Question about Frigidaire Washing Machines
To clean the washer's self cleaning lint filter FEX831CS
  • 1314 Answers
SOURCE: Avanti W851 Top Load Washer, Self Cleaning Lint Filter
they should be able to order one from any appliance pars store but if not contact avainti here ive worked for them for years most of the time if you contact them they might send you one if not they will get you one http://www.avantiproducts.com/
Posted on Jan 30, 2008
  • 177 Answers
SOURCE: LInt filter
Find you owners manual, it should say how to clean the button trap on your pump
Unplug the machine FIRST!
Get some towels, you will have water coming out.
if the tub is full of water you will need to bale it out!
Remove the lower front panel, usually two screws,
look for the pump it will have hoses on it. now lay some towels around, expect water.
Unscrew the end of the pump, if it has a button trap or lint filter.
it will be on or near the pump refer to your owners manual
If you dont have an owners manual you may find it at Samsung.com?
Posted on May 03, 2008
  • 1028 Answers
SOURCE: I know it has a self cleaning filter, but.......
not a true filter on machine ..if you have odor issue try filling tub ith hot water pour in 2 cups chlorine bleach allow to mix and then let set approx 30-45 min aloow to finish cycle this will also help clean any residue from outer plastic tub that may be coming back off onto clothes by the way what passes for a filter may be 4 small washers under agitator or at best a plastic piece with lots of teeth under inner basket on bottom good luck
Posted on Jun 28, 2008
  • 634 Answers
SOURCE: Lint on dark clothes
no product i know of , try running machine without cloths with hot water and a lot of extra soap the unrestricted water movement and extra soap lubricates and helps to flush machine out, let machine dishcharge into bucket and if poor flow or lots of debris run again and see if this clears up you issue
Posted on Jul 07, 2009
  • 10 Answers
SOURCE: Does this washer supposed to have a lint filter
No Lint Filter sorry you have a basic design washing machine, Dont replace it though it wont do u any justice just pocketbook pain
Posted on Jul 23, 2010
I have the KAWS700GQ washer with a self cleaning filter. My dark clothes are now covered in lint. How can I clean the filter?
go to
www.youtube.com/kitchenaid_washing_machine/how to clean the self cleaning filter
www.ask.com/
www.about.com/
www.wikipedia.org/
/how to clean a self cleaning filter for a KAWS700GQ
go to www.kitchenaid.com/service/how to clean the self cleaning filter.
Apr 13, 2015 | KitchenAid Washing Machines
Dryer not heating checked heater it is ok what else can i check
Make sure lint filter is clean - all the way through the components from where it leaves the drum until ir exits the conduit to the outside of the house. Many times the lint build up can block the air flow and keep the unit from functioning efficiently. This is probably true more in humid climates but I have had this happen in the Las Vegas desert as well.
Aug 16, 2011 | Frigidaire FEX831CS Top Load Stacked...
The washing machine does not filter out lint. It
I have the same problem. There's a plastic piece top back of tub that says "Clean lint filter after each load", but where is it ?
Mar 14, 2010 | Frigidaire FEX831CS Top Load Stacked...
Lint on cloths after wash is there a lint filter in the washer and where do i find the lint filter
There is a fine screen on the bottom of the inner tub under the agitator. It is self cleaning every time it spins out. If you use too much fabric softener, the screen can get clogged. Fabric softener is hard to clean off and the screen is pretty delicate.
Jan 03, 2010 | Whirlpool LSR7333 Top Load Washer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
LINT LEFT OVER CLOTHES
It has a self cleaning lint filter. Front loaders call for "Special" HE detergent .....and I would only use about a table spoon..You may be Cloging the special self cleaning lint filter ,with extra soap .Top loaders use a lot of water compared to front loaders. Let me know ,If I could help Again! Thanks
Dec 14, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Increased drying time; removal of lint behind tumbler ???
I have a top loading Kenmore High capacity dryer that is over 10 years old, it has been working very well, unfortunately when cleaning the lint filter my wife dropped a piece of paper down the lint duct hole. The paper evidently fell to the bottom of the lint duct. I am unable to reach the paper from the top of the dryer where the lint filter is inserted.The dryer now makes a grinding type noise when it is turned on. Can you tell me how to reach the paper and remove it
Mar 28, 2008 | Frigidaire FEX831CS Top Load Stacked...
Jan 30, 2008 | Avanti W851 Top Load Washer
Washing machine lint
fluffed up,
If you have a manual filter..make sure it's clean. If you do, and it is, the tub drain could be blocked.( it is under the agitator and basket, requires disassembly) If you don't have a manual filter, the self-cleaning filter/ trap could be clogged.(it is underneath, also requires some disassembly. If you have tools and feel comfortable with things mechanical, get a repair manual from the library, maybe you can tackle the fix.
hope this helps,
handiman518
Jan 04, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
15 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
