Question about Coleman Roadtrip Grill LXE 9949-750
How to take burner knobs off - Coleman Roadtrip Grill LXE 9949-750
    Master:
  • 495 Answers
It looks like they just pull off. Give them a good tug without using tools. coleman com
Posted on Jun 03, 2015
Center control knob/burner
yes.. you can replace the burner... but you can still the burner for any possible dirt blocking the gas out on each hole...
micro
Jun 07, 2008 | Weber Genesis Silver B Grill
Orifices burner flame adjusted
Most burners have an adjustment under the knob. Pull off the knob and use a slender flathead screwdriver. Turn burner down to low, insert screwdriver into knob shaft and rotate internal screw until flame is at "simmer" height. Can adjust each burner separately this way.
Jan 17, 2014 | Kenmore 71042 / 71044 Gas Kitchen Range
Hello, My Creda cookertop ignition system has a problem . There are 4 burners on this CT. 2 diagonally across burners cannot ignite when their knobs are activated but they show sparks of ignition when the...
(1) Get Naval Jelly (Rust dissolver) and apply on the igniter and than see if everything is fine.
(2) Check the connections from the knob to the burner. Probably have a leak. Replace the wire from the knob to the burner.
Feb 02, 2011 | Cooktops
Jenn air downdraft cooktop. We had a new Jenn Air
This is normal, Jenn Air along with many manufactures use one ignition module for all the burners. So when you turn one knob on all the ignitors on top will spark but gas will only flow to the burner with the knob on.
Here is a copy paste from a Jenn Air Owners Manual, I do not have your model number so I cannot be sure this is the exact phrase in your book.
I hope this helps!
To Set:
1. Push in and turn knob counterclockwise to light the burner.
All surface burners will click. Only the burner that has been
turned on will produce a flame.
2. Turn knob to anywhere between HIGH and LOW. Use the
following chart as a guide when setting heat levels.
May 02, 2010 | Jenn-Air Freezers
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
Both 6'' & 9'' burners come on however I turn the 6/9 knob.
may be a problem with the switch itself, but honelstly dont take offense but make sure the knobs are on correct knob stem, it squite common for someone tho clean the knobs and not put them on correct valves
Nov 16, 2008 | GE Kitchen Ranges
Replace burners
remove the cooking grates and the 5 pieces ubnder the grates covering the burners from the grill. Next remove the 4 screws on either side of the control knob panel pull it away from grill and pull the burners out from inside the grill. DO the reverse to install new burners
Apr 19, 2008 | Ducane 30400042 (LP)
Burner light does not go off on Amana AKT3040
Sounds like a short in that particular burner circuit. Usually when the light stays on even after cool down the heat sensor is bad. This is inside the burner. If your getting white smoke the burner switch could also be shorted out.
Apr 05, 2008 | Amana AKT3040 Electric Cooktop
Coleman Roadtrip Grill LXE 9949-750 Logo
205 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
paulcarew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
