Question about Mtd 22" White Outdoor Self Propelled High Wheel Mower
Does it take petrol or two stroke - Mtd 22" White Outdoor Self Propelled High Wheel Mower
    Loyalty:
    Visited the website for 30 consecutive days.
  • Mtd Master
  • 1,103 Answers
Gss
Posted on Mar 15, 2018
Bought it at local, start alright with petrol. When try with 2 Stroke RYOBI Synthetic Oil hard to start. Should i just use normal petrol oil?
no --- 2 strokes use a special 2 stroke oil ==not ordinary engine oil==
the difference is that the 2 stroke oil is specially blended to mix with petrol and will not block up the fine jets in the carby
it also "sticks " more readily to the metal components in the engine thus preventing wear
as a point of interest most small engines do not like E mix fuels either
so for trouble free operation --2 stroke oil mixed in the correct ratio with either 89 or 91 octane petrol and it will start first pull every time
use the primer bulb sparingly or the choke until it fores
Oct 19, 2015 | Homelite Garden
Does this scooter have a two stroke or four stroke motor?
If the scooter is a Lamberetta or any other Italian scooter usually they are two stroke, to which you add two stroke oil to the petrol. on some newer model scooters they have a seperate oil bottle near the petrol tank which takes the two stroke
Mar 29, 2015 | Motorcycles
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
Do i put an oil/gas mixture in gas tank?
the 4 stroke engine only needs petrol in its tank . if your motor has a dipstick for oil it is a four stroke ,,only two strokes requires oil and petrol mix as they have no oil sump in their design
Jun 01, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
What bis the ratio for a 1635a 16 inch 2 cycle
I got this from the McCulloch.com website. "Products with two-stroke engines, the petrol must be mixed with two-stroke oil. McCulloch recommends Outdoor Accessories two-stroke oil. The petrol/oil ratio must be 50:1"
Oct 05, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 | Garden
Is it 25/1 petrol and oil for a sthil blower bg85 thanks
hi artwill3544
no
using sthil 2 stroke oil mix at the rate of 50:1 that is 20 mils of oil per 1.0 litre of petrol that you mix , or if you mix 5 litres you would pour in 100 mils of 2 stroke oil into a 5 litre petrol petrol can , then add 5 litres of petrol only and give good shake to mix , then fill your blower with that mix
cheers pauly46
Sep 21, 2011 | Garden
I have a Poulan 625 push mower. What type of oil should I use in it? I can't find my manual.
If it has a 4 stroke engine, as most lawnmowers do, then you just car engine oil. Very occasionally you come across 2 stroke mowers.
The way to know if it's a 4 stroke or 2 stroke engine is, if it has an oil tank it's a 4 stroke engine. If there's only the one tank, i.e. you mix the oil with the petrol then it's a 2 stroke engine.
If it's a 2 stroke engine you mix petrol and 2 stroke oil at a ratio of 40:1
Jul 12, 2011 | Poulan Garden
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
How petrol is going in engine from tank and how it
air and petrol mix in caburater cause of sucking pressure by the piston when intake stroke (intake valve remain open) then the piston move up to tdc(top dead center) that call compression stroke (at this time both valve remain closed) and just before the piston reach the tdc the plug stat to ignite and the detonation is the power stroke and push down the piston and the piston come up again as the exaust stroke. that is a little bit information
Mar 28, 2010 | 2000 Bajaj Chetak 150
Mtd 22" White Outdoor Self Propelled High Wheel Mower Logo
18 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
