES)
The vehicle stability enhancement system (VSES) provides added stability during aggressive maneuvers. Yaw rate is the rate of rotation about the vehicle's vertical axis. The VSES is activated when the electronic brake control module (EBCM) determines that the desired yaw rate does not match the actual yaw rate as measured by the yaw rate sensor.
The desired yaw rate is calculated by the EBCM using, primarily, the following inputs.
The position of the steering wheel
The speed of the vehicle
The lateral, or sideways acceleration of the vehicle
The difference between the desired yaw rate and the actual yaw rate is the yaw rate error, which is a measurement of oversteer or understeer. When a yaw rate error is detected, the EBCM attempts to correct the vehicle's yaw motion by applying brake pressure to one or more of the wheels. The amount of brake pressure which is applied varies, depending on the correction required. The engine torque may be reduced also, if it is necessary to slow the vehicle while maintaining stability.
VSES activations generally occur in turns during aggressive driving. When braking during VSES activation, the pedal may pulsate. The brake pedal pulsates at a higher frequency during VSES activation than during ABS activation.
It
Jun 19, 2015 | 2008 Chevrolet Trailblazer
When i try to activate i messages or facetime a message an error occured during activation please try again
You probably need to update your phone bc thats part of the update the imessage & factime issue
Feb 08, 2014 | Apple Cell Phones
Cant get picture message or send them
first look that your pic is in pic form or image form
for pic form go to the message sending option
for image (photo) form activate the mms setting
and try sending message
Feb 06, 2013 | Samsung Cell Phones
Can't send or recieve MMS on Net10
With net10 it tells you clear as day on the step by step activation process on the web page that net10 does not support multi media messages. You will need to download a third party messaging app to send and recieve or use the email app.
Sep 26, 2012 | HTC Inspire 4G Smartphone
When i try to send a picture i get an error message that says "sending failed Incorrect server Response"
so your network service provider does not activate the mms service for your mobile number . Please contact your network servie provider and ask them to activate the mms service and also ask them for the mms settings and activate the exact mms settings in your phone
Jun 19, 2011 | Samsung Eternity Cell Phone
Loaded Start disc. When installing my language disc 1, I get an 9123 error code and a message " there was an error in the application". I cannot uninstall, because I get messages "...
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
  • Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
  • Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Dec 23, 2010 | Rosetta Stone Chinese Mandarin Level I &...
Whenever i try to send a multimedia message it wont let me
HI, to get back and have access to multimedia messages, you will need to contact the service provider of the network you are using. They will be of assistance to you on how to get the multimedia message sending work again.
Take care.
Jun 22, 2010 | Samsung Propel A767 Cell Phone
How to activate gprs china phone
Automatic Activation of GPRS
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text “ACTIVATE” and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: “Sun GPRS”
APN: “wap”
Select SUN MMS
Account Name: “Sun MMS”
APN: “mms”
Exit and save settings
Jun 06, 2010 | Nokia E66 Smartphone
My USB port power error message
This happens when anything draws over 500mA, of current, if it was working OK, before, and is working now but displays that message, or not working, well in any case it seems to have gone faulty, and somehow, is now drawing more current drain, the USB port can supply. It may have been spiked too.from all the plug/unplug especially if the safely remove hardware is not used.
May 06, 2010 | Dell Latitude C610 Notebook
HELP! wont install
go my computer-c drive-programe files-and delete any programs you dont use and do disk cleenup in accessorys and defragg
Oct 05, 2009 | Microsoft LifeCam VX-3000 Web Camera
Cell Phones Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
