Question about Cameras
Changing picture quality - Cameras
My monte camera gives a blured picture .i m upset with that.plse help me right nw emal me on physics_chemistry12@yahoo.in
hi
you can enhance your picture quality by setting quality high in camera settings option.you can also change your resolution.check your camera settings in your mobile and set the resolution or change the quality high.
thank you
Dec 17, 2010 | Samsung S5620 Cell Phone
Need to change to picture quality , reduce file to email format
Go into the Shooting menu and select "Quality." Set to Standard to reduce quality and file size.
Feb 04, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Hi i have a problem with my digital camera kodak m763
There is nothing you can do to change the quality of the picture you have already taken. But for future pictures please change the resolution within Menu, Camera Settings, picture Quality (it shows stars)
Jan 02, 2010 | Kodak EASYSHARE M763 Digital Camera
When I download pictures from my sony cybershot 3x they are all 48 inches wide - huge, so they are taking up all the memory on my camera and computer. How do I change the size yet keep high resolution? ...
well if you want the pictures smaller effectively you will lose quality. There are many options here. Keep the high quality ones you want and plan to possibly need that high of quality, then the rest convert to a lower quality. You can also just change the settings on your camera so that all the pictures are a lower quality. Also what format are the pictures in right now?
Thank you,
Lee
Dec 24, 2009 | Cameras
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
Taking Picture Problems HELP!!! PLEASE!!!
It could be the picture quality you are taking is set to high quality and the manual gives the higher figure in lower quality pictures.
You can go to menu/ settings / quality and change these to a lower resolution.
Hope this helps.
May 14, 2009 | Sakar Spider-Man 3 Digital Camera
I have a panasonic DMC-Fz8 12x optical zoom camera. How can I adjust the resolution? When I get my pictures developed they are low resolution; you can see the pixels.
Hi!
You need to change the PRINT SIZE and image QUALITY to have have a better picture. Try these:
Press 3049231.jpg then select aa5a871.jpg(Picture Size) . You will be given an option for the number of
pixels - ranges from 0.3 to 7 Megapixel. For better print quality, select 7M.
Next thing that you need to change is the Quality. You need to go back to Menu then 4e59df3.jpg. These are your options for quality:
I hope that helps.
Good luck and have a nice day!
Oct 02, 2008 | Panasonic Cameras
The picture quality is suddenly way too low on my fujifilm finepix f30. not sure how to change the setting to the best picture quality again with highest resolution again?
Look under *mode menu*, this will have options for both picture quality and ISO settings.
This could be an ISO setting on a fuji since high ISO degrades the picture a lot without a lot of obvious noice. The lower the ISO, the higher the quality of the picture, but gathers the least light. If low light (indoors or twilight) raise the ISO, or lower it with good light.
Jun 16, 2008 | Fuji Cameras
My pictures are not the quality I expected. What can I do?
Use the Quality setting on your camera to select a picture resolution. To change the quality setting: Press the Menu button. Select Picture Quality, and then press the OK button. Select the Picture Quality setting you want to use, and then press the OK button. Press the Menu button to exit the menu. NOTE: The setting remains until you change it.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Pictures are not the quality I expected
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
