Hp color laserjet cm1312-mfp
The screen on the control panel is white. It was the normal black with graphics and working. I swept my hand gently across the panel to remove a bit of dust and the screen went white as my hand brushed over it. The usual calibrate and cleaning cycles are continuing and I can copy. However, I cannot access the menu screens. It is cold and very dry today. Could this be a static electricity issue? Any other ideas?
SOURCE: HP CM1312 nfi MFP laser
Sikna says,
The problem was/is HP did not lubricate the drum wiper blades at all.
Excerpt from HP Statement: "In extreme cases the blade can be ripped off the cartridge and be found inside the printer."
HP Official Statement on this Problem:
http://74.125.95.132/search?q=cache:4hUOPOsNqFgJ:www.ussco.com/Email/OfficeLine/08_28_08/images/TonerCartridgeIssue.doc+grinding+OR+noise+OR+squawk+%22cm1312%22&hl=en&ct=clnk&cd=15&gl=us
Methuselah Drum Padding Power solved the problem for me and my customers.
http://www.mruserfriendly.com/orders2//p355.html
Sikna out...
Posted on Dec 08, 2008
SOURCE: touch screen on hp laserjet m 3027 mfp not working
turn of the printer. Hold the C and # buttons and turn on the printer. When the screen goes black it will be ready to be re calibrated. there is a white dot, touch it with a pen, another white dot appears, touch it with a pen. It will continue to turn on now with a newly calibrated screen.
Posted on Nov 25, 2009
  • 313 Answers
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
walid_sayed@hotmail.com
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Posted on May 07, 2010
SOURCE: paper jam inside HP Color Laserjet CM1312 MFP, not
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Posted on Oct 12, 2010
puertobori
  • 7733 Answers
Go to HP Support at -> HP Support & Drivers 1
How do control overtonning for gestener 1312
Dial HP Technical Support Phone Number 1@8@7777@88@96@9 for you to helpline number like, setup & install, hp printer customer service phone number and etc.
hp-printer-customer-service-phone-number-1877-778-****-jkyrmota2pdsmwgougvljebf-5-0.jpg
Sep 18, 2014 | HP Office Equipment & Supplies
I owned HP CM1312 mfp. I have problem with color prints. No any color is printed except black. I changed dc controller but the problem remains... Could you please help?
I hope you did calibration..The Flat cable from laser scanner assm to DC controller is very short & narrow, while connecting it to DC board little bit it will come out at scanner assm PCB, remove upper portion up to laser scanner assm refix flat cable both ends of DC & laser pcb. fix all back & try.. I hope it will resolve the issue.. Best of luck...
Sep 27, 2011 | HP Laserjet CM 1312NFI Color Printer
Bought a new macbook air and want to install my Color LaserJet CM1312 MFP. when connected via USB the printer prints. however if i use the set up assistant, the printer is not recognized. can not install...
Deleting the printer and then reinstalling it using the Gutenprint Drivers for the HP 1300 Series in the Add Printer pull down will allow you to print B/W. This works wirelessly over an Airport Extreme, so I assume that it will work wired. I am searching for a solution that prints in color. Amazing that HP and Apple seem content to orphan such a widely-used and relatively recent MFP.
Sep 05, 2011 | HP LaserJet CM1312 All-In-One Printer
Hp clj cm1312 mfp firmware corrupt ready 2 download, What to me to do? Help, please
You will need to apply the firmware to the machine. I've attached the link to hp site for you to download the firmware file as well. Below the link is the directions on how to accomplish this, as well you can see the same directions on via the link provided
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3558902&prodNameId=3558903&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=t2-85206-1
Firmware Update Notes:
  1. The Firmware Update Utility uses the USB connection to the printer.
  2. The HP Color LaserJet CM1312 MFP print driver software must be installed prior to using this utility.
  3. The HP Color LaserJet CM1312 MFP printer must be on and in a READY state as shown by the LCD display on the control panel and remain powered on during the entire firmware update process.
  4. Depending on the processor speed of your PC, the firmware update process may complete on the printer before the update status progress bar in the flash firmware update utility on the PC screen completes, this is normal.
  5. Once the update process has started, do not use your PC for any other activity until the process is complete.
  6. Do not power cycle the product or the PC until the firmware update process is complete.
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the file CM1312_MFP_Series_FW_Update-20100616.exe flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate CM1312 MFP driver in the dialog window. If you assigned a different name to the HP CM1312 MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the PC during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Printing Document - Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. If it is desired to verify the update, use the control panel reports menu under setup to print a configuration report. The configuration report will show the current firmware revision in the Product information block, Firmware Datecode: 20100616
Oct 20, 2010 | HP LaserJet CM1312 All-In-One Printer
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
jasbo
jasbo
