Question about GE 32GT740 32" TV
Blank green screen without picture
Audio is fine, but no picture
Television goes blank without warning for undetermined time
Power supply board have problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 32LC2D Television
New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
Dec 26, 2009 | Proscan PS50700 50" Rear Projection...
Green screen, white lines. Audio fine.
You most likely have a bad picture tube. Green gun is shorted. Usually a set this size is not economically feasible to put a new tube in. You may also have a green drive problem on the CRT board. Have a shop check it out for you before junking it. Thanks for using fixya.
Dec 05, 2009 | Philips Televison & Video
46 inch Sony flat panel lcd has vertical red and green lines down right side of screen and you can be watching tv and picture will go right out and leave grayish blank screen until restart. Black...
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Apr 28, 2009 | Sony Televison & Video
My ps3 is showing a blank screen.
if you barly bought it then return it and get a new one because it was dropped when they ship it
Apr 03, 2009 | Sony Playstation 3 (PS3) Console
We have a 25 year old zenith console, pretty old.. but still functional.. we noticed that the tv turns blank to a green screen... no picture just green color shown on the screen, then it will go back to...
Hi and welcome to FixYa,
Initially, your described problem indicates that one of 3 color drive transistors (for the green) has developed either a cold solder (most likely) or an intermittent internal fault (leak). These transistors (or in some cases a single power pack module/IC) are normally found on a small squarish PCB (printed circuit board) at the very rear of the picture tube (CRT). At times, the green blank screen would also have diagonal fine lines or would appear to be overly bright.
In some rare instances, it could be the chroma section (least likely) or in worst case scenario the CRT (cathode ray tube) itself that is faulty (hope not).
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 18, 2009 | Televison & Video
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
No Picture, cannot power off without unplugging, flashing green light
The part is Replace an X-tal (Viper) on SSB item 1H00, order code: 242254301397. The small small signal board is the one with the video jack on it. It mat be easyer to replace the SSB but yes it will cost more.
Oct 09, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
GE 32GT740 32" TV Logo
20 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
