Question about Frigidaire 131208500 Frigidaire Washer Pump
How can i tell if the pump on my Frigidaire Washer model #GLTF2940FS1 is going bad. it makes a humming noise when it is at the end of a cycle
docjohn174
  • 943 Answers
SOURCE: I just had a Frigidaire
hi thanks for the question make sure both water taps to washer are on check that because if the cold water if off it wont go into rinse cycle thanks the appliance doc
Posted on Sep 27, 2008
  • 29 Answers
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Posted on Oct 15, 2008
aborcass
  • 2651 Answers
SOURCE: frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Posted on Oct 19, 2008
  • 120 Answers
SOURCE: Washer leaks during spin cycle
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
Posted on Jun 02, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
Frigidaire washer makes a very loud humming noise on spin cycle.
Good Morning Larry Looney, thank you for your post!
I understand that your Frigidaire frontload washer is making a humming noise while in spin cycle. This could be a potential problem with your motor or drum bearing. In order to find the proper cause of the humming noise I would highly recommend having a professional technician come out to your home for diagnosis and repair. This will help to avoid any unnecessary part purchases as well as any future issues. -Matt
Nov 14, 2014 | Frigidaire ATF6000ES Front Load Washer
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer won't drain or spin. Makes noise when spin cycle begins. Any suggestions?
Good Afternoon Friend, thank you for your post!
I see you are having trouble with your Frigidaire washer (GLTF2040ES0) not draining properly or spinning. Often, this is because your washer cannot dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your appliance. Best regards - Z.
May 21, 2014 | Frigidaire GLTF2940ES Front Load Washer
Tell lid switch bad
Hello Kathleen, thank you for your post!
I understand that your washer will not spin; however is your appliance making a humming noise? If so, either the drain hose/pump is clogged and needs to be clean. Also try resetting your washer to the spin cycle only. Will water pump out? If it does not, then your washer could possibly have a faulty pump, timer, control board or door/lid lock assembly. In this regard, I would personally reach out to a professional for an accurate diagnosis and to assist with the repairs. You can often locate a qualified service provider by visiting the manufacturer website.
Feb 06, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frididaire model atfb6000es1
Hi Stacey C - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 06, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire Washer wont drain
If lid lock is bad the tub will not spin properly. Unplug, remove front and look at the lid lock closely. Let me know, Thanks, Sea Breeze
Jan 08, 2009 | Frigidaire GLWS1233A Top Load Washer
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
I just had a Frigidaire front load washer installed today model #GLTF2940FS1 and I am having a problem with the rinse cycle. When the wash cycle is completed and the spin cycle the machine will stop at 26...
Sep 27, 2008 | Frigidaire Washing Machines
Frigidaire 131208500 Frigidaire Washer Pump Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
