Question about Matsunichi Marquis Mp977 Marquispad 9.7" Android Ics 4.0 - msimp977
Need new battery old one will not charge
Main battery voltage too low been charging pad for 6 hours
Tablet will not charge
Assuming that you charger is not defective, and that you have no other electrical issues, then if your battery has been allowed to completely flat line, it may no longer accept a charge from the normal wall charger. Then you can try to trickle charge your tablet from a low voltage/current source, such as a USB port or a low power phone charger (5v/500ma). Try a trickle charge for 8 - 24 hours on your tablet. After that try your normal charger and see if it will now charge properly.
If that does not work, and you have previously ruled out your charger, then I would suggest contacting the manufacturer, as it is likely some other fault, either with the battery, or the tablet itself.
I post on behalf of HP.
Jul 31, 2015 | Tablets & eReaders
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
Went to use it and it won't come on. Thought battery might be dead and plugged it in and it still won't come on.
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Mar 11, 2015 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
Battery will not charge
Your battery may be defective and cant hold a charge. Make sure the unit is receiving power and if so replace the battery.
Dec 15, 2014 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
I have a axpen 1320 tablet that won't charge with power cord what do I do
hmmm, sounds as if the battery had dropped below it normal 'low' charge, therefore it may not appear on the charging circuit (as if it were missing). This sometimes works for me. Put the tablet in your freezer for at least 6 hours. Lowing it's temperature sometimes will help bring a 'dead' battery back to some life, at least enough to get it back on line with your charger.
Sep 13, 2014 | Tablets & eReaders
I have had my kocaso m9100 tablet since this past christmas and not had any problems with it until recently. It went completely dead and i had it on the charger for more than 6 hours with a little red...
You need to check battery to see if the battery has correct voltage. Their should be on the battery the number for voltage of battery if battery is not at suggested voltage then check for tablet with voltage meter to see if the tablet is charging at correct voltage. If battery is at correct voltage then something is wrong with tablet. If battery is not at correct voltage then probably battery is bad. Let me know for further assistance
Aug 24, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Why will a samsung galaxy 2 tablet not charge?
first go to a mobile shop ask hif it it is the problem of battry or some hardware problem inside the tab and also check the charger weather it works or not
Jul 24, 2014 | Samsung Galaxy Tab 2
Power Problem
I have the matsunichi 9.7 my email has amessage saying connection problem no emails has come in for 2 days. What can i do to fix the problem
Mar 05, 2014 | Matsunichi Marquis Mp977 Marquispad 9.7"...
Touchpad wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 25, 2012 | HP Touch Pad 16GB Internet Tablet
Matsunichi Marquis Mp977 Marquispad 9.7" Android Ics 4.0 - msimp977 Logo
Top Matsunichi Tablets & eReaders Experts
Are you a Matsunichi Tablet and eReader Expert? Answer questions, earn points and help others
