Question about ASUS P4P800E Deluxe (90M8LCW0G0EAY) Motherboard
Alarm sound coming from hard drive
Can u tell me why i would have an alarm sound from my hard drive and why my new monitor is not showing that it is getting a signal
  • 2 more comments
  • sophie0777 Feb 20, 2008
    i have a alarm sound when turning computer on, it sometimes doesnt stop. its two sounds. i know my tower has been damaged externally in transit before i recieved it. is it fixable?
  • laffingravy Sep 03, 2008
    The alarm sound from a hard drive is sometimes caused by internal damage. Imagine the armature dragging across the platters, reaching the center and returning to the outer edge to repeat the process. Much like a record needle skipping across an lp. It does indeed sound like a car alarm, with repeated whoops in a loop. I know of no cost effective cure for this problem other than replacing the hard drive.
  • jsmickelsen Mar 07, 2009
    my computer makes a loud alarm sound when it has been on for a long period of time. Sometimes even shutting the computer off doesn't stop the loud alarm. My computer is brand new and was custom built. What can I do to make this stop? Could it be caused due to the tower having too much dust inside it?
  • Anonymous Apr 05, 2009
    i have this too! but it only happens when i play counterstrike source. it could happen with other games, but i don't play much on my PC. what should i do? i asked my IT man (the person who actually built the computer, and he had no clue. help?
  • 24 Answers
I'm assuming the alarm sound would be coming from your computer tower...in this case, what does the alarm sound like?  1 long, 2 short?
It sounds to me like your video card failed on you.  I assume you're posting here because your computer has this specific motherboard.  If you're comfortable opening your computer, you may want to make sure that your video card is set properly in its slot.  It will be in the brown component slot above all the white component slots.  Try to gently push it in first.  To really make sure it's seated properly, take the card out & put it back in.  If you're not sure how to do it or you're not comfortable doing it, then leave it alone.  Chances could also be that your video card is good, but something failed(slot, circuit, etc.) on the motherboard.
Another possibility is a bad setting in BIOS, which can cause errors.  In this case, you'd have to reset it, which also requires opening your computer.
Do you remember what you were doing on the computer before this happened?
Posted on Oct 27, 2007
Cutts on and off
Sounds like a bad power supply or hard drive. Try replacing the hard drive first and see if that cures it. Otherwise, the DVR could be bad.
Mar 20, 2014 | Samsung SDE-120n 4 Channel DVR System
I bought a new HP home computer, but I would like to use my previous Monitor which is bigger and is a Dell, so when I changed to my Dell monitor with my HP hard drive, there was no longer any sound coming...
new to you , its very old, and officially retired at HP.com
its 14 years old today. yah, old. last one sold at $30(fleabay)
what ever OS (windows) it runs its not safe on the internet.
windows 2000? or XP?
called legacy now. (means zero support at HP and MS)
no dell monitor stated, endless kinds over 20 years. made.
what makes you think the dell has speakers/ lacking the 3.5mm
phone jack
on it. did you forget to plug the sound cable in?
the hard drive has nothing to do with sound.
one can boot to a LINUX CD and play music all day long.
a fact. same with booting to USB thumb drive.(linux)
why not buy some external speaker, for $10 or at Goodwill(tm)
stores. dirt cheap or heck , upgrade to good sounding speaker
no monitor can ever do that. well.
good luck and next time tell the helper what DELL that is.
the model is on the sticker on the back most times.
Jan 14, 2018 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
My dell Optiplex GX270 will not start up. it gets to the microsoft xp loading screen and it begins to load but then it restarts. it gives me a message "the primary IDE master hard-drive self...
Sad to say, you need a hard drive. The clicking sound you're hearing is typical of a drive that has gone bad. The monitoring message you see is from the motherboard's SMART monitoring, which checks several drive parameters and tells you when something is out of normal range. Often this gives some advance warning of a drive going bad, but this time it's just another sign the drive is already bad.
Installing a new hard drive is quite simple, with only two cables to plug in and some screws holding the drive in place. You will need to reinstall Windows and your applications since the new drive will be blank. There isn't anything you can do to repair the bad drive. If you have data on the drive that you don't have backed up on some other medium and you must have, there are companies that offer data recovery services. Just be aware it can be expensive.
Sorry I can't give you better news, but thanks for using Fixya.
Nov 11, 2010 | Dell OptiPlex GX270 PC Desktop
When i m starting my laptop S.M.A.R.T hard drive failure is showing.how 2 recover this warning ? this warning is showing since last 4 days.plz tell me the solution
If it gives a warning that the hard drive is about to fail, it means the hard drive will fail soon and that you should back up your data while you have a chance.
When the hard drive fails then you need to replace the faulty and install Windows on the new hard drive with the laptop's device drivers and your programs to get a working laptop again.
Nov 07, 2010 | Computers & Internet
There Was alarm sound coming from the hard drive i pulled the power line out of the drive waited then reconnected now there?s no blue light on the drive and no communication with the pc the drive is...
It sounds (pun intended) like the disk-drive inside the casing overheated, and that created the alarm. Unfortunately for you, it seems to have been a "fatal" problem.
If your drive is still under warranty, W.D. will replace it.
If not, W.D. has a "Customer Loyalty Program" -- you can get a discount on buying a new My Book from W.D.'s web-site, because you currently have a W.D. product.
Jul 07, 2010 | Western Digital My Book Essential Edition...
Tower turns on and cpu fan is running cd drives all respond and open. Monitor comes on then appears to go into sleep and will not show any screen, recently tried installing a new hard drive after have...
Have you tried another video card? Or even another monitor? If not, could be the motherboard especially if the video card is integrated into the motherboard.
Jun 23, 2009 | Compaq Presario 5000 PC Desktop
Loud buzzin sound on start up
If the POST screen is coming up, showing the the correct amount of memory in the system, and then telling your hard disk failure or something similar, your hard drive has failed. Put a new hard drive in the system, reload your operating system and all drivers, and attempt to use the old hard drive as a second drive long enough to get any files you need from it.
Dec 31, 2008 | Azza Xion II Series Gaming Computer Case...
Hard Drive Alarm & Refuses to boot up
Either your OS is corrupted or you have a serious hard drive issue. Not uncommon for the latter to go without any real warning.
Get a hold of the diagnostics software for your drive and run it. Don't be surprised if it fails.
May 05, 2017 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
New Hard Drive Dell Dimension 3000
Theres a problem with your driver installation.your computer is newly formated and wiyh a new harddrive but still theres a problem.check your monitor if it can support up 1024/768 pixel so that you can adjust your screen resolution to a smaller icons.also check your vga.and rollback device driver for sound device.
May 29, 2008 | Dell Dimension 3000 PC Desktop
Hard drive making strange alarm/chiming noise and won't load onto desktop
Listen to your power supply and see if it is making a faint buzzing noise. Try your device with a new power supply. With a new power supply my drive now runs fine, and was not corrupted.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
ASUS P4P800E Deluxe (90M8LCW0G0EAY) Motherboard Logo
4,317 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
