Question about Kenmore 15208 Mechanical Sewing Machine
Stuck in reverse
Started sewing in reverse and it wouldn't ever disengage from reverse, so now that's the only direction it will sew in
  • 3 more comments
  • Anonymous Dec 08, 2007
    We also have a machine stuck in reverse. I will try to take the cover off and oil it to reset it. Thanks Susie
  • Dymonsnrust Jan 11, 2008
    I recently purchased a used Singer Model #6234 for my mother. When she tried sewing it would not disengage from reverse. She now has 3 unusable sewing machines sitting in her sewing room!
  • kiana-2 Jul 22, 2008
    oiled machine...model 6022 made in Taiwan
  • kbjkadkins
    kbjkadkins Dec 06, 2012
    for anyone having an issue with reverse sticking or only running in reverse, your machine maybe dusty or need oiled. Also you may have an issue with thespring operating the reverse button. I was given an older 12 stitch kenmore and my husband was able to remove what looked like lent and oil it, the machine works lik new. GOOD LUCK!
  • Anonymous Mar 26, 2014
    Will. Only sew in reverse
The reverse button is attached to link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it). In order to solve the problem, the covers must be removed.
Posted on Oct 27, 2007
Singer simple sewing machine will not move forward, but will sew reverse with holding the reverse lever down like it is supposed to do. I have been sewing for 50+ years. No simple answers please
Sorry--the only thing I can find is that possibly the auto reverse is turned on. Other than that, perhaps contact Singer directly or take it for service.
3221 SIMPLE Singer Sewing
Jul 08, 2016 | Singer Sewing Machines
Necchi 535FA is stuck in reverse, no matter what adjustments I change. I oiled and cleaned it and properly threaded it. Everything seems to work and move fine, except the reverse button was stuck.
A part of the Reverse Button mechanism is probably frozen.
This may work:
Direct heated air from a handheld hairdryer into the internal mechanism and let the metal parts get pretty hot. (Don't burn your fingers!) Then try the reverse button to see if it has loosened. Repeat and hopefully it will begin working. If you figure out where the reverse button mechanism is located, you can try lubricating the metal joints--ONLY 1-2 drops of GOOD quality sewing machine oil (do NOT use 3-in-1, WD-40, cooking oil, or OLD sewing machine oil). Then try the hairdryer again. Do NOT oil plastic parts or belts unless directed to in the owner's manual instructions.
Vintage Sewing Machines
To keep your machine sewing well, be sure to clean and oil on a regular basis--about every 8-12 hours of continuous sewing, every time you empty a bobbin, or if it's not in frequent use, every six months. Oil drying out is a frequent cause of machine moving parts freezing.
Sep 01, 2015 | Sewing Machines
Singer 4166 suddenly started sewing only in reverse even when forward mode checked
open the top of the sewing machine. Then press the button or lever that changes the forward reverse mode. You may find that something got stuck there where it should effect the machine part. May a drop of oil on that spot can help?
Jan 11, 2014 | Singer 4166 Sewing Machine
When I put my material in the machine, it sews backwards, and I can not figure out how to get it to sew forward.
I just advised another person with the same problem, I think that somehow your lever disengaged and is stuck in the reverse position. Call Singer at 1-800-4singer and ask for advise how to fix it, if it out of warranty. Or, if it is new, take it back and get a new machine.
Sep 06, 2010 | Singer 3116 Simple
My feed dogs are going backwards
They are suppose to feed from the front to the back - that is the direction you are to sew.
If they are going forward, the machine is in reverse/back-up.
The reverse/back-up button/lever is in the reverse position or stuck, depending on how your brand/model of sewing machine is designed
Feb 24, 2010 | Sewing Machines
Brother Machine!
The reverse mechanism is stuck. The machine has to be completely disassembled to get to the problem. It is usually not a big deal to get it "unstuck" but taking it apart can be a pain. A good machine tech. can do it easily or you can give it a shot. Just look what the reverse lever actuates and see how it is stuck in the reverse position. It is usually the stitch length/reverse block.
Aug 06, 2009 | Brother XR-65t Mechanical Sewing Machine
Bernina 1090 only sewing backwards
1.Turn the bobbin winder off.
2.You have to reverse the wires on the carbon brushes.
3.Make sure that you have the needle in correctly- with the flat side to the back. Those machines rarely go out of time.
Jul 22, 2009 | Bernina Sewing Machines
I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Jul 02, 2009 | Brother XR-65t Mechanical Sewing Machine
Only sewing in reverse
If your reverse button has been stuck at all in the past then it may have just been sitting close to reverse for awhile and fell into that setting. Maybe your machine needs a good maintenance cleaning.
Feb 04, 2007 | Euro-Pro Deluxe 7130 Mechanical Sewing...
Kenmore 15208 Mechanical Sewing Machine Logo
1,687 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
