Question about Targus Wireless Optical Notebook Mouse PAWM10U
No usb receiver - Targus Wireless Optical Notebook Mouse PAWM10U
I have a thompson ths220 recorder and am unable to record programmes. I go in to epg menu and book a programme but the usb file is not compatible
It is possible that the USB drive is not formatted to the required specification (FAT/FAT32).
Please visit the following link and update to the latest firmware - http://www.thomsonstb.net/en/products/satellite-receivers/ths220
You'll also find a Manual there.
As per the manufacturer -
It is recommended to use USB 2.0 storage devices. If your device is not compatible to USB 2.0 specifications, multimedia functions of the receiver might not work properly.
THOMSON cannot guarantee compatibility with all types of USB storage devices.
It is advised not to store important information on USB storage devices used with the receiver. Always make backups of data on your USB storage device before using it with this receiver. THOMSON will not take responsibility for any loss of information or circumstances caused by loss of information.
Please ensure that either the USB device is already formatted to FAT/FAT32, or format the USB device via your receiver.
May 30, 2014 | Computers & Internet
My logitech mouse M215 is not working, at first i taught that it was just the battery but when i replace it instead of having a yellow light in the led it appears to be orange, i just want to know what is...
This problem is likely to be a lost connection. The connection between the mouse and the USB receiver can be lost due to several reasons such as:
  • Low battery
  • Moving the USB receiver from one USB port to another
  • Moving the USB receiver to another computer
  • Plugging the USB receiver into a USB hub or other unsupported device such as a KVM switch (your Unifying USB receiver must be plugged directly into your computer)
  • Using your cordless mouse on metal surfaces
  • Radio frequency (RF) interference of more powerful wireless devices such as:
    • Wireless speakers
    • Computer power supplies
    • Monitors
    • Cellular telephones
    • Garage door openers
Eliminate any problem sources mentioned above that might be affecting your device.
May 11, 2011 | Logitech Computers & Internet
What is a receiver for a wireless keyboard?
Hello.
A receiver is a small usb stick included with your wireless keyboard and mouse. It receives the wireless signal from your mouse and keyboard and send it to your computer.
Sometimes it looks like a usb flash drive or a plastic thing with a usb cable to plug in your computer.
Hope it helps!
Feb 09, 2011 | HP USB Wireless Keyboard/Optical Mouse...
Why does my usb plug-in not function
If your receiver simply doesn't reconize the usb, than try a hard reset to the receiver. To do this, power the unit on, than unplug power to it for about 15 seconds. Another item you can check is the type of files that your music is on your usb. It is possible that your receiver is not able to play that type of file. If thats the case try downloading a different format of music onto your usb and see if that works.
Good Luck
Jan 07, 2011 | Audio Players & Recorders
Keyboard does not type
If all the keys on the keyboard have stopped functioning follow the instructions below to reconnect the keyboard.
This problem is likely to be a lost connection. The connection between the mouse and the USB mini-receiver or the keyboard and the USB mini-receiver can be lost due to several reasons such as:
  • Low batteries
  • Moving the USB mini-receiver from one USB port to another
  • Moving the USB mini-receiver to another computer
  • Plugging the USB mini-receiver into a USB hub or other unsupported device such as a KVM switch (your USB mini-receiver must be plugged directly into your computer)
  • Using your cordless mouse/keyboard on metal surfaces
    • Wireless speakers
    • Monitors
Eliminate any problem sources mentioned above that might be affecting your devices.
Follow the procedures below to reconnect your mouse and keyboard.
  1. Make sure the USB mini-receiver is directly and securely plugged into a working USB port on your computer.
  2. Make sure the mouse is turned on. The on/off indicator on the bottom of the mouse should be green. If the on/off indicator is not illuminated, press and hold the red connect button on the bottom of the mouse until the on/off indicator is green.
    On / Off Indicator
  3. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your mouse. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  4. Quickly press the red connect button on the bottom of the mouse for 1 second, then release it. The power indicator will flash briefly and then turn green. The mouse is now connected to the receiver.
    Red Connect Button NOTE: Holding down the red button on the mouse for more than 2 seconds may cause your mouse to turn off instead of connecting. If this occurs, start again at step number 2.
  5. Move your mouse to see if the cursor moves. If the cursor follows the mouse movements, your mouse is now connected.
  6. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your keyboard. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  7. Quickly press and release the red connect button on the underside of the keyboard.
    Keyboard Connect Button
  8. You will hear a short beep. The keyboard is now connected to the receiver.
  9. Test your keyboard to see if it is working. If the mouse now works but the keyboard still does not, see Knowledge Base article 9144.
Dec 14, 2010 | Logitech Cordless Desktop MX3200 Laser...
Will not connect..its not in sync with my pc
Hello
Turn the switch to the "On" position, located underneath your mouse if your mouse has a switch.
Restart your computer to have a fresh starting point for troubleshooting. Sometimes, just restarting your computer can resolve issues you have with your HP wireless mouse.
Move your HP mouse about 39 inches away from your receiver.
Unplug your USB receiver, if you have one, and wait about 10 seconds.
Replug the USB receiver into another USB port, closer to your mouse if possible, then resynchronize your mouse and receiver.
Press and hold the connect button on your receiver, while plugged in, until you see the LED light flash.
Hold and press the connect button underneath your mouse until the LED light on the receiver stops flashing.
Check to make certain the button under your mouse does not get stuck in the depressed position and releases. Also, make certain you complete this resynchronizing process in 60 seconds, or else you must start over. Your mouse will now have a new identification number from resyncing.
Unplug the USB receiver, wait 10 seconds, then replug the receiver firmly into the USB slot, pushing it in entirely. You will notice the receiver's activity light turn on, then off in the next five seconds.
Press the connect button underneath your mouse until you see the activity light turn on again on the USB receiver.
Check to make certain the mouse connect button does not remain depressed when you release it.
Nov 14, 2010 | HP Wireless Optical Mouse
Cannot get mouse to work
1.
If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2.
Restart the computer. This can resolve the problem, at least temporarily, so that other troubleshooting steps can be applied.
3.
Move the mouse or keyboard closer to the receiver
The receiver is the hardware that receives the wireless signals from the keyboard and mouse and communicates the data to the computer. Most receivers connect to a USB port, either directly or by a cable, but a few types of receivers connect to the PS/2 ports.
. Make sure that the keyboard and the mouse are within 100 centimeters (39 inches) of the receiver. If the receiver is attached to a cord, position it so that it is on the same level surface, close to the mouse and keyboard.
4. Replace the batteries with a fresh set of alkaline batteries and make sure they are correctly installed. If the mouse or keyboard is not working, then replace the batteries, even if the mouse/keyboard software indicate the batteries still have a charge.
Remove the battery cover to access the batteries. For keyboards, the battery access cover is found on the underside of the keyboard. When replacing the batteries look for the positive symbol (a plus sign +) imprinted near the battery compartment or battery cover. Make sure the positive end of the battery is oriented to the positive side of the compartment.
5.
If you have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert it into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
6.
Resync the wireless keyboard and mouse connections.
Resync the keyboard and mouse connections for receivers with a connect button .
Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers.
NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
Sep 10, 2010 | HP Wireless Optical Mouse
" USB ERROR "
Hello kenwood12312,
With the receiver OFF, remove the USB device then turn the power ON. If the same display is repeated, use another USB device. Remove the USB device without entering the remove mode. If this does not work, try resetting the receiver. Press the "reset" button just above the AUX INPUT. This will return the unit to factory default settings. If these steps fail and you still get the USB error, the receiver is faulty and needs service.
Hope this helps.
May 20, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
The receiver doesnt light up when pluged into the usb port
sound like the receiver is down try other usb ports to charge your ipod if it works well it is your new mouse receiver thats capoot
Apr 18, 2009 | Computers & Internet
Wireless Gigaware 26-990 unable to connect
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 24, 2008 | Computers & Internet
Targus Wireless Optical Notebook Mouse PAWM10U Logo
Top Targus Computers & Internet Experts
J John
Laxman Bisht
Laxman Bisht
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
