Question about Epson Stylus CX5800F All-In-One InkJet Printer
Pulls paper in sideways - Epson Stylus CX5800F All-In-One InkJet Printer
Mp499 The paper tries to go thru but only one side pulls it and it goes sideways and gets jammed.
The feed wheels on the one side are either worn out or have some scrap paper stuck on them. Take a good look , after removing the paper tray, if it has one , inside the machine. It might be possible to turn the machine around and see into it from behind, if there is an access door on the back.
Aug 02, 2014 | Canon Office Equipment & Supplies
Ink cartridges move back and forth, paper feeds and half way goes sideways creating a paper jam
check closely where the paper is moving sideways.. there is something obstructing the paper path, piece of paper a staple or something.. look closely
May 03, 2014 | HP Photosmart C3180 All-In-One InkJet...
Hp 2610 paper jams on print command. Paper pulls sideways.
find the paper feed rollers and clean them. they get slick and one side will catch quicker and pull the paper side ways.
Aug 12, 2010 | HP Photosmart 2610 All-In-One InkJet...
Paper jams
If you have some small twiser like you use to pull those nasty nose hairs, and pull the paper out with that. If that doesn't take a air compressor and gently blow it. A compress air will have some moisture in it and you don't want that to get on to the rollers.
Nov 11, 2009 | Canon PIXMA MX310 All-In-One Printer
I removed a stuck piece of paper. Subsequent paper is pulled in and then is pulled sideways and then gets stuck. I have looked for more stuck paper and can not find anything. I replace the top roller...
The paper skews either because there is obstruction in the paper path in one side or the roller/counter rollers are not exerting even pressure on the paper. You need to check this.
S. Mohan
Oct 15, 2009 | HP Scanjet 5590 Flatbed Scanner
HP scanjet 5590 pulls the paper half the way in and then starts pulling sideways and then gets stuck.
Have you checked to make sure there isn't previously jammed paper in the feeder?
It sounds like the paper is getting stuck on just one side which is causing the paper to start going sideways.
I had to pull a piece of paper from my printer to
Go through the settings menu and find the system default settings button and hit it. This will restore the unit back to factory settings.
Sep 16, 2009 | HP Office Equipment & Supplies
Paper not feeding right
you need to take all of the paper out then fix the paper so it is all aligned then place the paper back into the paper holder still all aligned this should then prinbt properly
Jul 22, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Paper Pulled in Squint
I had a similar problem; paper would go sideways when it was trying to pull it through. I looked into the paper slot with a mirror and found a mini-blind clip had fallen into the printer. I tipped the printer over and shook it out and it worked fine.
Nov 19, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Epson Stylus CX5800F All-In-One InkJet Printer Logo
14 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
