Question about Panasonic TC-P50S1 50 in. Plasma LCD HDTV
PANASONIC TC-P50S1 10 BLINKINS
DOES NOT POWER, ONLY TEN BLINKS
eagle338
  • 4889 Answers
SOURCE: All of a sudden my
Your tv has a faulty power supply board also called SOS-P board. Take of the back panel and look for any obvious defects. Start by checking the capacitors for cracked/swollen/leaky capacitors. If the tops of the capacitors are not flat then it indicates that the components are faulty. If you find any you should replace them with exactly the same values. Ex: 40v,1000mF
If you don't find any a component level repair might still be possible so if you are skilled in electronics and know how to use a meter you can start by downloading a service manual. Unfortunately I don't have one for this model but you can download it from the link below
http://www.service-docs.com/store/catalogue.php?cat=278&exp=&resultpage=62&shop=1
Once you have it post back and I will help you troubleshoot this issue.
Sai.
Posted on Jan 22, 2010
  • 12 Answers
SOURCE: Panasonic TC-P54G25 plasma hdtv won't
Perhaps an easy fix. Remove the back of the flat screen. There will be a main circuit board visible. There will be several capacitors, cylinders with a cross hatch on the silver top. Do any of them look like they have a dimple created by expansion of the internal capacitor material over heating? If you see an expanded top...that's probably your problem. Get your solder gun out and replace that capacitor. You can order a new one off of Amazon. If yours is a 10 volt capacitor, consider replacing it with a 16 volt unit. Generally the electronics companies under design the size of these units. When you replace the capacitor take note of the silver band on the unit and where its placed in the two socket holes....there is a positive and negative hole placement.
Posted on Jan 03, 2011
TV #1
  • 129 Answers
SOURCE: I accidentally overheated my Panasonic Plasma TV TH-42PZ700U. It won't turn on, and the power button blinks TEN times.
Check and see if there are any blown caps on the power supply. If there are replace them or change your power supply.
Thank you
Posted on Mar 20, 2012
gopakumarg43
  • 75591 Answers
SOURCE: I need help changed power supply board and ss board and still no picture it is a model TC-42PX14 panasonic the red light still blinks seven times. At wit s end isn't much, can you help me.t
Check this link and select the site named 'Electro-help' You can get more details about the fault to your TV, with 7 blinks of standby light. Check this link and select the site named above.
Posted on Jul 28, 2012
SD Tech
  • 14553 Answers
SOURCE: tc-p46g10 Panasonic blinks red three times then pauses for about 5 seconds then blinks 3 times again and hasn't stopped. What does this mean?
Google the model number with 3 blinks or error codes and you should find it.
Posted on Dec 08, 2012
How do I safely replace the A-board on a Panasonic TC-42PX24 plasma TV? (Or, how do I confirm that the A-board is truly the problem component?)
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 17, 2016 | Panasonic Tc-42px24 42 in. Plasma TV
Panasonic viera plasma tv 10 blink code
1. Hold the front panel power button for over 15~20 sec and try.
2. See the youtube video
https://www.youtube.com/watch?v=awnrE3k_G2M
Mar 09, 2016 | Panasonic Viera Tc-p50gt25 50" Inch Full...
Won't power on ,
With 10 blinks it could be any of the following boards, the blinks tell you that is is a power problem
A-Board TXN/A1LPUUS
SC-Board TXNSC1LPUU
SS-Board TXNSS1LPUU
P-Board ETX2MM806ASH
Mar 08, 2014 | Panasonic VIERA Televison & Video
Tc-p50g20 4 blinks
My panasonic TC-P50G20 does not power on, just I have 4 blinks on my powericon1.png indicator light. What error does that mean?
Jul 24, 2013 | Panasonic Tc-p50g20 Viera G20 Series 50"...
I have a Panasonic Viera TC-P50x1 HDTV. When I turn the power on the red light blinks 10 times. What is my problem?
Unfortunately the set will need serviced. I would contact Panasonic or whoever you purchased it from for warranty information.
Jan 22, 2013 | Panasonic Tc-P50x1 50inch Class Viera X1...
Panasonic tc-42pc2 no power red light blinks ten times
Power supply related---either in the supply or downstream from it.
May 18, 2012 | Televison & Video
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
May 14, 2010 | Panasonic Televison & Video
Panasonic TC-P50S1 50 in. Plasma LCD HDTV Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
