Question about Dishwashers
FDB1050RES2 motor works only when tapping with hammer
Our Frigidaire dishwasher (model: FDB1050RES2) pumps water in, but doesn't wash. I removed the kick plate and, while the wash light was on, tapped the motor and it turns on, but sounds rough and really struggles to stay on. It sort of sounds like a propeller plan losing power. It doesn't ever stay on, and the wash cycle never successfully works. When I cancel, it successfully drains water. Any ideas what to check?
4 Suggested Answers
  • 7 Answers
SOURCE: another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Posted on Nov 02, 2007
QueenJLyn
  • 3 Answers
SOURCE: Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Posted on Aug 01, 2009
  • 5 Answers
SOURCE: maytag dish washer makes loud humming sound, I
Itcould be something caught in the impeller or filter area
Posted on Jul 21, 2010
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer
Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Jun 29, 2011 | Maytag Dishwasher
Wtaer will not drain. what are things to check.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
Hope it helps...
Jun 24, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Frigidaire Dishwasher model FGBD2431KW will not completely drain after wash cycle. What might cause this?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 15, 2011 | Frigidaire Dishwashers
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Upperrack water pressure
1)check the wash motor is freely rotating. 2)any jam in the wash motor.
Jun 03, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishes are not being cleaned because the water is not spraying out. water is collecting at bottom only, element getting hot, parts are all moving freely. Frigidaire, model #FFBD2405KW
Hi Beetlezombie,
Some times the spray arms get blocked with old food particals, if you can remove them(pull them off) use a hose to rinse them out and tap them against something hard(don't bash them) refit and try.. Or the wash motor has given up, you should hear it try to pump out water, if it doesn't pump, then the WM has died... Cheers
Mar 29, 2010 | Frigidaire Dishwashers
Dishwasher water will not circulate
The pump or motor is not working check if the motor is getting voltage about 115 volt during the wash cycle
Aug 04, 2009 | Dishwashers
Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Mar 20, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Dishwasher Repair
Ebers, you have a seperate wash and drain motor on this model. When you remove the bottom panel the drain pump will be on the right and the circulation (wash) pump will be in the rear. You are going to have to verify that you have power getting to the wash motor. Sometimes this is difficult without removing the dishwasher. The motor may have a quick connect harness going to it that you can check voltage there. If you have voltage to the motor during the wash cycle and it's not running, well, there's the problem. If no voltage, then it's probably a timer issue. Catriver..post back
Feb 05, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
Owen Barnes
