Question about Dryers
When I open and close the dryer door sparks fly out from the door.
3 Suggested Answers
  • 1028 Answers
SOURCE: Dryer door pops open after
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Posted on Jun 14, 2008
jmeredith
  • 417 Answers
SOURCE: Dryer door won't stay closed
hi,
shut off the breaker- pull the female receptacle clasp out of the front with flat screwdriver and needle nose and squeeze the back of it gently with pliers, replace, if its busted and you get mad, you can buy a standard padlock and latch and install that, that helps in other ways as well, careful to steer clear and watch the inner wall for wires and clearances if your going to retrofit that.
J
Posted on Jul 11, 2008
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
Why does my frige motor turn on when I close the door and off when I open door?
It's designed that way for energy saving purposes. The motor shuts down when the door is open so that it's not producing more cold air to just fly out the door. Then when the door shuts, the cooling mechanism kicks back on again for business as usual.
Oct 20, 2014 | LG Refrigerators
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
Runs for a while than shuts off if i take the back off it doesn't shut off.
Usualy this is caused by poor airflow through your dryer. Remove the lint filter and check for a lint build-up near the bottom of your lint filter. If you see a lint build up use a vacuum crevice tool and something long like a fly swatter to loosen the lint as you vacuum. Also check the dryer vent tubing and the outside vent flapper for obstructions. What is happening is your dryer is heating up until the high temp limit protection rhermostat shuts off the heating element.
What I just mentioned is apparently not your problem. You said that your dryer runs then shuts off completely. Check to see if the motor is easily roated by hand with the belt installed. If it is difficult to rotate there is a bearing problem somewhere causing heat to build up in your motor until the thermal overload shuts off the motor. There is a drive belt idler near the motor that can also cause excessive drag on the belt if the bearing has failed. The last thing to check would be the drum rollers located in the groved area on the outside of the rear of your dryer drum. If these have stopped turning they act like a drum brake and can also cause the same symptoms. Removing the back panel allows the chassis to shift enough for the drum to ride lighter on the drum roller even though it may not be turing it is enough for the dryer drum to skid / slide on top of the stuck drum roller yet not shut off.. Hope this helps and good luck. I can help with access issues need be here.
One question I have is does your dryer door open and close properly? Some times a bad door seal or door catch can cause the same symptoms. Open and close the door and losten for a switch click as the door opens or closes not far from the closed position.
Jan 06, 2010 | Kenmore 62602 Electric Dryer
Dryer won't start; light stays on whether door is open or closed.
Sounds like the door switch is not functioning or shorted......in other words the dryer thinks the door is open so it won't turn on.
Jun 22, 2009 | Dryers
There are flies inside on the screen. how do i get rid of them
By flies I take it you mean house flies? If so wait untill night, turn off your tv turn on one very bright light in the room by morning they will be out of the TV to rid your home of flies turn off all lights open the front door turn on the porch light (must be bright white) and they will go to the light then just close the door
May 21, 2009 | Hitachi 42V715 Rear Projection Television
Loud metal on metal noise, and sparks in rear of dryer
I've seen sparks flying out of an appliance before!
It could be a bad motor so be careful if you plan to plug it in again!
I would leave the back cover off before trying again so as to see what's sparking!
Jan 19, 2009 | Kenmore 98702 Stacked Washer/Dryer
Indesit IC70C Condensor dryer
We experienced a similar problem and corrected it by closing the drying door and then hitting "OPEN" followed by closing. Sometimes we use a tool to release the catch and then close the door. We have not seen this problem return.
Nov 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
15 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
