Question about Kenwood Food Processors
Burning motor smell - Kenwood Food Processors
Even after replacing the fuse my magimix 2800 food processor won't come on what should I do?
Check to see if the motor burned out by doing a continuity test of motor windings.
Dec 24, 2015 | Magimix Food Processors
Motor keeps stopping
If you are making it do alot of work it may be slowing down enough to heat up. This will trip a thermal cutoff. Fortunately that one resets and you don't have to have an expensive repair. But now it may have overheated a few times and will start to burn off the varnish that insulates one winding from another. It will eventually burn out if you work it too hard. Can you get a more powerful one? Do you do this often?
Nov 26, 2013 | Magimix Food Processors
I have purchased a kenwood FP270 food
not sure if this helps, but we bought the same FP270 11 months ago & use it 3-4 times a week with juicing attachment with carrots & apples. Last week the motor started to smell, and motor burnt out completely today with dust & noxious smoke coming out of the bottom. The Good Guys exchanged it for FPM270 with no hassles under warranty. I don't think the motor is powerful enough for serious kitchen work & had many cracks in the plastic parts.
Feb 17, 2011 | Kenwood Food Processors
I think my magic bullet over heated and now it won't work. I could smell burning plastic and now when I try to use it, it won't blend. Any suggestions. I hate to buy a new one because I don't need all...
The Magic Bullet power base is designed with HIGH TORQUE MOTORS and it is NOT TO BE USED FOR MORE THAN A MINUTE PER USE.Otherwise its gonna last a long time. You need to buy a new one or a refurbished one. Search google with keywords "amazon magic bullet power base".
Oct 15, 2010 | As Seen On TV Magic Bullet Food Processor
Won't work
Turn it over and remove the screws.
Jan 31, 2009 | Bravetti E109FS Food Processor
Motor burned out
emailed Euro-pro.com and ordered a new motor! Have all the attachment that where going to waste. Hopefully this one will hold up.
Debra
Nov 09, 2008 | Bravetti SB212H Quad Blade Food Processor
Food Processor
you need to buy something like a Magimix, these have induction motors and a lot less problems look at http://www.magimix-spares.co.uk/which_processor.asp for more information , if you buy something like a magimix you get a 12 year motor guarantee and 3 years on parts.
Sep 09, 2008 | Black & Decker Food Processors
Ultimate chopper motor not spinning
ik heb een mes van ultimate chopper nodig
Sep 24, 2007 | Ultimate Chopper Food Processor
Food processor stopped working
hi there is no reset switch follow these instructions and it suppose to work http://www.useandcaremanuals.com/pdf/FP1300-1400Series791.pdf when you used it did you smell a burned stench? is the unit smells still from it? then probebly the coiles are burend - sorry cant help.... http://www.blackanddeckerappliances.com/customercare/home.jsp good luck
Mar 21, 2006 | Black & Decker FP1300 Quick N Easy Food...
Food Processors Logo
35 people viewed this question
Top Kenwood Food Processors Experts
tfelton3
 Mikey
Mikey
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
