Question about ASUS M2N-VM DVI - Motherboard - micro ATX - GeForce 7050PV - Socket AM2 - UDMA133, Serial ATA-300
ASUS M2N-VM DVI fps - ASUS M2N-VM DVI - Motherboard - micro ATX - GeForce 7050PV - Socket AM2 - UDMA133, Serial ATA-300
SOURCE: IDE ports in asus m2npv-vm & m2n-mx motherboards
hi, i have a couple of those boards. they have 2 ide ports on them and 4 serial ports. if youu do get the m2npv-vm, one thing that is weird about it, one faces up from the board and the other lays flat off the edge. also the ports are right next to each other and the polarity (which side you put the ribbon cable stripe on) is opposite each other. so if you don't use a keyed ribbon cable you might hook them up wrong.
Posted on Jan 19, 2008
bhiga
  • 119 Answers
SOURCE: about motherbord drivers
You really don't want to run Windows 2000 on that setup. You should run at least Windows XP instead.
Support for Windows 2000, especially with modern processors like you Athlon64 X2 is limited. You have a good processor and motherboard. It would be a shame to cripple them with an old OS.
Posted on May 26, 2008
Nic61
  • 1073 Answers
SOURCE: need user manual for asus M2N-VM/S motherboard
http://www.asus.com/Product.aspx?P_ID=NRtD7hzBVvkGw0c3
There u go! you will find the manual under the "download"
Or you can click here: Manual
Good luck
Nic
Posted on Apr 08, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: no beeps or monitor signal
Sure, a motherboard can be a dud out of the box like any other part. If you have a known good power supply, processor and memory installed, and the machine doesn't boot and you have no video, the only thing left is a non-working motherboard. Return it to the vendor and get it exchanged as defective.
Posted on Jun 20, 2009
mattofilms
  • 110 Answers
SOURCE: were can i download ASUS M2N-VM DVI - Motherboard
try this site if you wish to scan your computer for missing drivers.
http://drivers.softpedia.com/get/BIOS/Asus/Asus-M2N-VM-DVI-Bios-0113.shtml
OR
downloadable driver:
http://www.howtodrivers.com/model550236.html
Posted on Jul 06, 2009
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
What type of battery does the M2N-VM DVI motherboard use?
Most motherboard BIOS batteries use a 3 volt lithium battery, this is a coin size battery type CR2032
Apr 06, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Hi i have an asus M@n68 vm motherboard. After i have flashed the bios from 0306v to 1006 i was told to reboot but when i reboot it my pc wasn't unable to start can u plz help
sounds like your bios has corrupted.
if you know anyone with an eprom programmer they can remove the chip and re-flash it.
if this is the case there is no-other way to fix it.
May 06, 2011 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Cannot install audio device for my motherboard M@N-VM DVI
First of all make sure you have original(health) diver. Check them on ASUS support page. To do this go to http://support.asus.com/download/download.aspx?SLanguage=us-us Select your products(MOTHERBOARD) Select Series(LGA775) Select Model(M2N-VM DVI) Then select your OS Then find your AUDIO DRIVER.
Then try installing it. If you still get error, let us know about error( error number, what kind error it is...)
Mar 27, 2011 | ASUS M2N-VM DVI - Motherboard - micro ATX...
I need all lan and wan and audio drivers for the M2N-VM DVI
Here is the website with all drivers and you just have to chose the operating system (windows xp , windows 7 etc)
http://www.asus.com/product.aspx?P_ID=fyD1uSu233yBDeCq
Mar 05, 2011 | ASUS M2N-VM DVI - Motherboard - micro ATX...
ASUS M2N VM DVI trouble
You must replace the processor cooler, the fan on it has aged and it's no longer doing its job properly. And use a good thermal paste.
BTW that software was designed to notify you of the temperatures and nothing more, reinstall it immediately.
Jul 09, 2010 | ASUS M2N-VM DVI - Motherboard - micro ATX...
No beeps or monitor signal
Jun 20, 2009 | ASUS M2N-VM DVI - Motherboard - micro ATX...
No monitor signal
have you tried checking the monitor to another computer? it could be the monitor?
if not, could be the graphics/video card, or even the motherboard itself could be faulty!
Jun 19, 2009 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Support DX10
Nope, it is a DX9 integrated solution - not good for gameing
Integrated Nvidia® Geforce®7Series Shader model3.0 DirectX 9 graphics processor
Maximum shared memory of 256 MB
Supports RGB with max. resolution 1920 x1440 (@70Mhz*32bpp/75Mhz*16bpp)
Supports DVI-D with max. resolution 1920 x1200 (@60Mhz)
Jun 04, 2008 | ASUSTeK M2A-VM HDMI Desktop Board - Athlon...
ASUS M2N-VM DVI - Motherboard - micro ATX - GeForce 7050PV - Socket AM2 - UDMA133, Serial ATA-300 Logo
20 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
