every thing works fine up in till it says ready, press the button and it hums for a second then switches off. when this happens the menu button does not work either
-   Same problem here and can't find the reciept to prove it is under warranty.-   jberrong
Apr 26, 2008
-   Mine looks fine until I press the brew button, then hot water comes out of a valve in the top of the tank and goes into the water tank. Any ideas?-   NicoleG
Jan 03, 2008
-   After 8 Months of flawless operation, The ready to brew indicator comes on with buttons flashing. Once a button is pushed they stop blinking and nothing happens.-   r2d2c3po
Dec 27, 2007
-   Have keurig coffer brewer will not brew coffee,turns on
push brew button nothing happens.
Have about year and half.-   Guest
Dec 24, 2007
-   Having the same issue as above. After inserting a K-cup, machine says "Ready to Brew" and two cup buttons flash (mine is a B50). When I select a cup button, they stop flashing, and nothing happens. Menu button does not work. Unplugged it and waiting for a few hours to try again as suggested above. The unit is just over a year old (arrrgggg!)-   jookymon
I too was having the same problem. Mine is out of warranty and Keurig will not fix machines that don't work. They did offer me $50.00 off a new machine on Jan 17th. I will not order a new one. Way too expensive to replace every other year.
Having the same problems, called and complained -out of warranty but they will offer a deal on a new one. Sounds like they have a revised processor board to fix the issue. So for about half off - they will sell you a new one. Not a fix but hey. my family can't get enough of the thing.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jan 18, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i called AGAIN and they sent me new B60 macine. Thought mine was out of waranty also but they seemed to think otherwise. Sent the old one back...happy again!
Here's what I found from Keurig:
First, use a paperclip to clear the injector from which water is delivered into the K-cup. The injector looks like a short, thick injection needle in the centre of head assembly. Simply lift the lever, remove any K-cup and look at the roof of housing.
Second, decalcify the internal tank. There is an internal tank in addition to the external tank that we put water into. Put decalcifier or vinegar (undiluted) in the external tank and run 3 brew cycles. THEN, leave the machine on for FOUR hours while the decalcifier works on the internal tank. Then put fresh water in the outer tank and run cycles until clear.
I had the same problem. I put the pod in, then the water, the brew light flashed, then the machine turned itself off. I called Keurig customer service and was walked through a process for cleaning out the 2 pins that puncture the pod when you close the lid. In the compartment that you put the pod into, you will find one pin on the top lid and another under where the pod sits. I was told to take a paperclip and gently, on the top pin, on the side of where the pin is, rub out any grounds that may have gathered on the pin. Clean the bottom pin in a similar manner. I found coffee ground that were clogging up the works. Then I was told to run the machine through 2 or 3 cycles with only clear water to flush out the machine. This worked great and after 2 cycles with plain water and no pod, the machine started working again. The suggest doing this once a month or so to avoid clogging. Hope this works for you too.
My would only brew without a k-cup in it. (only hot water) I took the k-cup holder out and soaked in hot water then used a bent paper clip in the point at bottom to unclog. Worked great after it was cleared!!!
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #7
posted on Aug 03, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This would occasionally happen to me whenever I filled my resevoir with too cold of water (like the water from my refrigerator).
They offered me discount too at $100 but I find myself using the machine to boil water to steep tea directly in a cup. $100 is too expensive to boil water. I am going to boil water on the stove the old fashioned way.
Lost the part the coffee pod sits in and cant find a replacement anywhere on the net or and any...
(More)
Lost the part the coffee pod sits in and cant find a replacement anywhere on the net or and any local store in the Milwaukeee area. The coffee maker is useless without it. Where can I purcase this part? GR
we have a keurig coffeemaker, and it's not making a full cup..maybe half the water comes out....have...
(More)
we have a keurig coffeemaker, and it's not making a full cup..maybe half the water comes out....have restarted, gone thru menu, don't know what the problem is...
won't brew, when i push the flashing cups, it just shuts down. After a few days, when i push the flashing cups, it buzzes for a second, then shuts down.
Comment by Guest, posted on Nov 04, 2007
I have two Keurig, and both have the same problem. After inserting a K-cup, machine says "Ready to Brew" and three cup buttons flash. When I select a cup button, they stop flashing, and nothing happens.
Machine seems to work again, if I unplug and wait several hours.
