Rear speakers not pairing
SOURCE: center speaker and wireless rear speakers have no sound
I had the same issue, but apparently...it's not an issue. What I discovered is that the system was fine, but the station I was watching didn't broadcast in 5.1 surround sound. Therefore, only the front speakers will have sound. Try putting a dvd in, or listening to a gameing system through it. If you don't have sound after listening to something that puts out full surround sound, then you know you have an issue.
SOURCE: I need the proper audio settings for LG. LHB953 to
Setting HDMI Audio to "on" locks the sound mode into "Bypass". Turning HDMI Audio off returned my sound options and sound from my rear speakers.
SOURCE: LG LHT854 Speaker issue
Have you tried the VSM (Virtual Sound Matrix) button on the remote? I think you will have to scroll through the various sound processors ie..stage...virtual matrix..etc...to find the one that will have all surround speakers working. Hope this helps
SOURCE: lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
SOURCE: My LG LBH953 Home Theater rear speakers won't work
You have go to audio setup on the main menu and turn off HDMI. Afterwards, select the sounds button on your remote and select the "games" option. This is because it is probably the best select to listen to movies via surrond sound. I hope this helps
