Need the reset keys for toshiba estudio 6550c printer
5 Suggested Answers
SOURCE: reset fax data in toshiba estudio 350/450
how do I find my IP address for my Toshiba e-studio350
Posted on Mar 04, 2009
  • 457 Answers
SOURCE: need windows 7 (64 Bit) driver for Toshiba eStudio
Toshiba does not yet provide 64bit drivers for this device, also Windows 7 is not (yet) supported. You need to contact Toshiba directly, if enough people complain, they may be inclined to fix this unfortunate situation.
Posted on Feb 07, 2010
SOURCE: Toshiba Estudio 350
I have an e-studio 350, we lost power and when the power came back on it went to call for service mode. I tried to tun it off and unplugged the unit but it still came up with same call for service mode. Unfortunately I dont have the money for a service call and would hope that there is a simple solution. can anyone help???
Posted on Jul 24, 2010
  • 30 Answers
SOURCE: I need a reset code for maintances on a toshiba
Hi how are you this is jack... jack_pak@hotmail.com
Dear you need PM maintances code..
ON the machine 08 mode and change the 251 value.
Change or Zero. ok .Then you change This value your copier finished Maintenance Indecation.
PLEASE VOTE ME.
Thanks.
Best Regards,
Posted on Aug 15, 2010
Testimonial: "Thanks for the help you give me, it was very simple to fallow up and easy to understand. Again, Thank you."
Toshiba estudio 181 error c44 how to solve
Here in this post I explain about a specific problem faced by Toshiba eStudio printer users. Toshiba eStudio series is high speed printer and mainly used in corporate offices. One day when you work all of a sudden you receive an error message from the printer and it shows C44 and now you can't print anymore. Frustrating isn't it?
Little bit facts about the C44 error, C44 simply means that the count of printer has gone above the limit and it needs service. But in most cases its false positive, means many reasons can bring up the issue. Some of them include over heat of printer parts, issue in settings, or any particular component failure but above all it occurs for some unknown reasons also and that's why you can use this to rectify the issue. The advantage of doing this is that if the issue do not solve up after doing this you can call you service engineers but if it gets solved it can save your money for calling the service engineers.
Solution:
  1. Switch off the printer first.
  2. Now Power the Printer by pressing 0 and 8 keys (keep pressing).
  3. Then a test mode comes up.
  4. Now Type 400.
  5. Press START (!)(You will get a counter and now you need to reset this).
  6. Type 0.
  7. Press Enter(start)
  8. Switch off the Printer now and restart and check again with first steps till typing 0 (You need not type 0).
  9. Now switch off the printer and on it normally.
  10. You should see printer working normally
This fix is applicable to all Toshiba eStudio printers.
Nov 03, 2017 | Toshiba Computers & Internet
How to fix the "Time for Periodic Manternance 0180" of Toshiba EStudio 255 ? Thanks.
You can reset this by the following procedures.
1. "Off" the copier then press "Start" and "6" keys at the same time.
2. "On" the copier while doing step 1. Wait til you see the display panel change then press "2" key, then "Start" .
3. It will show list of the PM items. Reset the counters then restart the copier..
Nov 27, 2014 | Toshiba estudio 255 Copier
Toshiba studio 181 error c44
This error indicates that the print count has gone above the limit and it requires service. But, this is not necessarily true. Try the following to reset the count:
Solution:
  4. Now Type 400.
  6. Type 0.
Resource: Clear Toshiba eStudio printer error message Error C44 call service
Jul 23, 2014 | Toshiba Computers & Internet
How do I print via USB on a Toshiba Estudio 200L copier?
You might need to have an enabler, which will fix to your copier.
May 16, 2014 | Toshiba Estudio 200L Copier
I replaced the drum and wiper blade and I need to clear the maintenance reminder on Toshiba eStudio 202L. I cant find the procedure in the service manual. Do you know which code will reset the...
switch off machine hold down 6 and print key switch on when the machine is on enter 2 and reset you counters switch off and wait 30 seconds and switch on again
Feb 11, 2011 | Toshiba e-Studio 202L Copier
I have an estudio 350 that I need to reset after a "time periodic maintenance". How do I reset?
THIS MESSAGE APPEAR BECAUSE THE PM COUNTER IS THE SAME OR LESS THAN THE COUNTER OF PM'S UNITS (YOU CAN SEE THIS COUNTER ON THE 08 252).
YOU HAVE TO DO THE PM TO MACHINE. HOWEVER YOU CAN DO THIS STEPS TOO:
1.- TURNS ON THE COPIER HOLDING 08 KEYS
2.- ENTER 251 CODE AND PRESS START KEY
3.- ERASES THE NUMBER THAT SHOW AND PUT 0
Dec 09, 2010 | Toshiba e-Studio 350 Copier
Don't know the password for Toshiba estudio 450.
default password is 12345 for toshibas...go into user functions, administration...
everything is there...
Jun 18, 2009 | Toshiba Estudio 200L Copier
Reset fax data in toshiba estudio 350/450
Nov 30, 2008 | Toshiba e-Studio 350 Copier
I want reset my estudio 163
Press *+1+3 and power on the machine.
Nov 29, 2008 | Toshiba e-Studio163 Copier
20 people viewed this question
jasbo
jasbo
