Question about Whirlpool WED5100SQ Front-Load Electric Dryer
Paper napkin or sock got sucked into lint trap while I was cleaning it
SOURCE: Keep getting error message AF druing drying cycle and I've cleaned the lint trap.
check for clog or kink in dryer vent
Posted on Jun 10, 2009
dawson57
  • 25 Answers
SOURCE: Lint fell down the lint trap. How do I get it
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
Posted on Jul 13, 2009
  • 494 Answers
SOURCE: A small sock fell into the dryer lint trap. How
You can try using a metal hanger to hook it and pull it out, but be sure to unplug the dryer before you try. There is also a small pick-up tool about 2 feet long you can buy at hardware stores for picking up small items in tight places. Good luck fishing!
Posted on May 18, 2010
heatman101
  • 43501 Answers
SOURCE: a sock got inside the
Shop vac and that long skinny crevice tool.......yeah, that will pull that sock right outta there...
heatman101
Posted on Aug 29, 2010
  • 4340 Answers
SOURCE: how to clean a lint shoot on an old whirlpool
Bummer, been there, done that! Try fishing with a coat hanger, bent in a hook configuration. Otherwise, surgery is the only way to extract the sock. UNPLUG the machine before you do anything, just to be safe.
Posted on May 02, 2012
How do I remove a sock that fell through the lint trap?
How To Fix Dryer Lint Trap Problems (Removing Items That ...
? 5:32
https://www.youtube.com/watch?v=Fcw1aPqGiSI
Feb 4, 2015 - Uploaded by UKaToNeN
Have you ever had something fall down into the lint trap on your dryer? It`s happened to more folks than you ...
how do I get sock out of lint filter shoot of electric dryer ...
www.shopyourway.com > Manage My Life > Questions
I'm sorry to hear that a sock fell into your lint screen chute and I would like to assist you. Be sure to unplug the dryer prior to servicing it! Do not run the dryer until you are able to remove the sock! There are two ways to do this.
Nov 29, 2015 | Electrolux Dryers
Bra stuck in lint trap housing on samsung front load dryer
You might need to remove the lint trap or the drum assembly.
Please check this video for tips
Click on Lint trap
Removing drum assembly
Jan 22, 2013 | Samsung WF337AA Front Load Washer
Dryer is not drying the clothes
If it is taking a long time to dry, but still has heat, try cleaning out under the lint trap. Take the whole lint trap off and clean the panel and path the lint is sucked through. I did this to mine and it made a HUGE difference! There was a ton of lint packed around the panel and only a small opening left where the air flowed into the exhaust.
With our dryer (Maytag) I had to take the front panel off to get to the area where the lint was.
Jan 19, 2013 | Dryers
Takes extra time to dry the clothes.
You may need to clean out your lint trap. Not just the part that you pull out. I'm talking about the entire tunnel. Even though we empty the lint trap regularly there's a lot that gets left behind and over time can become a fire hazard. Your arms and hands cannot reach everywhere in there. For this you can attach an old sock or rag to a coat hanger that has been opened up. Go down in there a couple of times with it. You'll be surprised at how much stuff comes out. To further help this problem you can also pull dryer out and check that the vent hose in back is clear and free of debris. Cleaning the trap screen (the part you pull out to empty the lint) with HOT water occasionally will also clear residue that has built up from using dryer sheets. Over time that residue will make those tiny screen holes smaller & smaller & smaller. All of this can affect your dryer's performance.
I hope this info was helpful to you. Good luck!
Jan 29, 2010 | Whirlpool GEW9250 Electric Dryer
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Whirlpool gs dryer and while cleaning the lint trap a peice of papaer about 4x6 fell into the trap -how to remove? Can I still dry clothes w/o starting a fire?
Please DO NOT try using it with the paper in it. You will need to remove the back cover and disassemble the lint chute to remove the paper. When the back is removed you will see the chute assembly on the left side about 8 screws hold it together. There are 2 screws at the top under the flap that covers the lint trap that need to be removed also.
Nov 23, 2009 | Whirlpool Dryers
A clothes pin and piece of paper fell down the lint trap when I was cleaning the screen. How do I reach the pin and paper to get them out?
This may take you awhile to do, but once you get to it you may find a lot more than that down there. You have to remove the back on most all dryers. If the lint trap is on top, there is a metal chute that lint and other objects fall down.Remove the back and you will see what I am talking about.Once this is done, it is fairly easy to remove the collars that go down to the lint hose. You will then be able to clean all of the lint build up down below that gets by the trap.
Good luck, Sincerely, shastalaker7
Oct 30, 2009 | Dryers
A sock fell in the vent of my whirlpool dryer
If you mean the lint trap, try this: Unplug the dryer. With a dryer brush (~$10.00 @ Lowe's/similar), bend to approximate the curvature of your cavity and try to retrieve. If this doesn't work, slide/scoot the dryer out and remove the venting duct. Carry outside and dump. If no sock there, look into the dryer exhaust (where the duct connects). Use the brush again to retrieve said sock (and generally clean as you go, as it never hurts). Also look at your vent where your dryer exhaust passes through the wall, clean as you go..... This should get you back up and running.
Regards, --W/D--
Jul 17, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Sock in lint collector slot
Take a hanger Metal one, stick it down there and twist tell you get a good grab on the sock and pull it out. The other way is to open the back up and get in there. The machine will not work at all cause it can not exhaust
Feb 09, 2009 | Kenmore 62622 Electric Dryer
Whirlpool WED5100SQ Front-Load Electric Dryer Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
