Question about Sony RM-YD063 Remote Control 148948411
Battery cover for Sony RM-YD063 - Sony RM-YD063 Remote Control 148948411
I recently moved just last week. Prior to that move in was able to access my netflix account on my Sony Bravio TV RM-YD063. How do I get it back?
Can you access other apps on your tv? ie. Hulu or crackle. If you are having issues with multiple applications you probably need to reset your wireless connection on your tv. I know your using the same wifi router but maybe your router is too far away from your tv or a setting has changed.
Oct 08, 2017 | Sony Computers & Internet
How do you Open Sony rm-yd059
SONY RM-YD059 remote is easier to disassemble then other models. Slide battery cover open 1 inch or half open. Using a plastic toothpick or similar device pop cover using the groove. There are three sliding locks on each side. You will now see six screws holding halves together - remove. There are six more clips holding remote together. Starting at the top working towards the bottom, there are three per side, location of clips at red and blue buttons, at between 4&7 and 6&9 rows, and finally at muting and jump buttons. Voila - Happy cleaning. Note: directional ring is keyed with thin and fat tabs, fat tabs are positioned towards the bottom.
Feb 04, 2013 | Sony RM-YD059 Remote Control 148947911
How do you replace batteries in a sony rm-sp350 remote
On the back of the remote, press the battery compartment cover where indicated and slide the cover off. It may be difficult to remove
Dec 02, 2012 | Televison & Video
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
I need to separate the covers on a Sony TV Remote Control but there are no screws holding the covers together. Model no. RM-ED005 (R) Can you help?
At the bottom of your Sony RM--ED005 Remote control you'll see 2 small rectangular holes. I used two small screwdrivers, one to create a gap the other to prise the unit apart, when u are able to get your fingers in gently separate both parts from bottom to top.
You'll notice where the rubber pads meet the contacts there is 'condensation' this is what causes some of your remote buttons to fail.
Simply wipe away with a clean damp cloth, dry off, clip the remote together again and you basically have a new remote control.
May 31, 2011 | Sony RM-V310 Remote Control
Sony remote RM-Y135 got dropped into a bucket of water. What to do?
If your device gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the batteries.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put new batteries back in and power on.
Nov 16, 2009 | Sony RM-Y135 Remote Control
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Lost Instruction Manual Paper for Sony RM-V401 Remote Control
You must press "set" button (with a pen), then press "tv" followed by the code you have and finally "enter". Regards
Jul 13, 2008 | Sony RM-V401 Remote Control
Sony RM-YD063 Remote Control 148948411 Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
