Question about Aluratek 2.5" RFID HDD Enclosure (AHDURS250F) Serial ATA, USB 2.0 External Drive Case
Blue indicator lights stays on - Aluratek 2.5" RFID HDD Enclosure (AHDURS250F) Serial ATA, USB 2.0 External Drive Case
I have two questions, first my speedometer won't light up, and my high beems won't stay on. And when I put them on it knocks out the headlights. Please help
18538624 Indicators and high beam lights on dash cluster ...
surf.dev.kinday.ru/.../t18538624-indicators_high_beam_lights_dash_clu...
18538624 indicators and high beam lights on dash cluster turn on and wont turn off. ...The high beam indicator light stay on my dash, I have a 2002 HD night train. ... wontwork and the blue indicator light wont light up when the switch is turned to high beams.. the lights ... remove install instrument cluster speedometer cable.
Cluster/Gauge lights out, highbeams dont work, no fuses ...
www.rx7club.com/.../cluster-gauge-lights-out-highbeams-dont-work-no-...
Feb 17, 2012 - My gauge lights decided to go out one night and I can't find any reason why. ... are on works on my dashboard but the lights behind the gauges don't (speedometer/rpms/gas/temp) and my highbeams wont work. .... My foglights stay onwith the headlights. ... If that's the case someone hacked up some wiring.
Oct 24, 2015 | Cars & Trucks
CHARGING HOW LONG
Blue Light staying on is a sign that it is in pairing mode. Depending on your headset the charging indicator is different. Consult your owners manual or http://www.motorola.com/support
Mark
Motorola Support
Jun 08, 2014 | Motorola Radio Communications
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Jun 23, 2010 | Lenovo IdeaPad Y510 Notebook
Blue thermostat light comes on after driving for 5 miles or so and stays on; after driving for 20 miles or so on occasion the oil pressure light comes on when car slows down and is idling.
when the thermostat in a beetle goes, it stays in the open position, so it could be you blue light is indicating a "cold system",change the thermostat.
the oil light will come on if low on oil or you have a low pressure,try using 10/40 semi synthetic oil.and mloyslip.if no improvement you will need to renew the oil pump.
Jun 18, 2010 | 2002 Volkswagen Beetle Turbo S
Non-responding screen, blue indicator light?
I also got this blue screen,
I fixed it wiit a registry tool, it is powerful suggest you have a try!
Fix blue screen now.
Download blue screen fix tool.
Feb 28, 2010 | HTC G1 Smartphone
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
Blue low engine coolant temperture indicator light is on
I also recently bought a 2002. According to the owner's manual the blue light does not indicate a problem unless it stays on after the car warms up. If you have an automatic it will not shift into fourth gear until the coolant warms up at which time the light should go off. Have only had the car for a week and notice the blue light goes off after a mile or two of driving in temperatures in the teens to 30's. I don't know how much outside temp affects it.
Mar 13, 2009 | 2002 Toyota ECHO
Aluratek 2.5" RFID HDD Enclosure  (AHDURS250F) Serial ATA, USB 2.0 External Drive Case Logo
44 people viewed this question
Top Aluratek Computers & Internet Experts
Ed Mac
Brett Duxbury
Brett Duxbury
Are you an Aluratek Computer and Internet Expert? Answer questions, earn points and help others
