Question about Mackie MR5 MR5 Reference Monitor
Low volume one speaker
Low volume out of one monitor speaker, when adjusting the volume knob it crackles loudly
    Scholar:
    New Friend:
  • 125 Answers
It seems likely that the pot (volume control) is dirty. with a slider you can normally get fluid down the side of the knob, your's is a rotary control and you sometimes can do it round the shaft of the pot but more often have to spray it in where the connections go into the pot. You'll need some contact cleaner spray which you can get online or from an electronics store, get it onto the pot track and then take the pot to each end of its travel a few times, this'll probably sort it out until next time. If you're taking it apart it might be worth just getting a new and better pot and soldering that in if you are hand with a soldering iron. The ones in Mackies nowdays are pretty sh1t.
Posted on Feb 10, 2014
My TH-15A starts making VERY loud crackling noises after a few minutes of being turned on. It does not matter if an XLR cable is plugged in or not, and the volume control does not change the volume of the...
buy a canister cold spray and spray on some active components if the noise begins You have a thermical failure in a component on the board can be faltering resistorcircuits or resoldering some active components.
May 08, 2016 | Mackie Tapco Th15a Thump Active...
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
My mackie thump amp will start to have a loud cracking sound. The cracking goes away if I have the input line unplugged from the speaker but with it plugged in it has the cracking sound and it does not...
Crackling is usally one or two things my guess would be bad grounding of the amp or bad connection with the jacks or plug it self try to make it crackle on purpose by jiggling the jacks see if it has any effect on the crackling try to narrow your possibilitys
May 04, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Crackling sound in speaker
These speakers have a history of being blown if played too loud. Apparently the higher quality CX version are reliable. If the lows are what is crackling, the voice coils are probably cooked causing it to drag the pole pieces.
Apr 28, 2011 | M-Audio Studiophile BX5A Deluxe
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
Nov 28, 2010 | Mackie MR5 MR5 Reference Monitor
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
Marshall MG50 DFX, the volume knob OD channel crackles
Either the control is damaged (happens if they get hit) or it is possible the circuit board it is mounted on has broken solder OR worse, a crack near the control. The unit will require servicing. Parts are readily available.
Jan 28, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Hi. When switched on the speaker makes a loud constant crackling sound. Nothing will work, no keys, stops, anything. Just a loud crackle!
This usually means that the speaker is blown. Try running through a different setup and see if it fixes the problem. Hope this helps
Oct 01, 2009 | Music
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Mackie MR5 MR5 Reference Monitor Logo
75 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a Mackie Music Expert? Answer questions, earn points and help others
