Question about Canon MX300 Office All-In-One Printer
Alarm light check the ink
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
I have a canon MP530 waste ink pad near full. what should i do?
Press the OK button.
The service call error, indicating the waste ink absorber is full,
is likely to occur soon.
Once the waste ink absorber becomes completely full, printing
cannot be done until the waste ink absorber is replaced.
To reset it:
With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT
release the buttons). The COPY button lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset
buttons. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange
and COPY in green, starting with Alarm LED.) "CANON Idle" is displayed on the LCD.
4) When the COPY button lights in green, press the Stop/Reset button the specified number of time(s) according to the function
listed in the table below. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately,
Alarm in orange and COPY in green, starting with Alarm LED.)
4 times - Waste ink counter
resetting
Hope that helps!
Aug 19, 2010 | Office Equipment & Supplies
I have Canon multifunction MX310 I was using
press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.Canon do not like you to use refills and generic carts so the function for detecting the remaining ink level will be disabled
Jun 19, 2010 | Canon PIXMA MX310 All-In-One Printer
My canon mp170 has a yellow alarm light on and it says "check ink u051" i already checked the ink and replaced them with new ones..
MP170 can only accept PG40, PG50, Cl41 & CL51 only. Please check the cartridge model correctly. if problem still persist, ask for replacement for the faulty cartridge
May 19, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
I just replaced both ink cartridges and the alarm light is now on. The LCD screen reads check ink, U053, BLK COL. I can't get the printer to work or perform any functions.
On the canon MX300, holding the "reset" button down for about 10 seconds will extinguish the alarm light & should normalize all functions. The ink level will still indicate "low" , just ignore it.
Rogert
Apr 08, 2009 | Canon PIXMA MX300 All-in-One Printer
Ink is low unable to scan/fax
I had the same problem. I had just installed new black ink cartridge and had the same problem "CHECK INK" and alarm light is on. My color ink had just runned out. I was just about to go buy the color ink to see if it would fix the problem but decided to try it one more time. This is what to do..Click on the print command and a cannon message will pop up saying that you have no ink (it being the black or the color) then you will get the CHECK INK message all you have to do is PRESS the "Stop/ Reset" button for atleast 5 seconds and it will let you print..
Dec 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Alarm light
hmmm..unhook printer from pc...restart and run a menu test page...
if that works, re connect to the pc..
and you might need new drivers get em here
Mar 10, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon MX300 Office All-In-One Printer Logo
13 people viewed this question
old marine
old marine
