Question about Roper Dryers
Electric dryer cord is frayed
Roper dryer cord where cord itself connects to the litlle metal ring ends
  • Roper Master
  • 8,220 Answers
You need another pigtail that one is no good. Their is no fix. Replacement cord must be installed.
Posted on Feb 09, 2014
  • 163 Answers
SOURCE: My Roper Electric Dryer will not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
kachbibi1
  • 979 Answers
SOURCE: electric dryer blowing cold air
You either have a blown fuse, breaker, burned out element, wiring that has come loose. They all can be checked within 5 minutes. However, I believe it is in the thermal fuse which is located below the top of the dryer. You can access that pretty easy though. To check it, just bypass it and put the 2 wires together and see if it runs. The fuse is only 15 dollars or so. I am assuming you have an electric dryer.
Posted on Jan 26, 2009
mark_37388
  • 100 Answers
SOURCE: Roper electric dryer replaced timer
check the door switch if that is bad it will not start if that is ok there is a white fuse on the blower houseing in the back check it with an ohms meter
Posted on Mar 29, 2009
canbruce75
  • 1776 Answers
SOURCE: Roper electric dryer. Clothes not drying. Temp ok/timer not?
I would supect a faulty high limit thermostat. This small round device is mounted to a metal plate and attached to the internal ductwork. It can be tested using a multimeter or ohmmeter. Test for continuity. It should have none. Hope this helped and best wishes.
Posted on Aug 11, 2009
  • 8404 Answers
SOURCE: I am changing the 3 prong electric cord on my GE
ground the green wire to the frame of the drier.
trust me on this
Posted on Oct 16, 2009
Replacing electrical cord
if you buy a color coded cord and plug then red and black go on thee 2 outer terminals of the power terminal and the white wire goes between these as this is the neutral connection and if it has a green ground wire connect this anywhere to the metal case of the unit, if its a gray cord with no colors then the 2 outer wire on the cord go to the outer terminals on the units power terminal block and the center wire on this cord goes to the center terminal on the unit
Jul 28, 2012 | Roper REX4634KQ Electric Dryer
Swich 4 cord to 3 cord plug in
To switch from a 4 prong to a 3 prong. First remove 4 prong cord, save screws you will need them. Look a 3 prong, it will be flat with 3 wires next to each other with metal fittings on the ends. The 2 outside which are hot wires go to the outside screws on the block, and the center which is neutral goes in the center. The only difference in the cords is the 4 prong has a ground, in new construction this is code. You don't need a ground if house is wired for a 3 prong.
Jun 15, 2010 | Roper REX4634KQ Electric Dryer
Wiring for three prong power supply cord
If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
Connections
New
Picture shown is for a range cord but is exactly the same for a dryer connection.
Feb 03, 2010 | Roper REX4634KQ Electric Dryer
Is my dryer 220 or 110 volts
If your dryer has a standard cord (looks like a extention cord) than you can not hook it into 220, it is a gas dryer if you have that plug. If you have a electric dryer it will have a much larger plug and vcan only be plugged into 220
Jul 08, 2009 | Roper REX3614KW Electric Dryer
RE: Roper Electric Dryer, front load
You have a ground fault or short . Disconnect dryer and remove small panel that holds the cord. Check if any wires are frayed, loose or touching any other metal objects.
Jun 29, 2009 | Dryers
Where to wire the ground when changing a three prong to a four pr
This cover is all different sizes and shapes depending on the manufacturer of the dryer, but it is typically very close to where the cord enters the dryer. The cover is typically held in place with 1 - 4 screws. See image to the right of a Maytag Performa dryer access panel.
04b796a.jpg With the cover open you will see a terminal block with three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nutdriver to remove the nuts or a phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Now you need to install a bonding jumper from the neutral terminal to the dryer’s frame. The bonding jumper is either a metallic strap (typically copper or copperclad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame.
Installing this bonding jumper is an extremely important step when changing from a 4-wire to a 3-wire power cord to prevent electrical shocks when touching anything metallic on your dryer.
If you do not have the original bonding strap, you can make one. You need a short piece of green 10 AWG wire, 2 ring terminals, a pair of wire strippers and a pair of crimpers. Strip both ends of the green 10 AWG wire and crimp one ring terminal onto each end of the wire. Now connect one end of the wire to the neutral (center) terminal and the other end to the dryer’s frame; where your ground is connected now. a9fc1b2.jpg Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. To hook up your new 3-wire dryer cord, connect each wire to the dryer’s terminal block. The 2 outer wires are your “hot” wires and the center wire is the neutral. Replace the access panel cover and your new 3-wire dryer cord is installed Before plugging in your new dryer cord, I recommend turning off the breaker to your dryer receptacle. Then plug in your dryer. Now turn the breaker back on. This is not fool proof, but it is a safer way to turn on the power to your dryer if you made a mistake connecting your new dryer cord.
If your dryer is different from the one described above and would like a second opinion on your connections, email a picture of the terminal block to info at ezdiyelectricity dot com. I will post the pictures on this page to help others with the same dryer.
Apr 05, 2009 | Whirlpool LER4634J Electric Dryer
Roper Dryer
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Mar 02, 2009 | Roper Dryers
Cord Connection
If your dryer cord is flat and gray, then simply attach the two outside wires from the cord to the left and right screws on the terminal block. Connect the center wire of the cord to the center screw of the terminal block. The only important wire is the center wire of the cord goes to the center screw of the terminal. The two outside wires don't matter.
Jun 13, 2008 | Roper RES7646KQ Electric Dryer
Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Apr 28, 2008 | Lakewood 2727 Heater
Dryers Logo
54 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
