Question about Behringer Audio Players & Recorders
Behringer tube preamp model t1953 - Behringer Audio Players & Recorders
    Problem Solver:
  • 12 Answers
What is the question?
Posted on Dec 22, 2014
How can i get a function switch for a TUBE ULTRAGAIN T1953 (the switch that engages the high pass filter)
If it is one of the toggle switches on the front then IF you can get it from Behringer then it would likely already be soldered to the board. If you just want the switch try a site like mouser.com and search for toggle switch and then narrow your search from there. Not extremely easy, so contact any electronics service center and they may be able to help you as the switch is an standard off the shelf part. Good luck!
Jan 02, 2015 | Behringer Music
Behringer model x 222usb owner manual manual
http://www.behringer.com/assets/X1622USB_X1832USB_X2222USB_X2442USB_M_EN.pdf
Jan 15, 2014 | Audio Players & Recorders
I am trying to find the weight of my Behringer Europower Model PMX2000 weight
Weight (net) approx. 15 kg (33 lbs)
You can rate my answer if this helped you.
Oct 04, 2011 | Behringer EUROPOWER EP2500 Amplifier
Hum on channel 2.
I assume that the hum exists without any cables plugged into the input. If that is not the case, then make sure all input cables and source are using BALANCED lines. If the hum is present with no input cables, since this is a tube type preamp, the input tube for the bad channel is first suspect. It is likely a 12AX7 or 12AT7 type tube. Since there are two channels, the first thing is to SWAP the two channels and see if the hum moves with the tube... if it does replace the tube. I have seen another problem with preamps in general where bypass capacitors from either side of the XLR connectors to ground get zapped with static and one side shorts. This reduces the gain by 6 DB and leads to hum.
Aug 30, 2011 | Behringer MIC2200 MIC.-PRE-AMPLIFIER
Basic settings for behringer mic2200
basic would be all dials in the middle. and appropriate switching on/off of (phantom power) +48volts. this option is required for condenser mics but way too strong of a signal for normal dynamic mics,like the shure SM 58. or any non-balanced input
Dec 23, 2010 | Behringer ULTRAGAIN PRO MIC2200 2 Channel...
Behringer 1508 into 2 300 watt 8ohm speakers will
you got to stating your processor, the amp, the preamp, the speakers type you own.  Without that, its hard to inform accuracy info for your request.
Aug 31, 2009 | Audio Players & Recorders
Behringer MX 3242x Mic input not working
Unfortunately, the way the mic preamp and gain control are surface mount components on the PCBoard, it's unlikely you'll be able to do it yourself. Best take it to an authorized Mackie repair shop, or send it back to Mackie.
Jul 29, 2009 | Audio Players & Recorders
I get a constant noise after I plug in the guitar
The reason for the few seconds delay is that this amp uses a vacuum tube preamp which has to heat up before it operates.
Now with most amps at high gain you will get some noise, but it should be well below the level when you are running program material through it. The statistical electronic noise will be more of a hiss. If it is hum you are getting, then the filter caps MAY have failed. Also if you have light dimmers can sometimes get into the equipment.
First step is describing the type of noise. Behringer is VERY stingy on supplying schematics. Essentially they WON'T unless you are one of theior certified techs.
Your amp SHOULD be simple enough to fix without schematics UNLESS it has one of the Behringer digital effects. That board has a chronic failure of the DC filter cap.
Jul 22, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer europower pmx2000 manual
I found it here.
http://www.bbmusic.bc.ca/behringer/PMX2000_medium.pdf
Sep 14, 2007 | Audio Players & Recorders
128 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
