Question about Motorola Mobility H371 Bluetooth Headset
On/Off button does not work
After charging my device for 4 hours, it does not turn on when I push on the On/Off button. I do not sense a discernible 'click' when I depress either the On/Off or the 'call' buttons. I am wondering if either or both are stuck in the 'down' position. Is there a solution to this powering up problem or do I just discard the device? Any help would be appreciated. PS The charging light does come on when charging, however it has not changed color. It appears to be in the purplish phase.
4 Suggested Answers
SOURCE: motorola hs820
I am having the same proble too..I am going to open it up and see if I can fix it, I'll keep u guys posted...
Blazemorefire..
Posted on May 26, 2008
SOURCE: H500 is not responding when i click the call button
make sure the bluetooth is off. then turn it on, but keep holding the button until the light is a solid color. then it is in pairing mood.
Posted on Apr 20, 2009
vqcb43
  • 1623 Answers
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: How do you turn on a motorola v710 after is has charged
    Bonnie
    Press and release power button for 3 seconds until you see screen light up.
    Mark
    Motorola Support
    Posted on Jan 03, 2015
    How can I change the battery in m9100 kocaso
    Try the follow to see if it will fix it:
    There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
    If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
    After performing the power reset on the device the device will behave in one of the following ways:
    1. The tablet will turn on like normal.
    2. The tablet will show the battery icon only.
    3. The tablet will show nothing on the screen at all.
    All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
    Then most likely the battery will need replacing.
    Here is a link to where you might be able to get a new battery:
    Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
    Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
    Problem with my tomtom go 910, was working perfectly until i went on vacation for five weeks. Went to use it and could not switch it on so i thought the battery must be low, so i was going out in the car...
    1. Connect the GO to your home charger and charge it for at least two hours. You need to charge your ONE or GO300 for at least 2 hours using the 12-24V cigarette lighter adapter in your car.
    2. Check if the green light on your GO lights up when connected to power (RIDER does not have this light).
    3. Leave your GO connected to the power cable and RESET it using a straightened paper clip
    4. Press the ON/OFF button for at least 3 seconds.
    To reset your TomTom device:
    1. Charge your device.
    Charge your device for at least 2 hours. Make sure the charging light on your device is on (except RIDER which has no charging light).
    2. Remove the SD card.
    If your device uses an SD card, remove it.
    3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button. For a visual representation of the reset button, see below.
    4. Turn your device on.
    Press and hold the On/Off button for at least 4 full seconds.
    5. Insert the SD card.
    If your device uses an SD card, insert the SD card.
    Always make sure that you are using the latest version of the TomTom application on your device. You can update the application through TomTom HOME. If you use more than one storage card you need to update the application on each card.
    Apr 04, 2008 | GPS
    Tip
    Reset you TomTom password.
    To reset your TomTom device, do the following:
    1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
    Press the On/off button for at least 5 seconds.
    on Feb 07, 2010 | GPS
    I have had this product since Christmas this past year and it has worked perfectly but just recently it died completley and i have charged it for more than a day but it still won't turn on. I've tired...
    Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
    Support Troubleshooting Guide
    Aug 24, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
    Will no turn on after charging
    Jul 01, 2014 | Kocaso Tablets & eReaders
    Wont turn on
    How do you turn it on ? Power button needs be pushed left to turn on, right is locking device.
    If this does not work, check charging the device. Plug it in charger for 4 hours.
    If all this is OK, you should reset device
    Hold power button on left for 8 seconds. Release, then restart normally.
    Sep 26, 2010 | Garmin nuvi 750 GPS Receiver
    Im locked out and I cant remember the password my brother set up for me what do I do to unlock my tom tom one?
    To reset your password try this. To reset your TomTom device, do the following:
    Feb 07, 2010 | Tomtom ONE XL GPS
    Bluetooth headset doesn't hold a charge very log
    hold call button down till it blinks, than youll get intermitant light for about 30 seconds, than youll know its on. to turn it on hold call button down till it starts blinking at least 6 seconds. to turn it off hold call button down , itll blink for about 3 seconds than move your thumb off and when it ceases to blink its off. good luck
    Jan 12, 2009 | Jabra BT350 Bluetooth Headset Headset
    Garmin 750 - 90 days old
    Had the same problem-try this- leave your nuvi off for about 4 hours. Push the power button to the right(lock position) and then to the left (power on position) and let go. I suspect temperature (getting overheated is the problem. This worked for me.
    Aug 25, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
    Blank screen
    images of where to find the reset button can be found here.
    Sep 04, 2007 | Tomtom ONE Regional Car GPS Receiver
    Motorola Mobility H371 Bluetooth Headset Logo
    106 people viewed this question
    Top Motorola Mobility Radio Communications Experts
    Coss
    Dennis
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
