Question about Kitchen Ranges
CAN'T REMOVE THE DOOR ON A KITCHENAID GAS RANGE ARCHITECT SERIES
MODEL KGRS807SSS00
  • 1073 Answers
SOURCE: KERS907 series electric ranges.
any high tech range or any appliance for that matter that is high tech has a greater risk of repairs, the smart solution is to purchase an extended warranty on the appliance so if it does need to be repaired it will not cost you any additional expense
btw kitchenaid makes a fine range
Posted on Apr 16, 2008
ginko
  • 19396 Answers
SOURCE: kitchenaide gas range inner door part number 9781721 is cracked.
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Here the part Inner Door Glass
Posted on Apr 07, 2009
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
jsrock516
  • 5911 Answers
SOURCE: my kitchenaid architect series II gas range is
In most cases, this is an indication that the Electronic Range Control (ERC) is defective and needs to be replaced. The ERC controls all the features of the oven, so without it, you cannot turn the oven on or regulate the temperatures. You can attempt to reset it by unplugging the range for at least 30 seconds, first. Or you can try disconnecting each wire from the ERC and reseating it (one-at-a-time) to ensure you have good connectivity. However, if the problem persists you will need to replace the ERC.
If parts are required, you can purchase on line at the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever parts source you like, but I have found these websites to be reliable, offer great service and the prices are usually cheaper than retail. The prices will differ between sites, so shop around for the best deals.
If the model number you have this listed under is correct, the part number for the ERC is 9762794. The cheapest website I could find it was on the Sears website for about $158. (Not a cheap part no matter where you look for it).
To replace (if necessary), follow these steps:
1. Make sure the appliance is unplugged.
2. Remove the screws that hold the back of the control panel in place.
3. Take note of the wire color coding BEFORE removing any wires from the ERC. Most control boards will have the colors printed on the board by the terminals. If yours is not listed, either write the wire color codes down or use a digital camera to ensure you note the proper placement of the wires.
4. Remove the wires from the control board and the screws that hold it in place.
NOTE: Most ERC boards do not come with the overlay (This is the plastic that covers the facing of the EOC with all the features on it). Remove the old overlay from the old board if you wish to reuse it and install it to the replacement board.
If you have questions, please let me know. I hope this helps you.
Posted on Sep 23, 2009
SOURCE: kitchenaid gas range model KGRS807S - oven starts then stops
earl am16 error
Posted on Apr 16, 2010
Kitchenaid oven won't turn on
FOLLOW the OWNERS instructions to TROUBLE-SHOOT (EG remove the door, clean it & replace it properly, etc.). On my model... check the center top for a simple switch lever... than gets pushed straight in when the door is PROPERLY CLOSED...
(light should go OUT).
ELSE your door switch "thinks" your door is open =
BROKEN or DEFECTIVE DOOR SWITCH
ServiceBench
As much as I detest SEARS... KITCHENAID is close behind:
If you cannot find your door switch issue on a REPUTABLE PARTS SITE
SEARS does have some "COMPETENT EXPECTATIONS"
for their repair service... Act quickly... SEARs is deservedly going out of business.
But first look around... for GOOD VIDEOS
(NOT YOUTUBE)
appliancepartspros, ereplacemntparts, partsselect.com
My KGRS807SSS00 Model Overview from PartSelect com
Search Over 2 1 Million Appliance Parts
Jan 23, 2017 | KitchenAid Kitchen Ranges
Gas kitchenaid gas stove code F02. Turned off breaker seemed to cool down at first now getting warmer. Can't open oven door, like it is cleaning. What do Ido now?
Shut off the breakers and GAS make sure the oven has completely cooled... This may take a significant time
without the aid of the cooling fans...
While you are waiting the requisite HOURS....
Look up your model number on reputable parts sites..
I will list below.
The most likely failure point is a simple heat sensor... (thermal switch" which SHOULD HAVE released your door IF INDEED it
was cool enough (this is VERY critical).
http://www.appliancepartspros.com/
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Don't hesitate to call KITCHAID themselves...
They ARE SUPPOSED to be GOOD....
I DISAGREE... but that just my opinion... as a
disappointed OWNER of their "STUFF"
ServiceBench
Dec 26, 2016 | KitchenAid Kitchen Ranges
Kitchen Aid Gas Range Architect Series II-self cleaned the oven; it is done the oven is cold but the door is locked and nothing works on the control panel.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | KitchenAid Kitchen Ranges
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | KitchenAid Architect Series KEMC308KSS...
Apr 16, 2008 | KitchenAid KERA807P Electric Kitchen Range
Superba oven removal
im not familiar with this particular model but on most ovens you shoud only have to open the doors and the screws that hold it in should be visible. generaly 2 on each side
Feb 20, 2008 | KitchenAid Architect Series KEMC308KSS...
Model Number
Open the drawer or bottom cover panel and look on the facing where the door closes to
Dec 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Ranges Logo
13 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
